24-01-2007, 10:24 PM | #1 | ||
|AFordEd|
Hi All, i want to put some switches in my car for my neons and lights, just want to know if any of you can help me with my setup that I was thinking of,
having on the 'X' Missile Switches and the blue strip as a neon, I'd obvioulsy need some sort of plastic plate to mount on the roof, but the real help i need is wiring up the circuits. how would i go about putting wires along side the panels of the car, i'd need to take the lining out and so forth, how is it done:S? or is this to much of a hassel???? thanks Ash
1996 Ford Fairlane mock by tickford EF Xr6 Engine EF Xr6 ECU 3:4:5 LSD diff JMM Extractors 2.5" Stainless Steel highflow cat 2.5" Exhaust T5 transmission Front Slotted rotors Lowered on Pedders Sports Ryders ....and a cherry scented airfreshner Speed determines how fast you hit the Traffic Light....Power determines how far you take it with you. |
24-01-2007, 10:29 PM | #2 | ||
Gunna girlie-man
its alot of hassle, and in the end of the day it may look like a tacky race car inside
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
25-01-2007, 01:11 AM | #3 | ||
What's green is gold
got rice?
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
25-01-2007, 11:47 AM | #4 | ||
|AFordEd|
Just a few lights, not riced up, **** that ..........
Aussie muscle
25-01-2007, 12:11 PM | #5 | ||
Oops, I slipped....
Yes you would need to take the roof lining out, you need to pull all the interior trims out that go around the roof lining, as well as the lights and sunvisors. Go around the roof, undo all the philips head screws, then the pillar trims are clipped on, use a flathead screwdriver to gently lever the clips off. You can run the wires down behind any of the pillar trims, no problems there.
Now whether or not it will look good is your call, as it's your car, I remember my old man had a roof mounted console in his CF Bedford van, that was cool as!... in 1986 :P
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
25-01-2007, 11:05 PM | #6 | ||
|AFordEd|
thanks heaps Aaron (positive guy), ill take it into consideration..
25-01-2007, 11:17 PM | #7 | ||
I reckon if you find a 2nd roof lining and trim the switch board in that fabric it would blend in and look good.
