Stingray
Old 13-11-2005, 11:31 AM   #1
Melz
Melz's Avatar
Default Drag Racing an Escort
Hey guys, what engine would you suggest i run in a purpose built 2 door escort? Taking into consideration that i am only still learning the 'art' of drag racing and that I would prefer to learn how to build up the motor also.
Suggestion on driveline also would be appreciated!!!
Melz
PS. Working on a very tight budget so no suggestions on $15000 crate motors!!!! Thankyou
Originally Posted by Jeremy Clarkson
“The Americans lecture the world on democracy and then won’t let me turn the traction control off!”
Melz is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 11:44 AM   #2
Bossxr8
Peter Car
Bossxr8's Avatar
The biggest engine that will fit. I've seen Escorts with 351 Clevelands, but I don't know how much work needs to be done to fit them. Personally I would put a 351 Windsor stroked out to 427. Big Block cubes in a small block with a suitable auto, depending on how much power you have. A C4 auto would be OK for say 500hp but a C6 will handle more.
Old 13-11-2005, 12:41 PM   #3
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
It depends what you want out of it, 302 V8 is a common conversion, but it's not really a beginners setup, are you looking to stay 4 cylinder like a worked 2 litre or go for something bigger ? i recall Brenx built a pretty serious escort engine years ago, maybe see what he thinks.
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 01:00 PM   #4
LTDHO
The one and only
LTDHO's Avatar
How fast do you want to go?
How much money do you want to spend?
What class do you want to race in?
I'd fit a 351C mild or wild.
Mild i'd run C4 shift kit with appropiate stally.
Wild i'd run Powerglide " " " " " "
9" diff with gears to suit tyres and engine combo.
Tuned by CVE Performance
Old 13-11-2005, 06:20 PM   #5
Gauntster
What bracket do want to run in?
Establish this and your budget and you should be headed in the right direction.
Once you know the bracket check out some of the cars in this bracket to see whether or not it is appropriate for your budget. If your like everyone else then you want to be competitive and win one or two as well as compete all year round then the bracket/budget thing goes hand in hand.
I would think that striped down and set up mk1 escy with the appropriate running gear and a 302 based block 400-500 hp running in either Super Gas, Super Sedan or maybe even Super Stock(modified) would be a goog starting point.
Hope this might give you something to research and think about to get you on your way to "quarter mile mania".
Go get em tiger!
Gauntster is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 07:17 PM   #6
Racecraft
they call me Tibbo
Racecraft's Avatar
myself, I'd go for a imported front cut and whack on a nice turbo
Old 13-11-2005, 07:21 PM   #7
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
sr20det. lotsa boost.
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 07:43 PM   #8
aimzes
...fairly odd
aimzes's Avatar
i think this would be the way to go. btw ive seen an article on a Mk1 corty with a 460... so i guess one of them would fit in an escort lol...
1992 EB Falcon 5.0 V8. mods; dust, dirt, cobwebs, scratches, trolley dents, dented bonnet, gutter scrapes, rattly exhaust, and floor mats.
aimzes is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 08:12 PM   #9
302donk
302donk's Avatar
if it was me i would build a nice
450 to 500hp windsor
a c4 3 speed trans(built by hugos race glides of course)
standard running gear up back as in 9 inch
and would run super gas as its not hard to go 9.90 in a car that weights as light as an escort would
302donk is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 08:16 PM   #10
xdclevo
The Fun Mobile
xdclevo's Avatar
If you want to run 12s, put in a new mild 351 and it will be easy if the driveline is set up properly in regards to stall converotor and diff gears. Work out if you want naturally asperated or a forced indcution 6 or 8. A nice naturally aspirated 351 cleveland or Windsor would be a good economical choice, depending on what fit the easiest.
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 08:23 PM   #11
Perana
Perana's Avatar
Id go a wheezer... 302 would fit the easiest but would still need a bit of panel work to fit. 351w stroked to 427+ would go very well in a light escort body
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 09:22 PM   #12
naughts
Hmmmmm Mulberry....
naughts's Avatar
289 Windsor
Good fit and lots of revs!!!!!
there is one down my way that runs 12's
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 10:27 PM   #13
ebxr8240
Performance moderator
ebxr8240's Avatar
Drag only car ???
