Old 01-01-2023, 09:33 AM   #1
Chugalug
Question Ford Focus Head Light Adjustment
Have a 2010 Mk 2 focus - bought two after market head lights - installed new Navara globes - both units re fitted easily - using a 7 mm allan key - clockwise to rasie beam height but the LHF head light beam does not come up - ??? what am I not doing right ?
thanks
Chugalug is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2023, 06:43 PM   #2
Badcooky
Badcooky's Avatar
Default Re: Ford Focus Head Light Adjustment
Do you have the headlight height adjustment on the RH light switch/dial ?
Maybe that is messing with it ?Either that or the adjustment thread is stripped ?
The right HL adjusted yes ?
My height adjustment on the RH dial switch doesn't seem to work either .
This may be of no help at all though .
After some 06 to 10 XR5 Turbo 2nd hand go faster bits if anybody has some .
PM me if you do .
Cheers .
Badcooky is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2023, 09:50 AM   #3
Chugalug
Talking Re: Ford Focus Head Light Adjustment
Thanks, No this 2010 focus (south african assembly) does not have the dash adjuster. Go figure. These after market units have two white plastic hex 7 mm allen key adjusting points, one at the top, easy to get too, and one at the lower back hard to get to, where you need a 180 mm shaft that can take a 7 mm straiught shaft allen key to reach it. All the vidoes I watched said the top adjustment was height, NOT so on these units, top adjustment is left and right, bottom the hardest to get too is height. All fixed now - next project is a front light bar and on a all plastice front wont be easy - watched some vidoes where they take off the entire front plastic grille assembly. looks like a major job over a half day or more ?
Old 06-01-2023, 01:01 AM   #4
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
I've removed the front grille, bumper, driving light's etc off a 2011 Focus, take's about 15 min's
It's pretty much the same as removing the 2010 front end
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2023, 01:10 PM   #5
Badcooky
Badcooky's Avatar
You got it figured out all good.
I wonder if my top head light adjustment is the same as yours , I saw those videos too but I can't find my 7mm allen key , so for now it's academic .
PM me if you do .
Cheers .
