Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 14-05-2015, 04:30 PM   #1
kjoy064
Default 378mm Options
Hi guys,
just wondering what the options are for the 6spot Brembo's? Increasing to a DBA 5000 hat and a 378mm rotor with spacers for the Calipers?
kjoy064 is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2015, 06:04 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: 378mm Options
Originally Posted by kjoy064 View Post
Hi guys,
Can be done but also have to run new alloy hats because the bolt pcd is bigger for the larger rotor. I think we can do spacers on the alloy brackets but not sure on the cast factory brackets as the spacers need to be 11.5mm and recessed into the bracket so total cost is pretty big plus you then have the problem of to much flex in the hub and rotor and you may get pad knock off.
We are doing some new brake kits made in Australia for about $2500
355mm 6 piston $2500
381mm 6 piston $2500
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 15-05-2015, 03:07 PM   #3
kjoy064
Thank you, already having the 6's on the front trying to keep costs low when the need for new rotors are required.
Old 03-06-2015, 03:33 PM   #4
mjrstar
Minimum wheel size for the 381mm diameter kit I assume is 19'' (or is it 20")
Thanks
2011 Vixen fg turbo ute.
Plasmaman cai, pipework, intercooler, surge tank, 044, injectors, 4 inch dump pipe, 5 inch cat.
Custom engine tune + zf tune by WRC developments ~20psi boost.
mjrstar is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2015, 03:55 PM   #5
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks
Yes 19" but like all brake kits sometimes individual wheels would have to be checked for clearance
MATTHEW PEARCE
Phone 02 9609 1101
Old 05-12-2015, 12:07 PM   #6
Supersuit
will the pad on the factory BF 6piston brembo sweep the entire rotor face?
Supersuit is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2015, 12:16 PM   #7
FLOORED
Race Brakes Sydney
FLOORED's Avatar
It should be fine to be hones i can't remember when we dummy fitted it all up.
MATTHEW PEARCE
Phone 02 9609 1101
