Old 12-12-2005, 03:22 PM   #1
GT-E
GT-E's Avatar
Default Removing BA Factory SatNav
Hi,
I am upgrading to a BF Typhoon and would like to remove the Factory Satnav from my current BA XR6T.
I have heard many conflicting stories on if this is possible.
I am hoping you may be able to let me know if it is possible and what will I need to remove.
I know there is the DVD unit and receiver in the boot/parcel shelf and the remote, but I am unsure whatelse I need to remove.
I would prefer you guys to do it, but I am Sydney based
Thanks
GT-E is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2005, 03:56 PM   #2
FADI75
Sponsor
It is possible. The only problem is when you originally purchased your car the loom to the ICC came with the SATNAV audio pins. If you option your BF without SATNAV the pins will not be there and you will get no audio unless you tap into your AUX plug(not desirable). We can add them to your new unit if you want.
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2005, 12:01 AM   #3
GT-E
GT-E's Avatar
Fadi,
Thanks for the reply.
I am planning to come to Melbourne for an Edit Tune early in the new year, so I guess I schedule a trip to your place to get the audio working by the experts.
What I need to know is what else needs to be removed from the car, so far I know I need to remover the : DVD palyer and sat ariel and remote, is there anything else I need to remove ?
I do not want to remove 80% only to find out I cannot get it working.
Also if I put all the gear into the BF, will it work less the audio ?
I do not want to play with the ICC so I will leave that up to you.
I will also get a Parrot Carkit at the same time.
Thanks
Old 15-12-2005, 11:05 AM   #4
FADI75
Sponsor
Originally Posted by ZapXR6T
Fadi,
Thanks
Hi again
Although we are familiar with the satnav we are only really familiar with the ones we have installed and not the factory installs. From our experience as BA audio technicians we know that these systems use a speed wire(behind dash) and tap into the factory head unit for audio. Other than this we do not want to supply you incorrect information that you will be able to remove the satnav and reinstall correctly in your new BF. Wiring may be integrated with the factory loom and Batt, Ign, Reverse, speed sensor, audio and GND wires would need to be identified. If you believe you can attempt this and you can rewire correctly the only problem I see is the audio which we can fix at our end as long as you have identified the wires.
cheers
fadi75