Id go SOHC 4.0 , turbo and auto...The drive shaft won't be vary long...
Shortened Cortina diff or Toyota Hi ace etc ??
If a std E series can run mid 11's with turbo on std engine then I assume 9's would be achievable with traction and good kook up...Abviously the firewall will need to be fabriacted to accept the engine's back 2 or 3 cylinders...
Daily driver GTE FG..
Old 13-11-2005, 10:42 PM   #14
12
Silhouette AU1 TS50.
12's Avatar
Have a look here. Good starting point I reckon.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 11:48 PM   #15
Falcon Coupe
Clevo Mafia Inc.
Hmmmmm does :
out the rear end a bright pink chute is fitted for those passes above 140MPH.
sound like a good car for learning in ? we don't want anyone to get hurt.
Old 14-11-2005, 12:12 AM   #16
INJECTED_250
Custom user title
INJECTED_250's Avatar
i would build up a turbo pinto motor..... prety easy to do.... keeping it in the ford family and would run fairly good times, and not be to hard to control
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 12:34 AM   #17
12
12's Avatar
Originally Posted by Falcon Coupe
Hmmmmm does : sound like a good car for learning in ? we don't want anyone to get hurt.
The car is being sold with no engine, so I doubt it would reach 140 MP/H yet alone 4 MP/H.
How fast can ya run Melz? You could try to get to 140 MP/H Flinstones style. Because that's the only way this Escort would reach 140 MP/H in it's current state.
I posted the link because I thought Melz could be interested in a already prep'd purpose built drag Escort (minus the engine and gearbox.. (if Melz didn't already have one that is)), and Melz could decide on the engine/gearbox combo for herself. But instead, I get accused of trying to hurt people. :yeees:
PIC'S OF MY
T1 TS50.
Old 14-11-2005, 02:25 PM   #18
Falcon Coupe
Clevo Mafia Inc.
I Didn't go through all the pics, just read easy sub 10 second car etc... :
Old 14-11-2005, 04:09 PM   #19
JG3282
Awake after dark
JG3282's Avatar
The first thing you have to do is rule out a six. the Escort engine bay is not very long, therefore to run a six it would mean cutting out and removing the firewall and radiator support panel. The next question is, do you want to stick with a caveman style v8 with holley carby, edelbrock manifold, powerglide, nine inch and 4.11's (the same as every other tom, dick & harry) or do you want to be progressive. There's a guy called Peter in the RS Owners Club who has a 2.0 litre Zetec in an Esky that flies. I can help you get in touch with him. Something like that, plus weight reduction, hilux or VL turbo diff, a reasonable sized turbo and dry ice intercooler setup would be my suggestion. There's a guy in Ballarat, Andy from Specialised Power Porting who would be a good bloke to speak to about this or Rod at Motorvator Race Engines in Bendigo.
Or you could read my signature and give Frankie a call, tell him I sent ya.
Every time I learn something new, it pushes some old stuff out of my brain
His Car: XE Fairmont Ghia - For Sale Here
Her Car: ED Fairmont - Lowered, Pioneer stereo, Sony XPlod speakers, Big Exhaust & more
JG3282 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 04:14 PM   #20
JG3282
Awake after dark
JG3282's Avatar
Mate that is the funniest avatar I've ever seen :
Old 14-11-2005, 05:56 PM   #21
XRQTOR
XRQTOR's Avatar
There was a little two door escort at supernats yeasterday with a blown 351 in it, dam did that thing have some balls. If you have ever seen the forza HR do a burnout this little green machine had it well and truly covered.
Old 14-11-2005, 06:37 PM   #22
jd dad
302 Windsor for mine as a Cleveland is a pretty neat fit into anything small unless you`ve got good fabrication skills. As you are only learning a 450-500 hp motor for mine is plain silly. Start with a mild combo that is easily upgraded to get you used to it. A small car with a big hp engine can be fairly interesting to drive even when you are used to them let alone starting out.
