Just wondering what the power output on the VCT and HP are standard, cause im looking for at buying a AU but i want a VCT and some ppl are just saying 172kW and i dont know if thats the VCT or HP engine
Uterus M.I.A.
thats the vct
#3 | |||
VCT Power : 172kW @ 5000rpm Torque : 374Nm @ 3500rpm HP Power : 164kW @ 5000rpm Torque : 366Nm @ 3150-3500rpm |
XB in parts...
164kw normal (HP)
172kw VCT ....beat me to listing the figures. At this stage the non VCT car is the easier to mod in so far as getting cams etc to work. This may soon change if we get the AU edit.
Daily Driver 2019 Ford Escape...looking for XR6T's. Last edited by loxxr6; 31-03-2005 at 11:56 PM. |
Walking with God
Pardon my ignorance fellas, but what does HP stand for? I know VCT is variable cam timing.
Also what are the main technical differences between the HP and VCT? Is it basically just the variable timing gear or other goodies as well? George |
Smile
hp= high performance
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
have you seen my marbles?
yet the VCT has more KW..
how does that work?
comfortably numb... |
Smile
The vct cam has simliar lift to the hp au cam.However the variable cam timing can retard and advance cam timing to creat more power.Also consider that they put out from memory less rwkws than fwkws
Get in the ring!!!
Well I assume Ford wanted to use the VCT as a major selling point, hence 'VCT', and compared to the standard Intech 6, the XR6 HP is indeed 'high performance'.
Useless what do you mean less rwkw than fwkw? Me confused
FG MKII XR6T - Tuned by Pit Lane |
_Oo===oO_
Open up the bonnet and you will clearly see which car is which. The VCT head is labelled accordingly and has diagonal polished stripes across the top.
#11 | |||
![]() Join Date: Dec 2004
#12 | ||
The 'Stihl' Man
![]() Join Date: Jan 2005
I can tell you for a fact that the HP had to be toned down to make the VCT look superior. Not taking anything away from the VCT, but the HP is not a bad thing either.
#13 | |||
#14 | |||
The 'Stihl' Man
Its all histroy now, and both cars a quite capable of more, but without touching the ecu, which is one of the more expensive mods; the HP is not a bad thing.
#15 | |||
Somehow I find it hard to believe that the HP was only good for 164kw. I know the VCT was certainly good for a lot more than 172kw.
#16 | ||
bit OT but what are the differences between series 1 and series 2 xr6's cause if found i can get a series 2 bodykit on a series 1 but what (if any) are the mechanical changes?
#17 | |||
Umm it's not like the 185kW was as hard as the 5L could go either...
The power figures are always a reflection of their economical balance at the time of design and manufacture.
#18 | |||
Off the production line, based on the parts they had, they were starting to top out. The I6 had, on average, more "in reserve" potential than the V8 had in as a factory production run engine. Id say this was as much to do with the impending death of the 5.0l as anything though. I'm sure Ford would have loved to not have had to produce the 200, 220 and 250kw V8 Windsors.
#19 | |||
335 kw of goodness
CAUTION! STILL Contain's opinion's & fact's that may offend !!! ![]() 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
#20 | |||
#21 | |||
Walking with God
Righto, all have 9.65:1. Power figures are quoted as. 157kw HO164 VCT168 XR6 VCT172 This sound about right everyone. I wonder what the figures were in the real world and how much difference could be seen between say 5 VCTs or 5 HOs. Anyone have an idea? Here's something though, no mention of HP high performance, just HO high output. These are the same yeah? Last edited by GK; 01-04-2005 at 07:37 PM. |
#22 | ||
I suspect the AU1 VCT head had closer to a 9.30:1 compression ratio. This was fixed in the AU2 and 3 VCTs. I think it was a design fault in the head. Turns out that most AU2/3 VCT's have more power than the AU1 VCT due to this. This has been proved consistantly with dyno runs showing the later VCT's with more power.
#23 | ||
so if the vct can be fiddled to produce more power what are the pro's and con's
just curious as i kepp hearing differant things and thats why i havnt done much to mine YET
18 T6 Multivan 03 Ba Xr turbo 300rwkw |
#24 | ||
The VCT responds exceptiopnally well to a chip of some kind, be it unichip or chiptorque. Even better with a decent exhaust and intake. No cons at all.
#25 | |||
_Oo===oO_
I'm of the opinion that the 164 kW and 172 kW were the figures that Ford used as the minimum 'official' outputs, my hunch is that some of the production XR6's were actually putting out a bit more than that. There is definitely going to be some variation in ouputs across all the cars, being typically mass produced.
#26 | ||
Walking with God
Ok, thanks for clearing that one up.
#27 | |||
Built Ford Tough
Of two, Herrod picked the HP version to kit up for Targa duty. Darryl Coon did likewise for racing in Australian Production Car. HP's are lighter (no IRS) and make a better track weapon (hell, V8 Supercars still run live axles...) but that IRS was a very nice piece of gear on the road.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
#28 | ||||
All I'm saying is that the VCT is also a very good engine and, combined with the IRS and a few little luxuries, makes for an excellent daily driver. It can also go a lot harder than many people thought it could for what is a relativly small amount of money. I'm afraid the VCT is far less of a "grandpa's XR6" than many people would have thought a few years ago.
#29 | ||
Smash the Boost
is it true the VCT though likes to drink a little more juice than the HP motor?
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
#30 | ||
Get in the ring!!!
Casper do you know of any dyno results with pacemaker 4499's on the XR6 VCT? My dad has one with those extractors, K&N filter, and XR8 intake, we were wondering what his next mod should be, should he change extractors, or perhaps fit a chiptorque, or unichip chip?
