09-06-2013, 11:27 PM | #1 | ||
Where would water leak into the cabin, drivers side, when it rains
looked around the firewall and under the front cowl and no holes could it be leaking around the windscreen?
03 BA XLS 6cyl Ute-Mercury Silver 04 Subaru Liberty GT Premium 99 Toyota 105 series Cruiser TD 99 5.8M Profish plate alloy carport decoration |
10-06-2013, 12:56 PM | #2 | ||
Chairman & Administrator
Top header rail of the windscreen is one possibility but a more likely choice is the plenum chamber with either the drain holes blocked or rust from pooled water.
Cheers Russ
Observatio Facta Rotae
10-06-2013, 02:44 PM | #3 | ||
Hmmmm well it's for sale so I'll just park it under cover and let someone else worry about it. spent way too much on it already
24-06-2013, 05:42 PM | #4 | ||
Hey, I also have the same issue, wet carpet in the drivers side. Where should I be looking for water coming in?
09-06-2022, 02:50 AM | #5 | ||
Any new ideas on this my daughter has same issue