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo
jd dad is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 07:10 PM   #23
blo666
the white one is nice i think i read some thing about 600+ i could be wrong
Supercharge forsale for ef 9psi powerdyne the hole kit $3600
blo666 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 07:42 PM   #24
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
Yeah, a turbo EFI pinto would be pretty good and quick, something like this:
That's what I'd do personally, although there are so many options available, N/A or turbo 4, V6, V8.... As cool as a I6 would be, given the size of an Escort engine bay, it would probably be more trouble then it's worth, in my opinion.
The other advantage with going for a setup like that above is that you could do it in stages, start off with a 2 door Escort with a bog standard 2L OHC "Pinto" engine, get a good feel for how different it is to a Falcon engine (this might seem like it's obvious, but believe me, there is a whole world of difference), then source the EFI setup and get it fitted, etc.
The other great thing is that it's not too hard to source replacement diffs, and bolting in a 3.77:1 diff from a "kent" powered Escort (pretty much anything with a 1.6L or smaller engine really, also the kent engines are not OHC, but OHV, just like the 6's in all Falcons before the EA), or even a 4.11:1 if you can find one out of an Escort panelvan (was an option for them), it will make a pretty big difference, although once you start putting a reasonable amount of power through it, don't expect it to last too long, they do cope suprisingly well if you treat them with some respect if the engine isn't making heaps more power then stock - 5000rpm clutch dumps will destroy a stock Escort diff pretty quickly, but more sensible launches will see it last a lot longer then you might expect.
When it comes to transmission, there are many options, and to a certain extent this will depend on what powerplant you choose to go for. A stock 4 speed is cheap and reasonably effective, although the gear ratios aren't the greatest. You can put in a sierra 5 speed box fairly easily, with the only real difference being the overdriven 5th gear, but even with a 4.11:1 diff, you may not need the 5th gear before the end of the standing 400m. Autos can be built up to handle some serious ooomph, ratios won't be as great as a manual, but it's easier to launch an auto consistantly. But there is also the option of transmissions such as a supra 5 speed, which could go on with some mods, and like I said above, if you choose to slot in something else as the powerplant, then the transmission choice will depend to a certain extent on which engine is powering it.
Hopefully that has been helpful I wish I still had my 2L Escort, I'd love to know what it would have ran down the 1/4... :
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2005, 07:44 PM   #25
The MaDDeSTMaN
Wouldn't suprise me, cosworth DOHC turbo, running heaps of boost can achieve that sort of power, even higher. Pity those engines are so damn expensive :(
Old 15-11-2005, 04:23 AM   #26
ebxr8240
ebxr8240's Avatar
As this is in drag section and the question was drag Escort.. The 4 cyl build up would be fairly expensive..But it depends on what you want?
Big lassy motors last and can be bought from wreckers and almost thrown in..But they need to be set back through firewall and some space framing done..
Years ago I fitted a 289 in a Mkl Escort...
Scanned it but not that clear...
Old 15-11-2005, 05:04 AM   #27
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
My brother has a T28 turbo and manifold for his Mk2 escort 2L which came off a
Mk2 panelvan which ran a 12.8 with a stock pinto and draw through carby.
I will hopefully be racing my 4 door Mk2 RS2000 at the next AFF drags.
It has a fairly worked pinto and twin 45s, it will be interesting to see how it goes.
XE S-Pack
4 Runner
XH11 Longreach
THORNSPAWN is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2005, 09:40 PM   #28
Melz
Melz's Avatar
Thanks for your suggestions guys. I'm still trying to nut out the different brackets, etc. for drag racing, and what i would like to run in.
My only thought was a N/A 289 with powerglide (obviously i haven't been able to sort out the full set up yet).
The brother-in-law was eyeing off a Holden 6... blah
Old 19-11-2005, 10:09 PM   #29
jd dad
Be more room with a Windsor than a str8 six. Saw a Capri with a pre crossflow 250 in it in a wreckers yard years ago and it looked like a ***** of a job to get it in there
Old 20-11-2005, 11:11 PM   #30
Gauntster
Hi Melz, you should get yourself a copy of the ANDRA drag racing rule book for 2005-2006 and you will find everything you need to know. Pretty sure they still cost $20.00, buy one at the next ANDRA meet or go onto the web site.
This should give you a good understanding of the brackets etc.
