Old 12-02-2007, 01:00 PM   #1
Curare
Default AX tx5 tyres
I just got to work and noticed that my rear tyres are stuffed, in fact one is so bad it looks like if I drive on it again I'll delaminate it.
Now the question is, can I run a set of 205/60's on the rear without any ill effects?
Thanks for your help
Curare
Curare is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2007, 09:36 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
you can only run the tyres specified on the tyre placad /sticker
should be under the bonnet in the glovebox or on a door frame/ask a tyre supplier
My car goes Brumm Brumm
Old 13-02-2007, 12:01 AM   #3
crankyTX5
I also have trouble with rear tyres on the AX. In the past I have delaminated to the steel belts. I found the rear rotors warped when I took them off and lay them on flat concrete. New rotors seem to have solved the problem and rotate the tyres regulary.
crankyTX5 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 04:34 PM   #4
daz82
In the family since 1996
daz82's Avatar
205/55/15", toyo had a good tyre out a few years back when i had a tx-5
daz82 is offline   Reply With Quote Multi-Quote with this Post
