Adams Polishes
Old 18-12-2012, 04:22 PM   #1
mrfalcoon
Default changing clock spring
changing clock spring,
take air bag cover off,
take steering wheel off ?
and the clock spring is the black oval shape behind steering wheel ?
mrfalcoon is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2012, 04:32 PM   #2
mrfalcoon
Default Re: changing clock spring
ok,i have worked out,this is what it is :-) i now have a horn yay:-)
you think the clock spring could effect air bag light to flash ?as it was flashing...... i guess ill find out in 1hr when it resets it self ?
Old 18-12-2012, 08:46 PM   #3
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Yes the clock spring affects the airbag light. The light will flash error code 32 when the clock spring dies.
MINE- AUII Forte
Old 18-12-2012, 09:02 PM   #4
mrfalcoon
seems to fix it
do you know what the best pully is to remove steering wheel ?
supercheap will have one?
Old 18-12-2012, 11:40 PM   #5
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Originally Posted by mrfalcoon View Post
seems to fix it
You shouldn't need one. If it is on tight, just try a little spray lube. Give it 5 mins and then a firm nudge should break it loose.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
