29-11-2005, 11:26 PM | #1 | |||
Sublime
ok, ive seen this on a couple of forums now, and i dont think a conclusion has been reached for this little problem........
29-11-2005, 11:28 PM | #2 | ||
No. the plane won't take off. it's just like you being on a treadmill you are not moving but your legs are. in a planes perspectivr it would be your wheels if the plane isn't moving the wind can't lift it
29-11-2005, 11:33 PM | #3 | ||
The one and only
No it can't.
It needs speed relative to the world not the ground! It'll probbly run very hot and blow up!!
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
29-11-2005, 11:35 PM | #4 | ||
No... The planes wheels will be rolling at(pluck a figure out of my butt)100mph but there would be no air flow over the wings... Without the airflow, you lose the pressure differential required to generate lift.
29-11-2005, 11:41 PM | #5 | ||
Bluepower enhanced GT
Confusious asks - Does your car Drive you from A to B when your on the Dyno????
Wheres Newton when you need him - Id say No - the plane would not fly.... |
29-11-2005, 11:42 PM | #6 | ||
damn! your right, i must have fallen asleep during that part of physics ;
29-11-2005, 11:43 PM | #7 | ||
who cares
29-11-2005, 11:49 PM | #8 | ||
It will take off.. A plane uses air for displacement to move forward. The wheels of it would just be spinning like crazy tho...
29-11-2005, 11:49 PM | #9 | ||||
29-11-2005, 11:51 PM | #10 | ||
the air craft won't be stationary. it's propelling itself by the wind
29-11-2005, 11:52 PM | #11 | ||
the air craft won't be stationary. it's propelling itself by the air
29-11-2005, 11:59 PM | #12 | ||
Two > One
the aircraft will take off.
IF the aircraft used its wheels to provide thrust then no it wouldn't. Seing it uses air displacment then yes it will take off. The aircrafts wheels will be turning at 2x the speed of the aircraft relitave to the air.
30-11-2005, 12:05 AM | #13 | ||
My Call = NO
It would not matter how fast / slow the tread mill / plane was going i could stand in front of the wing ( away from the jet ) and there would be no further air rushing past me than there would be if the plane was stationary, it would need the air travelling over the wings to create a lower pressure on top of the wing to lift it off the ground and it wouldnt be there. |
30-11-2005, 12:06 AM | #14 | ||
Has Blue Blood
the plane will take off as the wheels dont have any effect on the plane momentum other than to keep it off the ground by being a very low friction point of contact when the plane is not flying !
Real cars dont wear bowties I'm not arrogent , Just superior
30-11-2005, 12:06 AM | #15 | ||
Zoom Zoom
If the conveyor can track the plane's speed on a moving road, it would track that of the plane and not the wheels. Regardless of wheel speed, if it is on a moving road/conveyor, the plane's fuselage speed is always going to be zero relative to the stationary environment around it, thus the conveyor itself will never move if dependent upon the fuselage speed.
Moral of the story, the conveyor will never move, nor will the plane. OR It will take off at regular speed with the wheels spinning twice as fast as normal ground speed. I'm leaning more toward the second one... can't decide.
2012 Mazda3 MPS
30-11-2005, 12:07 AM | #16 | ||
It isnt moving - stationary in the sense it is not shifting a cm from its starting point because of the conveyors equal travel speed in the reverse direction. Surely even with air displacement you would need extra force to fight gravity - hence the flap direction changes on the wings etc during takeoff to maximise this air change against the plane and under the body of the plane to get it off the ground...
This is one for the Myth Busters - not me..... |
30-11-2005, 12:09 AM | #17 | ||
Hmmm Gold!!!
No it wont take off, there is no pressure difference over the top of the wind and below it. yes there is air passing thru the engines but there is nothing near the wings.
If the engines blew the air over the wings then yes it is a posibility
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
30-11-2005, 12:12 AM | #18 | ||
windsor user
someone go get a plane and put it on a treadmill
30-11-2005, 12:18 AM | #19 | ||
Ok guys.....
