Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 08-04-2014, 12:31 AM   #1
Bulletime
Default Tech question, changing pads
Hi Matt,
I've got a question re changing brake pads. After spending some time this afternoon reattaching a caliper that was starting to come off because the caliper bolts had rattled out I've come across a few different recommendations when doing a pad change and am after some advice.
Apparently the ford service manual recommends replacing the bolts on every pad change, ford mechanics say they just locktite them up, and I've noticed that when ford changed pads on my car, without me asking, they did neither.
So what would you recommend as obviously locktite is not good, but do the bolts need to be changed every time? Also to clarify in case I'm taking about the wrong bolts I'm referring to the bolt that goes into the slide bolt.
Thanks for your help.
Bulletime is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2014, 11:33 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Tech question, changing pads
Originally Posted by Bulletime View Post
Hi Matt,
Mate i am apologizing for not responding to this message i must of missed a whole day of them somehow.
From as long as i can remember we never change these bolts unless they are supplied with the brake pads as not all brake pad brands will supply them. You can check the quality of them when doing the brake job to see if they need doing but if they are supplied in the box then 5 mins extra won't hurt to change them.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
