Old 28-11-2005, 03:48 AM   #1
rally escort
Default 2lt escort
whats the go with puttin a 5 speed gears box in a 79 modle bc escort. has for speed manual at the moment with the rs2000 engine mild work done including shaved head, bored cylinders, balanced crank and rods. recent engine rebuild has done little to proformance what is the next step?
Old 03-12-2005, 09:16 PM   #2
T3man
T3man's Avatar
You've got lotsa choices for a 5-speed. If you want to keep your existing gear ratios but just add an overdrive the Sierra box is your go. But if you want to get closer ratios through the intermediate gears you can go for a Celica steel case or a Supra alloy case. Conversion kits are readily available from people like Jeff Dellow Automotive in Sydney.
Old 03-12-2005, 09:22 PM   #3
V8falcons
V8falcons's Avatar
the sierra box will be the cheaper option but unless you change your diff ratio it will do nothing for performance as 5th is just an overdrive,the problem with the celica/supra box's is the set up cost and the power loss through its gear train.
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2005, 11:15 AM   #4
T3man
T3man's Avatar
Sierra boxes must be cheaper these days ... when I did mine the Toyota conversions were the way cheaper option. I don't know how you figure there is any more power loss through the geartrain ... they do have slightly stronger gearsets but not that you'd notice when driving I wouldn't think. And to counter that, if you used the alloy case you would save about 10kg weight over the Sierra box I think.
Old 05-01-2006, 01:11 PM   #5
bad_mk1_escort
eskie freek
bad_mk1_escort's Avatar
yeh u can pick up serria boxes for about $500 now if ya can find 1 tho they are hard to get over here at the moment so look hard if ya want 1
black mk1 on goin project/ toy
94 ef xr8
toyota 60 series project with 6inch lift and 35z
Xd sedan project for sale
mk1 4 door project car for sale
Mk2 4door 1.6lt for sale
bad_mk1_escort is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 09:28 AM   #6
whooligan
whooligan's Avatar
If you just want to drop the revs on the freeway, the sierra box is the way to go. You can pick them up from $300-$450. Anymore than that and you'd want some sort of warrantee. If you want performance stick with the 4-speed. You can get performance geИИИИts from the uk and the quicker you can get into top the better. The celica/supra conversions vary from really good to basically a truck gearbox. I've driven an early one in a 1600 Capri and it was a dog, and I recently drove a Mk 1 Escort with a 2lt and Supra 5spd and it was brilliant. I'm fitting this box to my Capri. Do some research before you spend you money.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 04:41 PM   #7
5L
[ 5L ]
5L's Avatar
i think that the escorts gearing is perfect as it is, they only need an overdrive, for contsant speed driving or highway driving, as they rev fairly high sitting a 60km/h
www.ignitionimages.com
