Old 25-01-2006, 05:39 PM   #1
'63Deluxe
Irregular Member
'63Deluxe's Avatar
Default Quality construction - Guess the make
Look what just happened to my radiator! It just fell apart, lucky I wasn't driving or out in the sticks. It's boody made of plastic, are all new cars like this?
The car only just clicked over 40,000km- ИИИ peice of rubbish. AAAARRRH
The tilt tray is on the way
'63Deluxe is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 05:54 PM   #2
NZ
NZ's Avatar
cars have had plastic side tanks for years now.
Old 25-01-2006, 06:07 PM   #3
toby123
Boosted TQE FTW
hmmm... late model commy?
Daily Driver: 08' ford ranger
Project: EF Falcon Turbo... Not long till back on the road.....
toby123 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 06:17 PM   #4
EL_futuraistic
EL_futuraistic's Avatar
looks like a late model commodore... vx/vy. I have broken a radiator tank in the same way removing the radiator hose as it was on FT.
Is that covered under warranty??
EL_futuraistic is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 06:47 PM   #5
'63Deluxe
Irregular Member
'63Deluxe's Avatar
Angry
VY II ute.
and I have told them it's under warranty
things fixed so far
Paint work covered in dull spots within 2 weeks
Holden hard lid needed adjustment so it would actually lock
New Diff - at 11000 km, clunky coasting along
drive axel fell out whilst driving - nice and noisy also made the ABS go beserkried to stop
and now the radiator
Old 25-01-2006, 10:40 PM   #6
16wantsI6
iRegular crossmember
16wantsI6's Avatar
Lemon!!
1996 EF XR6
5 spd manual
2 1/2" manta S/S exhaust
After market alpine/soundstream stereo
18" tyhpoons
superlows waiting to go in....
spoilerless
16wantsI6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2006, 11:30 PM   #7
gmhdriver
gmhdriver's Avatar
Pretty much all new cars these days have radiators with plastic tanks, and have had since about the late 80's. I don't see any real benefit in it, apart from lighter weight and possible cheaper production costs.
While the car manufacturers can be blamed to a certain extent, what it all comes down to is the production quality of the third party suppliers.
Both Holden and Ford source many compontents from the same suppliers and correct me if I'm wrong, I think radiators is one of them (from Calsonic?), meaning that Falcons aren't exempt from these sorts of problems either.
Same with the noisy diff - It is common knowledge that both Falcons and Commodores have dodgy diffs (moreso in the Falcons for some reason) as they sourced from the same supplier (Dana). I suspect this is the main reason for Holden dumping Dana as their diff supplier and contracting ZF to supply units for the VE.
gmhdriver is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 12:29 AM   #8
apolloxbgt
cross breeder
apolloxbgt's Avatar
Ea's where the first ford with a plastic radiator,and mabey vr on commies?It is fairly common,I cracked a tank n my eb xr8 when it was 8yo,wasn't even trying,and I live in the sticks! :
apolloxbgt is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 03:25 PM   #9
gmhdriver
gmhdriver's Avatar
VN V6's were the first with plastic radiators I believe, while the VT V8 was the first V8 model to have a plastic radiator.
Old 26-01-2006, 04:05 PM   #10
ltd
Force Fed Fords
ltd's Avatar
That radiator hose clamp looks like it is overtightened. Thing with plastic tanks is if you overtighten the hose clamp, you can actually crack the outlet flange which will allow vibration and normal use to accentuate the damage. Had the same thing on a DA. Radiator guy showed me the broken off part had been cracked for a while, and was cause by overtightening. Good news is though, they are not that expensive to fix.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2006, 04:56 PM   #11
svo347
AFF's 1st DM.......
svo347's Avatar
Originally Posted by 16wantsI6
Lemon!!
Maybe so mate but fords do it also.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 26-01-2006, 05:37 PM   #12
gmhdriver
gmhdriver's Avatar
I have to agree with you there, I didn't really take notice the first time, but looking at the pic again I can tell the clamp is severely overtightened just by looking at it.
Old 26-01-2006, 10:55 PM   #13
ltd
Force Fed Fords
ltd's Avatar
You're right there too. I have had some radiator issues with a couple of our cars but luckily Ford fixed them before I even knew or there was a problem. Also, with the Diffs, I was speaking to a service manager who said that they tend to have alot of problems with them on the V8's due to the overwhelming amount of torque. This wasn't a problem on AU's but is becoming quite a problem on BA's. Who knows, even Ford might do what Holden are doing and get them from somebody else.
Powered by GE
Old 26-01-2006, 10:58 PM   #14
ltd
Force Fed Fords
ltd's Avatar
Maybe an apprehensive apprentice not willing to get into trouble for overtightening, or amoulding fault. Either way, Ford have had their fair share of problems with suppliers' quality too; so Holden don't own the license to inconsistent parts suppliers.
Powered by GE
