Old 08-10-2013, 11:29 PM   #1
080
Default Can I advance the timing a few degrees??
Hi
I am currently trying to pick up a few MPG on my mileage and was wondering is it even possible to advance the timing 3 or 4 degrees on a laser??
Do I need to do anything other than rotate the dizzy?
Not overly concerned about pinging as all low speed low load short hop city driving.
My recollection with my Holden dunnydoor VH was as lead was removed from petrol and detonation set in I had to retard timing and it ran like a dog.
I had always put my holden forward a degree or two and it had nice around town driveabilty / consumption.
Thanks in advance
080 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2013, 11:23 PM   #2
080
Default Re: Can I advance the timing a few degrees??
anyone?
PS is it because I keep talking about my holden you wont answer??
Old 21-10-2013, 08:40 PM   #3
Quinsta
hahaha, no mate i forgive you for your mistakes..;). Im just unsure about it, try it and see thou really, i run mine on 96 fuel only so i think the timing is advanced, but not sure how much..!
Quinsta is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2013, 08:47 PM   #4
89.SVO
89.SVO's Avatar
get a timing light. Do a google search or get a repair manual if it's a EFI model as it may need a wire bridged/earthed etc. set it maybe like 2 degrees before the factory setting.
And pinging, you should be worried. Decent engine damage can happen from pinging
Daily driver: 2010 Toyota Crown Hybrid
Weekend car: AU2 "XR8" 220kw 5 speed. 19" BBS LM. Full exhaust. Lowered. XR leather interior.
Weekend driver: EA SVO - AU motor. Built BTR. SDE 3500 stall. 76mm turbo. On E85. 425rwkw. 10.8@ 126mph
89.SVO is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2013, 09:50 PM   #5
080
Thanks for those.
Always got an ear out for the pinging. Never had anything damaged but I know it can. Just low speed tonkin' around town so it should be OK. Took the car out for a run in the country and city milage is much better to now too.
OH look!! One whole post without mentioning holden. (doh!!) ;)
Old 15-11-2013, 03:40 AM   #6
graham7773
Ahh Holden, I remember the good old days when if you let the 202/3.3l motor ping without correcting it, you could very likely lose the top off one or more pistons. Happened to me and took some time before I could see the street through the massive clouds of oil smoke. Meanwhile, what pressure do you run your tyres at? Adding 5 or more psi will improve economy but say goodbye to the armchair ride. I run my 195x55x15 razor blades at 36 round town and 40psi on highway and get excellent economy. Of course, I look after all the other relevant things like plugs, leads, filters and correct fuel for the car.
graham7773 is offline   Reply With Quote Multi-Quote with this Post
