Hi fellow Ford people. My 1st time on.
I have an AU3 dedicated LPG. A great car BUT the transmission has a mind of its own. I can be cruising along at 100 kph or where ever and it will back shift for no good reason, or as I slow down it will back shift. It could go for weeks without a problem and then give grief all day !! I have been told by a transmission bloke that it was a common problem and it was the inhibitor switch (neutral/start swith). I replaced it with a brand new genuine part but its still the same. Anybody got any ideas ?? Cheers folks. |
Au Falcon = Mr Reliable
Welcome to Aff Ford, what else, if possble, go to a trusted mechanic & get a ecu scan - it could be couple of things (tps?), the scan will pinpoint the problem. Also give the inhibbitor switch plug a good clean if you havent already. Have a look at this link -
http://www.fordaustraliaforums.com/f...c-gear-changes. cheers, Maka
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
I had a similar issue with my trans. A service with filter and oil change corrected the problem. I believe the issue was caused by my filter being too clogged, starving the trans of fluid. This would also explain the intermittant nature of your problem.
Good luck sorting it out. Cheers Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
a common problem ?? mines never had a problem other been worked hard and getting a little soft in the changes after 200,000 +k's ,
had any electrical issues in the past ??? |
[QUOTE=mik;4854360]a common problem ?? mines never had a problem other been worked hard and getting a little soft in the changes after 200,000 +k's ,
had any electrical issues in the past ??? Thanks for all the suggestions people. I've only had the car a short time but there is no other issues with it. The service and filter sounds like a good place to start but !! The trans has been replace at some stage (I no this because it has a dip stick !). |
[QUOTE=mik;4854590]I believe it is possible to have a filler tube fitted, so it may not have, service sounds like a good place to start though.
Nah, you can't fit a dip stick tube to the later model box, Different housing all together |
yes you can, the marking is on the inside of the box, it can be drilled from underneath with the pan removed
2000 AU Wagon |
[QUOTE=naughtyfalcon;4855124]yes you can, the marking is on the inside of the box, it can be drilled from underneath with the pan removed
Yeah, OK... Didn't no that ! The next time I've got the pan off a late one (hope thats not too soon). I'll have look. Thanks for that mate. |
