Stingray
Old 24-03-2013, 12:57 AM   #1
XDOUBLEU
Default Drag racing with a toploader
Do any of you guys have any tips and tricks for racing with a toploader?
I have been having trouble with my shifts, especially 1st to 2nd at full noise. If I try to grab second in the burnout, It crunches and won't go into gear, and then second crunches after the launch too. But if I stay in first during the burnout, then I can get second ok after launch.
Is this an inherent problem with pushing a toploader hard? Or do I have a problem with my setup
The synchro looks ok, but I am considering removing every second tooth off the synchro cone in an attempt to get a better shift at hi rpm . Has any of you guys done this mod before, and do I need to mod the gear as well?
I am running an xw in full street trim with 393 clevo, toploader, centre force dual friction clutch, and 4.11 rear. 6 cyl front springs, koni shocks, 235 et streets
Last week, with a new clutch I ran a pb of 12.07 @ 119 mph and watching the vid. I could have had a cut lunch between gears . What can I do to make my toploader work? I am determined to delv deep into the 11 s before I can it And fit an auto
XDOUBLEU is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2013, 05:37 AM   #2
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Default Re: Drag racing with a toploader
How hard are you spinning the clevo on gear change? Maybe try dropping the revs in 100rpm increments until you find the point it takes the change ok?
It might have some clutch drag under maximum attack, a clutch swap may also fix it, but that's a tad expensive to try at this stage me thinks. Does the pedal move at all as you run down the track?
Why don't you just start the burnout in second gear, it's not like it will have any trouble with the second gear clutch drop.
I know they're no way similar, but my tremec won't take changing beyond 6700-6800, it baulks, and can even just plane refuse to swap closer to 7000. I only do 2nd gear burnouts in staging, and I drop the clutch in second so to avoid the 1-2 shift. I've done a few 3rd gear burns, but it seems a little less brutal on the driveline side stepping 2nd!
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2013, 09:21 PM   #3
shrek378
If you are useing a toploader for racing you are only playing :put a auto in it:!!
shrek378 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2013, 09:53 PM   #4
tex
Broken
tex's Avatar
Hahahaha, sound advice.
The Scud GT
Old 24-03-2013, 09:58 PM   #5
Legit290
Legit290's Avatar
you can get some pretty trick after market shifters for the toploader...that may be an option?
Legit290 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2013, 10:09 AM   #6
shrek378
By the way I am speaking from experience not out my a-&e I ran 11.6 with full weight xy Gt with toploader after a lot of $$$ and sorting at the end of the day with what I spent I should of went hi stall auto.
Old 25-03-2013, 05:06 PM   #7
Rural 351
1000+ passes
Rural 351's Avatar
What ever you do don't put a bleeder in it stick with the manual, good syncros and a old school V gate shifter, you don't really need to take off every second tooth if your not going over 7500rpm, Ive done the tooth thing before its good but no comparison to the liberty gears I later fitted, If you want to run into the 10s give up on it and get a Jerico D4R (that's the latest version of the DR4 ) but a pretty much stock toploader will get low 11s depending on your engine and traction
If you do the syncros be careful there are some crap ones around and make sure the taper they run on is flat and then give them a little lap in before you chuck it back together, even think about a muncie input shaft if you still have the stock item they do break
A short shift into second would still be better than a slow shift
As for the burnout I always dump it in 2nd in the water
http://www.youtube.com/watch?v=KvkgvHljfjc
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2013, 10:50 PM   #8
XT302
Search raging rhino in this section xygt toploader 31 input/output and aftermarket shifter 393 , 3.89 gears ran 11.2.... STILL manual but running pb 10.6
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2013, 12:07 AM   #9
XDOUBLEU
Thanks for the info fellas
I have only done one meet with a clutch that doesn't slip. I will try 2nd gear burnout next time, and mayby try to short shift into 2nd too
I am shifting at 7000 rpm and as said a few less rpm on the first shift will be better than crunching
Any ideas what brand the good synchros are? I am also trying to find out what the max mainshaft end float should be. I have .030" at the moment and it seems excessive to me.
Old 26-03-2013, 01:27 PM   #10
GTB 351
GTB 351's Avatar
Hi XDOUBLEU,
My black XB Coupe was running very similar numbers back in the mid 90's running a 351 4V clevo, toploader and 4.56 lsd. 12.1 @ 117mph. I was running a V-Gate shifter and no mods to the box.
The synchro mod was something I was going to do but I think a change in lubricant has the most dramatic effect. Switch to Dextron III ATF or transmax-z.
I always did my burnouts in third and accasionally even 4th gear (with slicks) as it is easier to tell when the tyres have gotten grippy and I was well known and photographed for my burnouts. I changed gears at 7300 - 7500 rpms which was a little beyond the limit of my oiling system.
Your car is good for at least 3 to 4 more tenths with some work. If you have input shaft problems(as I did: they'd break shifting into 4th if you had too much clutch) then check out toploader heaven or david kee toploaders, theres plenty of stronger affordable bits for them.
In the old days I saw some people send there toploaders to shops for lots of mods (layshaft lubrication mods, special synchros etc and spend lots of dollars and there boxes didnt seem to work any better than those with the ATF added.