Conveyor in opposite direction. Aircraft (for sake of fact rather than hypothesis) Cessna C172R Nil wind, nil gradient, standard friction surface. Throttle applied, aircraft accellerates to, say, 30 kts indicated air speed. Conveyor senses 30kts and applies 30kts in opposite direction which has negligable effect on aircraft other than spin wheels at 60 kts. Conveyor notices that aircraft is still going 30kts so increases its speed to 90 kts compensate. Conveyor notices that aircraft is still going 30kts so increases its speed to 120 kts compensate. During this time aircraft is still accellerating.... This continues to happen until: a) The aircraft accellerates faster than the conveyor can compenstate and reaches 60kts IAS before the wheels rip off due to friction. Aircraft rotates and commits aviation. b) The aircraft accellerates at the same speed that the conveyor can compensate and either the conveyor blows up or the gear collapses as they would be doing infinity kts. (actually this would happen immediately because as soon as the aircraft moved the conveyor would constantly increase speed because it has no effect on IAS). Conveyer in same direction. Aircraft accellerates to 60kts IAS, rotates and pilot is happy as there in no wear on landing gear as it is not moving. Wheels on aircraft are just there to reduce friction, some come with skis or floats.... Capt Flappist ARN 540335 (guess where my name came from) |
30-11-2005, 12:19 AM | #20 | |||
Zoom Zoom
2012 Mazda3 MPS
30-11-2005, 12:28 AM | #21 | |||
30-11-2005, 12:29 AM | #22 | ||
Looking for clues...
The aircraft is in contact with the conveyor belt. Any forward motion attempted by the aircraft to get up to speed is NEGATED by the conveyor belt.
Therefore, no actual movement of the aircraft, so no airflow over the wings. The aircraft will sit there, engines going redline, till there's a theoretical meltdown, and then the conveyor belt will slow down... |
30-11-2005, 12:32 AM | #23 | ||
if it was a harrier jet ( S ) it could take off.
30-11-2005, 12:32 AM | #24 | ||
Bolt Nerd
Ohhhhhh F**K... zetec... surely ONLY a bent Maribyrnongnite could come up with that.........You ARE a nut! (Photo shop lessons to the right)
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4 Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD 2 wheels.. 2015 103ci HD Wideglide.. SOLD SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida! (Ex Blood Orange #023 FPV Pursuit owner : ) |
30-11-2005, 12:41 AM | #25 | ||
I'm with others here, how the hell can the plane lift off with no foreward movement, whereby air speed is needed to create the pressure differences on the top and bottom of the wings which lift it up? If you're not moving through the air, it will be like standing still with zero air speed!
30-11-2005, 12:42 AM | #26 | ||
Zoom Zoom
2012 Mazda3 MPS
30-11-2005, 12:55 AM | #27 | |||
Bolt Nerd
To a "layman" like me... The thrust, wheelspeed, AND LACK of forward underwing air pressure is made perfectly obvious now!... (how many people are on the plane BTW?)
30-11-2005, 01:07 AM | #28 | ||
It's an impressive read, but I can't buy it. He says it's all about air speed, but this plane doesn't seem to get any, the way I see it.
30-11-2005, 01:20 AM | #29 | ||
Zoom Zoom
Put it this way. Imagine running on a treadmill, the faster it goes, the faster you run, you still go nowehere. That's like a car on a treadmill.
Imagine you running but you're holding onto a rope tied to a wall in front of you. No matter how fast you're running, all you have to do it pull the rope and you'll move forward off the treadmil as fast as you pull your arms. This is like a plane. It get's it's propulsion by pushing the air through the engines regardless of how fast the wheels are going. Therefore, even with the wheels spinning at 300km/h on the dyno, increasing the thrust of the engines will simply roll it forward as per normal like nothing has happened. The only strange thing is when it rolls off the dyno, onto solid ground, it'll be doing a 300km/h burnout under momentum of the wheels and might slightly lurch forward a metre until the wheels grip and return almost instantly to airplane speed. Makes sense to me.
2012 Mazda3 MPS
30-11-2005, 04:17 AM | #30 | ||
In the Forced 'lane
I agree with everyone who thinks it WILL take off.
It's a plane not a car it doesn't use the wheels to accelerate it uses thrust, air, gasses to push it forwards, the conveyor can be travelling as fast as it wants in the other direction the thrust will still be pushing the plane forward. The only way you could prevent it from taking off would be a huge fan moving the air in the opposite direction matching the engines thrust. wheel speed has nothing to do with it.
XE S-Pack 4 Runner XH11 Longreach |
