View Poll Results: Has your zf heat exchanger failed? POST 2012 CARS ONLY | |||
No | 85 | 92.39% | |
Yes - cooling system serviced as per factory, using factory coolant | 6 | 6.52% | |
Yes - cooling system serviced as per factory using different coolant | 0 | 0% | |
Yes - cooling system not serviced | 1 | 1.09% | |
Voters: 92. You may not vote on this poll |
05-03-2017, 02:45 PM | #1 | ||
Rob
Given this topic keeps on coming up, with no real facts on how prolific it still is, or if it is at all, i thought i'd start a new poll for later model cars only.
This is for falcons and territories (petrol and diesel) manufactured after 2012 only! this is just a date i plucked out of thin air, but didn't want to exclude too many cars for fear the sample size would be too small and wouldn't provide much of a picture. If you vote, feel free to also update the thread with your car details and also add whether or not the cooling system has been maintained as per factory recommendations. Please DO NOT comment if you DO NOT have a car built after 2012. thanks Last edited by prydey; 05-03-2017 at 02:51 PM. |
05-03-2017, 03:25 PM | #2 | ||
So cars built from 01 Jan 2013?
2 users like this post: |
05-03-2017, 03:31 PM | #3 | ||
Rob
It was just a randomly plucked date. Its not a definitive cut off though, so if you have had a failure on a car built late 2012, then feel free to vote, but also comment to clarify the age of your car.
i kept the voting simple, but if all those who vote could also post a comment with their car details, then that would help to paint a clear picture. |
05-03-2017, 03:57 PM | #4 | ||
#neuteredlyfe
As stated here...
http://www.fordforums.com.au/showpos...84&postcount=1 FG MKII XR6. Mine did it at 40101ks and 18 months old. |
05-03-2017, 04:00 PM | #5 | |||
Rob
05-03-2017, 04:09 PM | #6 | ||
#neuteredlyfe
05-03-2017, 04:16 PM | #7 | ||
Rob
05-03-2017, 04:18 PM | #8 | ||
#neuteredlyfe
19 users like this post: |
05-03-2017, 06:41 PM | #9 | ||
What you should ask, is for those with an FG Mk2 or FGX that have failed, not 'POST 2012'
My Resume: Current: Alfa Romeo Giulia Quadrifoglio in Vulcano Black MY18 Black WRX STi Spec-R Previous: '16 White FGX XR8 '09 Black FG FPV GT 5th Anniversary '04 Blueprint BA XR8 '97 Mocha Foam EL Fairmont |
05-03-2017, 06:50 PM | #10 | |||
Rob
This wasn't about particular models, but rather trying to establish whether the situation is any different in more recent times. |
05-03-2017, 06:52 PM | #11 | ||
Please remove my vote, yes I read it but I am a stupid male and took no notice, my car too early. Sorry.
igodabigblackshinycar and I relented and allowed a BMW into the garage. |
05-03-2017, 06:53 PM | #12 | ||
Why so specific with the date, when pre 2013 models are exactly the same?
It seems you're trying to narrow the amount of votes to try skew results to 'prove' a lower failure rate, also evident by dismissing PG2's comment. If you want a fair sample then allow anyone with FG+ regardless of build month or year to vote and comment. |
4 users like this post: |
05-03-2017, 07:05 PM | #13 | ||
There should be another option in the poll
No not yet. Always dealership serviced but going to happen one day |
05-03-2017, 07:11 PM | #14 | |||
Rob
05-03-2017, 07:17 PM | #15 | |||
And if there is a difference, it's simply because they are newer with less km and it just hasn't happened as many times... yet. Einstein would call it insanity. Doing the same thing over and over again and expecting different results. |
05-03-2017, 07:22 PM | #16 | ||
I'm trying to work out whether the reliability of the heat exchanger bolted to the side of the engine near the starter motor is being determined here, or heat exchangers as a whole.
Territory diesels don't have a heat exchanger like those in the petrol vehicles. Like the V8's, they have the heat exchanger in the radiator. But different radiators I suspect. And they use a different, longer life coolant. So perhaps Diesel Territories and V8's should be excluded from this poll? |
05-03-2017, 07:29 PM | #17 | |||
Rob
if there were procedure changes (as an example) in the build process, then you could have later build cars showing a different result even though they are the same model, hence my focus on year, not model. |
05-03-2017, 07:29 PM | #18 | ||
There is another poll like this one still going with 557 votes so far.
"Do you own a ZF equipped Falcon and have you had it Milkshake?" 68 Yes votes to 484 No votes Here..... http://www.fordforums.com.au/showthr...37#post5891137 |
05-03-2017, 07:32 PM | #19 | |||
So yes... Something has changed. |
05-03-2017, 07:42 PM | #20 | |||
05-03-2017, 07:46 PM | #21 | ||
How many Milkshake threads does it take to change a heat exchanger?
18 users like this post: | 78xcgxl, arronm, BENT_8, blackf6, Cav, Charliewool, fordomatic, Iggle Piggle, Linz, mad2, olds, pottery beige, PridenJoy, Shonky., Sox, trev57, Vesper Martini, xtremerus |
05-03-2017, 07:49 PM | #22 | ||
05-03-2017, 07:49 PM | #23 | ||
Rob
05-03-2017, 07:51 PM | #24 | ||
05-03-2017, 07:53 PM | #25 | ||
Milkshakes have been an issue since the BA at least.
Not being a milkshake fan I fitted a radiator with stainless cooler to my BA, and on the BF I removed the heat exchanger and fitted a stand alone transmission cooler. So from 2002 - 2016, 14 years of crappy transmission coolers in Falcons. |
05-03-2017, 07:53 PM | #26 | ||
05-03-2017, 07:56 PM | #27 | ||
Rob
05-03-2017, 07:57 PM | #28 | |||
Your trans will eventually wear out and fail, as will your engine, coils, exhaust, and just about every other mechanical part. The problem is premature failure of the heat exchanger means a very expensive ZF repair compared to replacing or fixing the damage caused by other mechanical parts failing in other areas ( not transmission). The point however, has nothing to do with "good engineering" ... Ford was well aware of the OEM heat exchanger failures, and were even recommended a better design by the parent ZF company in Germany. But Ford did not want to spend the extra money per unit on a car with falling sales in the FG - FGX series. |
05-03-2017, 07:58 PM | #29 | |||
29-03-2017, 10:32 AM | #30 | ||
George
In order to get the same level of exposure to voters this thread should be in the same section of the forum as this poll is https://fordforums.com.au/showthread.php?t=11404878
I also believe that neither of these polls have addressed the question as to how many failed heat exchangers and or "Milkshakes" have been avoided by the removal of the heat exchanger and the installation of an air/oil cooler? My heat exchanger has never failed because I removed it and installed an air/oil cooler, I would be voting "no" in both polls, but I do not intend to vote in either poll because it would suggest that the incidence of heat exchanger failures is lower than it actually is.
BFWSMhttps://fordforums.com.au/vbportal/v...articleid=1708 ZF:http://fordforums.com.au/wsmpub/bf/307-01B.html 2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal. R/Up 2019:Winner 2023:, Best BA-BF Geelong AFD. PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. |
