16-01-2023, 06:12 PM | #1 | ||
have major trouble trying to get a outside door handle and the reinforcement bracket that holds the door handle to the door for `02 focus.
ford said they are discontinued , tried wreckers locally, nothimg. seen on ebay this : https://www.ebay.com.au/itm/155327611073 it says front exterior , so does that mean the FRONT left and right outer door handles are the same. ? |
16-01-2023, 07:21 PM | #2 | ||
Outer door handle is the same for both RH and LH Front doors, part number 2M51A22404AAXWAA. The inner bracket how ever is different between each sides. The RHF is XS41A224A36BE.
Obsolete here, but you may have some luck with Google or eBay like the one below: https://abouttimespares.com.au/TimeS...(several-marks) Good luck, hope that helps. |
16-01-2023, 07:36 PM | #3 | |||
