24-01-2007, 07:27 PM | #1 | ||
My XR6 is starting to show symptoms of a rooted head gasket. Coolant is coming out between the head and the block behind the exhaust manifold. Just wondering if when I replace it, would there be any advantages of putting an AU XR gasket in for example. Which model had the best quality standard gaskets? And are they interchangable?
24-01-2007, 07:31 PM | #2 | ||
yep, put a AU headgasket on, i did, it fits no problems, and it even raises compression a little bit!
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
24-01-2007, 07:44 PM | #3 | ||
now with 3.73 lsd
au gasket gets my vote
g6e turbo |
24-01-2007, 08:09 PM | #4 | ||
Are the gaskets the same for each series, or is there a particular one to get?
24-01-2007, 08:30 PM | #5 | ||
Living the Dream
AU gasket, it should outlast the life of the car.
24-01-2007, 09:31 PM | #6 | ||
one day
au gaskets are the go there really just a shim
XY GTHO MOCK 406 cleveland grout filled, pavtek alloy girdle scat 4340 crank, scat h beam rods 2000 series bolts CHI cnc 2v heads comp 308r solid roller camshaft torque power single plane manifold 950 quickfuel race carb pro trans c10 with transbrake 5500 tce converter 3.89 diff gears |
24-01-2007, 09:32 PM | #7 | ||
Location: Under the bonnet, trying to keep as clean as above!
AU seems to be the way to go. But to all out their that have used one, what head bolts do/should you use? and what torque do you take them up to?
pete j |
24-01-2007, 09:33 PM | #8 | ||
AU multi-layered seems to be the way to go. But to all out their that have used one, what head bolts do/should you use? and what torque do you take them up to?
pete j |
24-01-2007, 09:37 PM | #9 | ||
one day
i use new bolts as the old ones fatigue and twist
25-01-2007, 02:34 AM | #10 | ||
what does the head job cost? and when do you know that you gotta go for the full go.
25-01-2007, 02:39 AM | #11 | |||
This is open to two interpretations, I find one of them very funny. Think about it. :
Quote: Originally Posted by XCPWSF Is there portable speed cameras? Because coming home from school I noticed a cop sitting on the corner, with some box with buttons and knobs, with wires running into one of the big gum trees. Just practicing with the Tazer on a Koala? |
