04-11-2006, 07:15 PM | #1 | ||
95-97 statesman SC V6. Im trying to find out what these SC 6cylinder cars ran factory down the quarter.Thanks for any info....i actually want to see if it will beat my wifes Fairmont Ghia EF Ticky :evil3: taaa
04-11-2006, 07:16 PM | #2 | ||
Mid-low 15s is about what they run.
04-11-2006, 07:23 PM | #3 | |||
Brobably why most commadores have "chrysler hemi" when they go for a supercharger. cheers kyren
Ambrose driving in Nascar and joining RPM Murphy somewhere in the V8'S. XR6 Turbo.Championship winner. |
04-11-2006, 07:29 PM | #4 | ||
V8 Powaah
Well in early VS2 form they were pretty quick, about 170kw in a 1450kg shell. But considering its a Statey the weight should be around 1550 and would pull a mid 15 i should imagaine.
It should beat your wifes Ghia pretty soundly, not because of the power difference, but gearing and weight (50-100kg) will be against you.
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
04-11-2006, 07:31 PM | #5 | |||
now with 3.73 lsd
better of asking this question over at streetcommodores forums or just commodores buddy hehehe
g6e turbo |
04-11-2006, 08:02 PM | #6 | ||
Now XR8TickfordBoy
Was reading street machine that had an article on the S/C VS Holdens, I dont think its that their quick from factory but they are built with stronger engine components/internals making them much more suitable for boosted applications (turbo or supercharged) and the boost can be wound up and modified with little risk to the engine compared to standard ecotec engine! So from what I understood the main benefit from a factory S/C ecotec engine is as a basis for a boosted application not to keep as a stock S/C car! My mates got a S/C 2002 Monaro and the manual says that's only 175 odd KW from factory!
EF XR8- Respray in Monza Red with Clear Coat, Custom Rear Bar, AU V8, EL GT MAF, Rebuilt and Strengthened Auto with Stage 2 Shift Kit, 2,500RPM Stallie and tranny cooler, Rebuilt Diff with 4.11 Gears, Custom Radiator, King Ultra Lows, Pedders Shocks, NL Concorde Rims. |
04-11-2006, 09:36 PM | #7 | ||
Solution Was Boost 4?, 6 & 8
Stock V6 Supercharged makes the same power as a stock BA i6..
The HSV XU6 Commie had 180fwkw.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
05-11-2006, 12:06 AM | #8 | ||
In crate form from GM. They are rated at 180kw, either holden detune them or fiddle the figures. They are not blistering fast but go fairly well. in VS ans WH form.
05-11-2006, 12:26 AM | #9 | |||
05-11-2006, 12:41 AM | #10 | ||
My brother has a VT XU6 and the thing goes pretty hard - are you saying a BA XT will go harder?
05-11-2006, 12:47 AM | #11 | |||
I smash them both anyways :P |
05-11-2006, 01:10 AM | #12 | |||
you can think what you like as per 1/4 mile figures. im stating what happend and why. |
05-11-2006, 01:25 AM | #13 | |||
Only a matter of time.
VS V6 Supercharged engines only had 165kw. VT onwards was 171kw.
They ran around the 7 second bracket too 100. Probably the biggest hindrance for them was the Auto. So stock 7's too 100 and 15's 1/4. If a VS Calais it might brake 15 1/4's being lighter. I don't know the weight of the stato. Little bit i found online. about the VS stato. Quote:
"SOUNDS THAT GO BUMP IN THE NIGHT" |
05-11-2006, 01:34 AM | #14 | |||
05-11-2006, 01:47 AM | #15 | |||
My brother was told by a holden mate that they wouldn't trust the manual with this engine they seen it too dangerous. Might be a easy cop out because a manual would have walked over the 5lt's easier:P. I miss that clutch a bit I think there was a place in QLD that converted them too a 6 speed manual same as the holden and ford 6 speed. I've been really shocked of late at how easy they are too gain power from. I want that engine in my car But I'm having trouble getting help no-one seems too want too do the work even my mate at a wreckers thinks it's too hard too do. I don't see it as impossible. Get the engine install it, See a Auto elec wire it up too the ECU with a VS engine loom few extra sensors here and there from a VS. Then have the dual cats fitted too my current Exhaust system. Then tune it. I got guys telling me i need a tranny for it i'm going too slap them there the same trannys:P Just my isn't electronically controlled which is a bonus. It's not easy but it's no where near impossible and i'm passiont i'll let the engine sit in the shed till i have everything ready. Be worth it in the long run.
05-11-2006, 02:02 AM | #16 | ||
The problem with modifications though Slick is that a lot of people see it as bang for your buck.
The way I have understood it is that with S/C car you're limited to pulley ratios (have no idea what they are BTW) but with turbos the limits of tuning are endless, hence why I reckon that if the XU6 was turbo it would of really been the new VLT. |
05-11-2006, 02:08 AM | #17 | |||
05-11-2006, 02:25 AM | #18 | ||
It does launch bloody hard
05-11-2006, 02:25 AM | #19 | |||
I can live with it as I bought a car short gearing (bloody thing revs out so quick I've hit boost cut a few times) but sometimes wish I could grab an extra gear whilst crusing. |
05-11-2006, 02:38 AM | #20 | |||
I think 15-20psi is about it's limit, There is one lucky guy with a VN Calais with one that pumps out about 260rwkw. Good for 11's, But that's about it really as you said there limited:(. I love the boost of a turbo nothing feels as good. But i would be happy with about 170-200rwkw. The more power i have the smoother i drive and i get better fuel economy.
05-11-2006, 02:47 AM | #21 | ||
Churches Eat Souls
The L67 supercharged Ecotec engines are surprisingly good. Not a huge peak power output, but lots of torque everywhere in the rev range. Makes the old 5.0litre seem pointless (except for noise).
05-11-2006, 02:49 AM | #22 | |||
05-11-2006, 05:33 AM | #23 | ||||
05-11-2006, 10:38 AM | #24 | ||
I own both a BA xr6 and a VT Calais Supercharged and regardless of all the specs the BA is my first choice to jump in and go for a drive, but i must add the torque on the VT is huge and if had to tow definately the holden would pull a heavy load also wouldn't take much to get the VT going hard with a change of pulley and a few little mods.
05-11-2006, 06:33 PM | #25 | |||
This was Wheels or Motor, when the BA range was new. |
05-11-2006, 07:33 PM | #26 | ||||
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
05-11-2006, 07:36 PM | #27 | ||
Last warning
factory forced induction wins.
they may be slow from the factory, but with mods they can seriously move. i think theres a few 12 second ones on factory superchargers. probably quicker too.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
05-11-2006, 08:26 PM | #28 | |||
05-11-2006, 08:32 PM | #29 | ||
the supercharged V6's were made for better towing, not really performance, after all it is a statesman, not a SS.
05-11-2006, 08:45 PM | #30 | |||