I'm planning on running a toploader behind a 460 in the coupe in the next year or 2. I'll look at using a wide ratio big shaft set up from one of the vendors list above with a bull nose input, 31 spline output, transmax-z and my old V-Gate shifter, but being the lazy ***** that I am it will probably be the old box exactly as it was in the 90's.
Plenty of people told me I shifted too slow and when I was in plaster and couldnt race I let them put their money where there mouth was; I let 2 guys run my car and the quicker one kept missing gears, the other couldnt launch it and neither criticised my gear changing after that. The hardest thing to teach yourself is to change gears without lifting your foot from the accelerator! It stops the car falling over on each gearchange.
The Car -
http://www.fordforums.com.au/showthread.php?t=11358570
The Engine Rebuild-
http://www.fordforums.com.au/showthread.php?t=11361067
GTB 351 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2013, 07:06 PM   #11
XT302
The owner of this says once he is over 40 he'll stick an old mans gearbox in it...
http://www.youtube.com/watch?v=PonbkUuAt4g
Old 27-03-2013, 08:52 PM   #12
Rural 351
1000+ passes
Rural 351's Avatar
I always think of going down the drag strip as playing, are you trying to say that when you have an auto its not fun anymore ?
Old 27-03-2013, 11:14 PM   #13
GTB 351
GTB 351's Avatar
I went on to fit a 460 and full manual C6 into the black coupe in the mid 90's; it took all the fun out of it for me, thats why it will change back to a manual when it hits the track again!
Oh, and I'll probably be over 50 by then.
The Car -
The Engine Rebuild-
Old 28-03-2013, 10:29 PM   #14
TC200six
IMO Toploaders may be a very durable box, but they would be terrible for racing where you shifting all the time. Maybe it's because I'm too soft after driving cars with other manuals
TC200six is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2013, 10:44 PM   #15
shrek378
Unhappy Re: Drag racing with a toploader
Run whatever box you want;if you don't want a fast car you run a toploader!!!
Old 29-03-2013, 07:57 PM   #16
XT302
10.91@125 with toploader just with big input and output shaft, oh yeah and with dual plane airgap manifold, pump 98 octane, 3.89...
10.6@129 with Jericho, still 3.89, just had a change to single plane...10.704@128.77mph (airgap)
Not fast enough for you Shrek? whats yours run?
Old 29-03-2013, 08:13 PM   #17
tex
Broken
tex's Avatar
^^^^^^^^^thats some awesome driving right there^^^^^^^^^^
The Scud GT
Old 29-03-2013, 08:52 PM   #18
shrek378
Cool Re: Drag racing with a toploader
I have been out of the racing seen for ten years ten ago 10.2 351 clevo 131 mph xw falcon and just built another xw with 610 hp at the tyres have not run that car yet!!!
Old 29-03-2013, 09:10 PM   #19
shrek378
Question How many 7-9 second pro streeters do you see with a Toploader?
Old 29-03-2013, 11:52 PM   #20
HEMI POWER
N/A BOSS 390+
HEMI POWER's Avatar
Thats a great effort, toppies are pretty **** so kudos to the driver.
We know autos are better
WOOOOOOOOOO
FPV GT 03 /341 RWKW OF N/A POWER.
XB GT 73 /OLD FORD MUSCLE
ALL AUSSIE MUSCLE
HEMI POWER is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2013, 02:36 AM   #21
XW WA
XW WA's Avatar
Personal preferance i reckon. I would rather a 10.9 toploader than a slush box. Thats probably quicker than my car will ever go anyway . Obviously worked autos are quicker down the strip when you get to the very low numbers but you get extra credit running a stick on the 1/4 IMO. Have seen some pretty awseome numbers from the mustang guys running toploaders in the states tho . Probably change the clutch a fair bit tho , but go the manual s . clevo ,toploader ,9 inch .that is all
XW WA is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2013, 02:46 AM   #22
XW WA
XW WA's Avatar
Why is there not a class for manuals and one for autos at the drags ?
Old 01-04-2013, 10:24 PM   #23
Rural 351
1000+ passes
Rural 351's Avatar
10,2 131 hmm like the gas do you ?
Old 01-04-2013, 10:29 PM   #24
tex
Broken
tex's Avatar
The latest one seems quite quick..
The Scud GT
Old 03-04-2013, 09:38 AM   #25
shrek378
No gas at all standard stroke 351 clevo.
Old 03-04-2013, 09:50 AM   #26
Rural 351
1000+ passes
Rural 351's Avatar
Something doesn't add up don't make us drag it out of you cause I've been around long enough to know back then those times would have only been possible for a reson, so was it in a mini or do you know a short cut?
Old 03-04-2013, 09:56 AM   #27
shrek378
That's what the car run mate 2003 2004 in tassie some people on the forum would remember it.
Old 03-04-2013, 10:01 AM   #28
shrek378
I sold it to a guy in Sydney he gassed it and it run 8.90 150!!!
Old 03-04-2013, 10:09 AM   #29
shrek378
When chi heads came out I bought one of the first lot of heads they made had them handported by pavtek in melb it was the fastest street ford in tassie back then,there was a mag I think it was performance ford they did top ten of every state it is in some of the magazines.
Old 03-04-2013, 12:17 PM   #30
XT302
What comp? Fuel it run?
