buickman
While doing some seaches on spark plugs and several people are happy with the JMM autolites which I think are P/N 985. I found they suit the DodgeR/T Viper V10 mtr. Is the plug JMM uses that P/N if so that would be why it performs well. Plus I might get a set.
buickman |
![]() Join Date: Dec 2004
I dont think its just a matter of "it fits a viper so its going to be the best" otherwise we would all be using the same plugs they use in ferrari's. Its simple a matter of the temperature rating of the plug, the gap, the intensity of the spark, and alot of trial and error on jim mocks part.
And yes I believe it is the exact same plug they use in the Viper from Autolite.
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
I have them in mine, they work well enough. I would go as far as to say that they certainly havent caused any power loss thats for sure.
#4 | |||
buickman
The NGk iridium plugs have been in for about 70,000Kms in my VCT mtr & I was thinking of what to use next that is cheaper & works well on the mtr. My son tried the NGK iridium plugs on his VL turbo ran ok until he used the high low switch for boost it started to missfire, he change back to the normal NGK plugs & the miss was gone at boost so even though they ran fine in my 6 the iridium plugs must be not that suitable for turbo's. buickman |
#5 | |||
ive run NGK iridiums on my 6 and they worked very very well. Id probably argue that 100,000 from the plug is a bit optimistic but a decent product none the less.
Smile
Personally I had bought a set of ngk iridiums and my car went disgustingly slower .Then the new iridium NGK went straight into the garbage bin.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#7 | |||
buickman
So what plugs are you running buickman |
TL40 Wagon?
I am running the Autolite 985's they seem good but couldn't honestly tell any difference.
#9 | |||
horsepower
Okay just about to order the autolite plugs and the part listing i recieved was P/N :APP64 .
Is this correct as i believe it's a triple platinum spark plug for the au 6 ????? |
#11 | |||
TL40 Wagon?
They are OK they work I have an old set you can try if you want but I wouldn't stress about plugs too much just good stock plugs for an AUII will be fine. |
#12 | ||
champion rc12lyc are a replacement plug for autolite 985's so anyone used these? they are available at repco for $4.44 where as autolites cost $3.80x6+ $15 shipping from noelsautoparts. i can get for $4ea so should i get them?
and as far as leads go what are the best value for money that work well?
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
T3/Sprint8
![]() Join Date: Jan 2005
yep good plug autolites.
Leads comes into everything get what you pay for - budget brands top gun bosch eagle etc do the job fair prices.
