Go Back   Australian Ford Forums > The Sales Yard > Wanted Car bits and other general items
Wanted Car bits and other general items If you want it and it's not in the For Sale section, post it here
Old 27-04-2024, 06:04 PM   #1
BarryandSandra
Default ba 3v v8
someone in the ringwood vic area to run a check on my ecu as vehicle cranks no start and we have checked everything else. standard forscan diagnostics reveals no fault codes
BarryandSandra is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2024, 05:56 PM   #2
Fgute
Default Re: ba 3v v8
Are you able to check for volts across your injectors and coil packs?
Fgute is offline   Reply With Quote Multi-Quote with this Post
Old 29-04-2024, 06:08 PM   #3
T3rminator
T3rminator's Avatar
Check you haven't blown the coil fuse. It's in the fuse box inside car.
Rides (past and present)
Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual
Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m)
AFF motto - If contrary views trigger, please use ignore button.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
