Old 19-12-2023, 09:41 PM   #1
Minerva
Default 2002 LR Ford Focus gearbox oil change
So I was reading in the Haynes manual that my Focus fitted with the IB5 manual transmission doesn't have a a drain plug.
My question is how do I get most of the old oil out?
Will removing a driveshaft get most of the oil out or is there a better method
When dealing with this transmission?
Minerva is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2023, 08:22 AM   #2
Peter B - CV8
Default Re: 2002 LR Ford Focus gearbox oil change
Does it have a fill plug ? If so, maybe you can use a large syringe & some plastic tubing to remove the old oil.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2023, 09:28 PM   #3
Minerva
There's a fill plug. There's also a detent underneath the fill plug for the gear selector I thii
nk.
I've read others have used that plug to drain the gearbox but I have also heard others have damaged their gearbox using this method so I am a bit worried about draining via the detent.
Maybe I am better using some tubing then? I dunno.
