02-11-2016, 09:55 PM | #1 | ||
Can anyone advise how to detach the shiny metal "protection " strip from the back ledge of the wagon. It needs to be replaced due to a "mishap". Apart from a wrecker, where is the best source for a new one?
02-11-2016, 10:33 PM | #2 | ||
Challenge Accepted!
wreckers ebay/gumtree or overseas would be my guess.
02-11-2016, 10:37 PM | #3 | ||
02-11-2016, 10:45 PM | #4 | ||
02-11-2016, 11:22 PM | #5 | ||
yes 17k922B
02-11-2016, 11:43 PM | #6 | ||
I think it's the rear bumper protector/scuff plate that Mondoman is referring to (indeed part 17K922B in the posted pdf). (Edit: beaten to it)
I believe it's simply affixed with adhesive, so it should just be a matter of wrestling it off. You could try injecting a glue remover/cleaner like Oomph under the plate to help it pry loose. You can get a new one on ebay, both genuine and third-party options should be available. (I've looked before as mine also has a dent in it, but I haven't been game to go through with trying to remove and replace it.) |
03-11-2016, 12:00 AM | #7 | ||
That part has a part number of BS71 17C979 AB genuine Ford.
It is not in the Workshop manual I have, just how to remove the whole bar. I have my car booked into my dealer tomorrow, so will see if they have one and check it out for you.. |
03-11-2016, 07:23 AM | #8 | ||
I look forward to your reply. I will try mild heat first, then solvent iy that doesn't work.
Don |
03-11-2016, 09:40 PM | #9 | ||
They did not have one there, but are getting me some photos of one to see. They said to give them a couple of days..
03-11-2016, 10:43 PM | #10 | ||
04-11-2016, 09:46 PM | #11 | ||
Hi Don,
I have seen the part you are talking about but having dramas uploading the photo. To confirm the back of it is like one big piece of double sided tape, so a plastic scraper or trim removed should be used to pry it up from the sides enough to get your fingers under, then slowly peel it off... |
04-11-2016, 11:42 PM | #12 | ||
good work
06-11-2016, 08:38 PM | #13 | ||
There is a German high quality carbon fibre strip that can be stuck onto the external part of the chrome strip. Seems like a good alternative.
I suspect that the current strip is stuck on with double sided tape. Don |
