Old 09-04-2019, 10:05 AM   #1
blownvn
Default AU XR6 timing light weirdness
So I was checking spark on our AU XR6 VCT and this weird issue revealed itself.
The car starts and idles fine, maybe not 100% smooth but pretty close. I put a timing light on the leads and it appears that cylinders 1, 2 and 3 are firing at approximately double the rate of cylinders 4,5 and 6.
I've changed the coil pack and it's still the same.
I've asked a couple ford mechanic and they agree its weird.
Has anyone come across this before?
Has anyone done this test on their AU?
blownvn is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2019, 01:52 PM   #2
blownvn
Default Re: AU XR6 timing light weirdness
Nobody with an AU has a timing light?
Old 10-04-2019, 02:06 PM   #3
Mechan1k
Mechan1k's Avatar
ECU on the fritz maybe?????
Been a long time since I mechanically mucked around with an AU though.
Old 10-04-2019, 09:09 PM   #4
blownvn
Yeah maybe. I'm not sure I want to buy another AU ECU seeing that I'm converting it to Barra ECU shortly.
Sent from my SM-G950F using Tapatalk
