Old 08-11-2014, 06:15 AM   #1
mex351
mex351's Avatar
Default Et Front and Et street tyre pressures ?
So I got some Et Street's cheap and some Et Front runners to match...just wondering what size and tyre pressures you are using in your car.
I have a xf ute with a NAT ASP 250 running 12.2 @ 112mph so far but have been having trouble putting any RPM on the convertor to launch the car on MT radials,hence the swap to the ET Street's.I have some 24x4.5"x15 fronts and 26x10.5x15's rears with tubes on a 15x10 rim to help stiffen the sidewall a tad. Havn't driven on slicks (yes I know the Et's are a treaded slick) in a long time and it's a different car aswell so any help with car set up would be appreciated.
Rob
mex351 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2014, 01:03 AM   #2
prasac
prasac's Avatar
Default Re: Et Front and Et street tyre pressures ?
26x6.5-15 40psi
275/60/15 17psi on 15x10
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2014, 07:16 AM   #3
mex351
mex351's Avatar
Cheers bro...I know what the website says but TBH running 12PSI in rag tyres doesn't sound like fun. Took it for a drive yesterday with 35 front and 20 rear and cold no skids rolling it hooked ! When I got home I put some on the convertor and it went 3400 on the foot brake before it pushed which was good. Backed it off to 3000 and it launched pretty good with real wheel spin.
Should be a good deal I think.
Old 09-11-2014, 08:59 AM   #4
mex351
mex351's Avatar
With NO real wheel spin...dam ph
Old 09-11-2014, 10:24 AM   #5
prasac
prasac's Avatar
they hook good, we can do 4500rpm 10psi boost street launches on 20psi tyre pressure lol
Old 09-11-2014, 03:22 PM   #6
mex351
mex351's Avatar
Suit my car alot better than radials atm thats for sure.Thinking I should convert it to a trans brake now
Old 09-11-2014, 11:13 PM   #7
Parfrey
Parfrey's Avatar
I'd start higher at like 25psi and work down from there at the track..
FG XR6T
GU Patrol Duramax
Parfrey is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2014, 09:29 PM   #8
prasac
prasac's Avatar
25psi is very high, I'd use 20psi as a starting point!
Old 12-11-2014, 08:35 PM   #9
mex351
mex351's Avatar
25psi does seem high, why so high for a slick tyre ?
