02-01-2013, 07:18 PM | #1 | ||
http://robrobinette.com/et.htm
Admittingly it did pick my LS1 quarter mile ET almost exactly. Also a few other cars that I have checked are very very close. Id like my charged 8 to run the time suggested. |
02-01-2013, 07:24 PM | #2 | ||
It says mine should do 14.77
02-01-2013, 07:39 PM | #3 | ||
I typed in 4000lbs and 480rwhp for a ET suggestion of 11.8 lol,I am already at 11.3 with a slipping trans and Darwin weather.
I recon a 10.8 is gettable so yeah its a bit off. Turbo cars have a massive torque spread which the calculator doesn't account for.
03 BA Turbo 6466 external gate Hi comp motor Built BTR 4k TCE stall FG inlet and exhaust manifolds |
02-01-2013, 07:44 PM | #4 | |||
Cane Farmer
Checked it against my old XR6s time...
Sport on, 15.4 My PB was a 15.448 ~3700lbs, 200rwhp.
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
02-01-2013, 07:51 PM | #5 | ||
formerly Troy23
Apparently 15.5 for mine
3756lbs, 199kw
My ride: 2010 FG XR6 (black) Mods: Pacemaker competition headers, hi flow cat, x-force cat back exhaust, K&N air filter, Kings SSSL springs, Herrod CAI, Powerbond under drive, XR6T injectors[B] Last edited by 335POWER; 02-01-2013 at 07:57 PM. |
02-01-2013, 07:51 PM | #6 | ||
its says my clubbie will do a 12.8
(weight is 3615 in pounds and 400 horsies @ fly) if i recalculate using rwhp using 400hp@fly=300rwhp then its 13.35
: Z series Clubsport HRT edition.. e46 320ci 2.2ltr Stocko |
02-01-2013, 08:00 PM | #7 | ||
15.0 mine says.
02-01-2013, 08:10 PM | #8 | ||
Lol I think it was optimistic for me
17:92
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
02-01-2013, 08:10 PM | #9 | ||
Just for a giggle I tried my first car, a 1953 Austin A30.
1500 pounds, 30hp... 22 seconds...sounds a little optimistic to me from what I remember... |
02-01-2013, 08:14 PM | #10 | ||
13.4
FLy Hp: 368hp Lbs: 3858 |
02-01-2013, 08:25 PM | #11 | |||
His: 2015 FG-X XR8 ZF (Stock) & 2009 FG G6ET 370rwkw on pulp 98 and 426rwkw on e85 thanks to Spiro @ Autotech Engineering Hers: 2012 FG MK2 G6ET Previous: 2012 FPV GS Ute 423rwkw |
2 users like this post: |
02-01-2013, 08:29 PM | #12 | ||
3860 lb .. i think thats right or abouts.
310 rwhp comes up with 13.5 pb of 13.65.. so it is close |
02-01-2013, 09:37 PM | #13 | ||
says my escort will do 10.5 and my boss 12.5
not sure about the boss doing that. |
02-01-2013, 09:45 PM | #14 | ||
yeah, pretty close for me too
3600lbs 325rwhp 12.98 1/4 actual pb 13.08 @ 108mph
Money Talks, but all i ever hear is it saying Goodbye!! |
02-01-2013, 09:55 PM | #15 | ||
say my 88hp motorbike will do 9.6
i doubt that |
02-01-2013, 09:59 PM | #16 | ||
It says 11.44 for my xr8... Given the right conditions/tyres maybe
Make sure you add in the driver/riders weight too. 1kw = 1.34 hp 1kg = 2.2 pounds Last edited by RAPID_BA; 02-01-2013 at 10:06 PM. |
02-01-2013, 10:16 PM | #17 | ||
yeah the times certainly are optimal drive line setup times.
not bad tool though |
03-01-2013, 11:55 AM | #18 | ||
Not really, my LS1 has stock diff gears, stock stall and it picked the right time. No doubt with gears and converter there is probably half a second to a full second difference.
Id call my setup less than optimal. |
03-01-2013, 01:18 PM | #19 | ||
Yeah but the 1st gear in the Holden 4spd is rather short and helps with take off somewhat.
This is the reason for hole shotting the Fords all these years with the 6cyls and some 8's.
03-01-2013, 02:37 PM | #20 | ||
This had me on the floor in stitches with laughter!
03-01-2013, 02:54 PM | #21 | ||
3000lbs and 152hp = 16.5, that's about right.
2011 FG XR6 Sedan |
03-01-2013, 03:21 PM | #22 | ||
on the way to the RSL
3550lbs
Dyno showed 300rwkw, but convertor is soaking most of it. this calc says mine will do 11.4 but its done 10.9xs@121/125mph
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9" 8.9x@160mph+ |
03-01-2013, 05:21 PM | #23 | ||
Clutch Cable Killer
yeah I got it to come out with 16.1 for mine, which is quite close seeing as I got 15.5 and my GF got 16.6 in hers, which is the same but auto.
Matthew 1997 Manual EL XR6 in Heritage Green Extractors and 2.5" exhaust- - 16" Tickford Wheels - Full EL XR bodykit - COYO73 Plates HID projectors, lowered on King SL and Koni Shocks. Daily - 2002 AUIII SR Stock as she comes. Coyote's EL XR6 ^^Click Me^^ 15.132@ 91.51 MPH Photos by Me https://www.facebook.com/PhotosByMatthewWylie |
03-01-2013, 05:28 PM | #24 | ||
Said 11.2 for me but i've gone 10.6
Said my clubbie should do 12.7 which is probably about right. Maybe it works better for NA cars
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
03-01-2013, 05:30 PM | #25 | ||
A standard 3.8 V6 from Holden only out performed the 4.0 I6 because of the shorter first gear in the transmission,the BTR is very tall but this is where economy comes into play. The 5.0ltr Holden motor was the same scenario to the E series Windsor 5.0.....the shorter first gear in the trans getting the torque going sooner. Why do you think a ZF 6spd BF 6 or 8 beats the same powered BA 6 or 8?
03 BA Turbo 6466 external gate Hi comp motor Built BTR 4k TCE stall FG inlet and exhaust manifolds Last edited by Auslandau; 04-01-2013 at 12:35 AM. Reason: Removed the bits not required! |
03-01-2013, 08:09 PM | #26 | ||
Pethy FG XR8 Ute
how much does a ute weight???
i used 3900lb x 394rwhp = 12.5 i would be happy with that
FG XR8 Ute 2010 Nitro, Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum Powerbond 25% under drives, Sports bar, now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset total of 285.5 rwkw and 642nm when Herrod cams in 290rwkw GSXR 750K7 with goodies, dyno'd 136rwhp, 10.567sec for the strip |
03-01-2013, 08:29 PM | #27 | ||
Hmmmmm Mulberry....
Nope.. Said 11.8, but have gone 10.91
03-01-2013, 08:38 PM | #28 | ||
Ours is a circuit racing XE it reckons 11.1
2800lbs (it weighs 1400kgs) and 400 RWHP
I reserve the right to arm bears
03-01-2013, 09:41 PM | #29 | ||
xe@1400kg, is there much left of the car?
03-01-2013, 10:02 PM | #30 | ||
XE's aren't that heavy. I've found figures, probably for a 6, of 1320kg. Make it a V8 (+100kg), roll cage and then some weight reduction and it makes sense.
1400kg is almost 3100lbs though. |
