Old 14-07-2013, 01:27 AM   #1
Loris
Focus & Territory TDCi
Default Cigarette Lighter always on
Hi,
Anyone know how to make the cigarette lighter socket switch off automatically when the ignition is off? At the moment it stays on all the time even when the car is off and keys are out.
Thanks
Loris is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 04:30 AM   #2
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default Re: Cigarette Lighter always on
Don't know if it can be done unless you rig a switch in line with the circuit?
___________________________
Old 14-07-2013, 09:27 AM   #3
fbvisitor
I'm interested to know this myself as I'm about to put a crash cam in SWMBO car.
This would allow her to not have to worry about starting and stopping it.
Once upon a time it was a relatively simple task of picking up a feed from a circuit that's switched on as and off by the ignition but with CANBUS things aren't quite as straight forward (so I've been told).
fbvisitor is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 11:25 AM   #4
pertuan
Focus on my Focus
Perhaps use a relay that's switched from the radio?
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 09:37 PM   #5
DeKa
Apparently in Mondeo, you can change this by moving the Cigarette Lighter fuse "up" one position in the fuse box.
I'll have a look at my Focus tomorrow and check if similar positions exist.
Ref: http://fordwiki.co.uk/index.php/Ciga...er_bulb_change
DeKa is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2013, 09:43 PM   #6
Loris
I just put a dash cam in and its a pain having to always take out the power from the socket.
I have a 2008 tdci lt focus. Looking at the manual for the fuse box and what i actually see in the car are two different things. The numbers dont even match so i have no idea which fuse is the cigarette lighter in order to do the mondeo trick.. Any one know which number fuse it is?
Old 14-07-2013, 10:31 PM   #7
Yellow_Festiva
Where to next??
I did the fuse for the ciggy plug once. Problem is, book is in car and car is at the dealer.
Yes, book is useless at explaining how to access fuses. Fuses are behind a flip down panel below the glove box. If memory serves you need to unscrew two plastic nuts.
Find the thread on changing the pollen filter, you need to remove the fuse panel to do so. The pics will help.
Old 14-07-2013, 10:55 PM   #8
marg99
If it helps the cigarette lighter is a 20amp fuse.
Old 14-07-2013, 11:20 PM   #9
Loris
Thanks, yep ive got the fuse box pulled down but buggered if i know which is cigar fuse and where to move it to for ignition only
Old 16-07-2013, 10:39 PM   #10
Loris
So i think im going to go the fuse tap method and install a secondary cigarette lighter\power source behind the glove box for the dash cam using something like this:
http://dx.com/p/diy-car-cigarette-li...ack-red-195736
Ill probably tap the radio fuse as that turns off with ignition.
Old 17-07-2013, 10:38 PM   #11
Foconatic
Foconatic's Avatar
Originally Posted by Loris View Post
Hi,
Thanks
My Titanium 12 volt power outlet switches off ......eventually. It's on a timer controlled by the BCM. But it takes awhile. (Over 10 mins. I gave up waiting for it to switch off.) I use it for my Pure digital radio.
FORD FOCUS Titanium Sedan with Sports Executive Pack in Midnight Sky GDI
Going somewhere isn't why you drive, driving is why you go
Foconatic is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2013, 09:05 AM   #12
marg99
this suggests it may be possible for a dealer to reprogram that aspect?
Old 18-07-2013, 01:57 PM   #13
Loris
I waited over 30 minutes, doors locked and I could see through the window it was still on.
Foconatic, they must of changed it on the newer Focus.
