RBS
Old 21-05-2015, 08:50 PM   #1
AaronDugs
AaronDugs's Avatar
Default Have you fit an aftermarket rear sway bar to an au1
Hey guys just curious because The sway bar design my au1 has is only under the title of 'ef/el' sway bar, is the el's and au1's suspension set up the same? cheers
99 AU Futura Granpa Spec
AaronDugs is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2015, 12:55 AM   #2
ebxr82nv
Default Re: Have you fit an aftermarket rear sway bar to an au1
Front is the same or very similar, if it's live axle it's probably a similar story
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2015, 02:06 PM   #3
AaronDugs
AaronDugs's Avatar
yeah sorry its live axle I forgot to mention, its just a rear whiteline sway bar kit on ebay for quite cheap for the E series and it seems to be identical to the one on my AU so I might just bite the bullet and get it
Old 24-05-2015, 03:36 PM   #4
Ride
Stay Classy ™
Ride's Avatar
If you need a front sway bar, I have a 30mm KMAC bar for an AU1 that I no longer need
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2015, 11:50 PM   #5
KRL-94
any luck on finding out if there is an aftermarket rear sway bar for an au S1 live axle??
'99 AU Falcon S1 GLI factory manual in sparkling burgandy, 333xxx, NA + T BF barra conversion, FG TR6060 6spd manual, 3.9 lsd. Currently at 10psi. Power figure unkown at this time.
Project "White Knight"
93 ED XR6
ROH Alloys
Momo wheel
Cruise
Sunroof
Premo Sound
Manual
HO Goodies
http://www.fordforums.com.au/showthread.php?t=11447916
KRL-94 is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2015, 09:09 AM   #6
AaronDugs
AaronDugs's Avatar
I have found some on ebay but they say it suits from EA to EL, type in BFR35 into google and have a look because its seems identical to the sway bar on my au1.
