Old 26-06-2019, 06:41 PM   #1
LeadFoot81
_Oo===oO_
LeadFoot81's Avatar
Question AU3 XR8 Ute Won't Start (Intermittently)
Hey guys, I'm having an issue with my auto XR8 which occasionally refuses to start.
I turn the key to Accessories (all good) then turn to start and get nothing.
There's no specific circumstances which cause it (doesn't matter if it's hot or cold, just been driven or been sitting for a couple of weeks)
Every time this has happened I've kept tried a mixture of wriggling the steering wheel as well as moving the shifter from from P to N. Nothing obvious fixes it...I just keep turning the key off/on until it eventually starts.
The only out of the ordinary thing that has been happening recently; is that when I shift the box into a lower gear (3,2,1) it either won't do it, or after a while it'll decide to shift back to D irrespective of where the T-Bar is.
In terms of troubleshooting:
- I've checked that the relays are snug (switched them around and given them a light tap)
- Had a test light on the starter motor (when the key is turned, she lights up)
However - ironically, I haven't been able to reproduce the no-start scenario!
Any ideas on troubleshooting this greatly appreciated!
Cheers,
LeadFoot81 is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2019, 07:12 PM   #2
Default Re: AU3 XR8 Ute Won't Start (Intermittently)
Does it start easily and continue to run if you jump the starter relay terminals in the underbonnet fusebox? Good idea to have a helper standing on the brakes in this instance.
Citroënbender is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2019, 07:13 PM   #3
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Battery terminals tight?
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2019, 08:07 PM   #4
macman
macman's Avatar
I really would have suspected the inhibitor switch / neutral safety switch on the side of the auto trans, the white plastic module which tells the electronics which position the T-bar is in.
Perhaps take the module off (easy) and give it a clean and visual inspection.
If you have another AU (seems lots of us do, or have access to one), try swapping in another switch to quickly rule it out.
IMO you're experiencing the symptoms of a dud one.
macman is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2019, 09:00 PM   #5
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I agree
Old 26-06-2019, 09:32 PM   #6
BLU-220
FG XR50 TURBO
BLU-220's Avatar
This is what it looks like the white thing that is circled
BLU-220 is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2019, 10:24 PM   #7
LeadFoot81
_Oo===oO_
LeadFoot81's Avatar
Thanks guys, and thanks BLU-220 for the pic! Really appreciate it.
I'll have a look over the weekend and report back.
Old 27-06-2019, 01:34 AM   #8
snap0964
I'm assuming you get the brake warning light (!) every time start is selected whether it turns over or not?
Most likely you'll need to clean the inhibitor switch by the sounds of it - quick test you can do is pull the 4 pin white plug (see pic above),
use a paper clip or jumper wire, short plug terminals 57 & 34.
Refer http://fordforums.com.au/wsm/wire/aubx/Part%2024-3.html connector C12 Page 24-3-2.
Make sure trans is in park - try to start the car. If it starts, inhibitor s/w needs cleaning.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2019, 10:36 PM   #9
NCII40
XR6T BA 2002
NCII40's Avatar
Def Trans switch
No need to change
Just start it in N,
Works every time for me
Good security too
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2019, 08:19 PM   #10
LeadFoot81
_Oo===oO_
LeadFoot81's Avatar
Hi guys, late update but I ended up changing the Inhibitor Switch and so far so good!
I'd forgotten that the reverse light had stopped working as well (ute only really gets driven daylight hours) and that started working again with the new switch.
Thanks again for everyone's comments.
6 users like this post:
