Old 20-08-2012, 08:39 PM   #1
G6ET8U
GTX Turbo & KB Blown
G6ET8U's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: ALWAYS goes out of his way to help others in need, never posts rubbish only facts he has learnt the hard way or with success in his personal experiance. Takes the time to aid more junior members and overall is a solid contributor to AFF.
Default Tyre options for 11.48 @ 123.5MPH car.
Hey guys,
Haven't ever really been in here much but now I have a car that I've started to race I am in need of some help, assistance and guidance!
My car is an 2008 FG G6E Turbo. I have raced it 4 times so far. 3 runs on Nitto NT05R 275/40/17 @ a touch under 20psi on BA XR alloys. I use the Nitto NT05 on my street wheels 275/30/19.
I have only run the car on the R tyres at Heathcote test and tunes so far. The best run being an 11.48 @ 123.52MPH. Best 60ft so far is 1.93...
I have been advised to move to a 16 inch wheel and a 235/60 MT ET tyre.
I make no other changes to the car to race it. It has the full size (19") spare and jack. All my change in the centre console and a full tank of BP Ultimate.
Fire away
Jack
DARTH 2008 FG G6ET
465.6rwkw
not a 10 @ 134.81 MPH
SNOW WHITE 2004 BA FPV PURSUIT
2.6L Kenne Bell
Brembos all round
Twin Screw Awesomeness
Supported, serviced and tuned by
BLUEPOWER RACING DEVELOPMENTS
http://www.fordforums.com.au/showthread.php?t=11354744
G6ET8U is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 09:10 PM   #2
G6ET8U
G6ET8U's Avatar
Default Re: Tyre options for 11.48 @ 123.5MPH car.
Sorry for my noviceness...
Advised to go to a 255/50 MT ET...
Edit: and just to add to this so all information is on the table. The car has Koni Red shocks, King Springs that aren't too low. I imagine the car is close to or even over 4000lbs.
So far the best 60ft I have gotten out of the car is a 1.93 on the Nitto's.
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 20-08-2012, 09:14 PM   #3
Tobey
BF Ute...
Tobey's Avatar
You can go a 275 ET on a 17" XR wheel, quite a common way to go...
Tobey is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2012, 09:19 PM   #4
G6ET8U
G6ET8U's Avatar
MT's are the common tyre that most 'recreational' drag racers use. I only went for the Nitto NT05R due to cost and whether I was actually going to 'take to' drag racing my car and if I didn't then end up with a set of wheels and tyres I didn't need any more.
I like it
I also appreciate that a 275 MT on a 17" rim would be better again but I am also interested whether a 16" rim would be better as that is the advice that I have received.
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 21-08-2012, 11:42 AM   #5
icer
Winning's Winning!
icer's Avatar
depends on your brakes size. 16" may not fit.
As i stated in your build thread, 17/40/275 from vpw.com.au or speedpro in dandy. <$300 a tyre. You can pick em up and stop of at the bridgestone just on the corner of the Speedpro shop and have the guys there fit the et on the xr rim on the spot for $10 a tyre! Win win.
Plenty running low 10s with the setup!
Dyno-Mite Performance Tuned
+480RWKW on ~24psi 10.05 @ 138MPH
Now with new setup 460rwkw on 15psi. 30PSI is fun!
icer is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 08:15 PM   #6
dieseltrain79
Yep 275 17 are the go , but if you insist on 16's , I run 255/50/16 on a 16x7 rim with no issues . 60' 1.60 all day and would prob go a 1.5 with the new convertor .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 08:27 PM   #7
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
I use 275/40x17 jack, I think they work ok. Not that I've ever run a quick 60, 1.88 my bestest, but, that's more to do with my sympathetic launching, not lack of grip. At heathcote they hold full throttle in second gear...
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2012, 11:07 PM   #8
XEGL
XEGL's Avatar
If you can get the 16 on, don't look back!
The tyre size in a MT ET street is the shizzzz
Even a 265 or 275 if you can squeeze them under.
XEGL is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2012, 08:02 PM   #9
G6ET8U
G6ET8U's Avatar
Thanks for that XE!
I have won a set of 16" 255/50 MT ET's on Falcon steelies.
Will see if they fit after I collect them
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 22-08-2012, 09:12 PM   #10
dieseltrain79
Should fit , are 26 inch tall which is very close to factory specs enjoy
Old 02-10-2012, 10:49 PM   #11
xr6t_ute
xr6t_ute's Avatar
It should help alot with your 60 ft.. I ran the same tyre for a 1.6 60, but thats only if you have been spinning with the other tyres.
If you havnt, you need more boost off the line .
Daily driven workute....10.33 @ 136mph
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
xr6t_ute is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2012, 10:57 PM   #12
rednose
RNS10S
rednose's Avatar
Agree with Ivan, you may also benefit from lighter wheels
rednose is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2012, 07:24 AM   #13
Black F6
Black F6's Avatar
We have pretty much the same set up and power, and I use the 275 x 17 MT and run 1.6 all day long
12.33@112mph (stock)
11.00@125mph 98 (387rwkw) (CMS)
10.19@139mph (450rwkw) (Nizpro)(SOLD)
10.25@138mph FG XR6T (new toy) (Nizpro)
Black F6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2012, 07:58 PM   #14
G6ET8U
G6ET8U's Avatar
There is no question that the car needs more boost off the line but in saying that the tune hasn't been done to make the car 60ft nicely. Excellent advice though there mate, I will be taking the 16" MT's next time I go out. Upgraded tailshaft is going in tomorrow too that will allow me to stay on the line longer after a slightly longer burnout with the new slicks on.
It is good advice George. Anything to reduce weight provides a gain. It will be something that I will look at for sure mate.
Once the tailshaft goes in tomorrow we are basically on par Scotty!
I don't have an E85 tune. Honestly trying to avoid it right now. If I had E85 available at the bottom of my apartment then I'd have an E85 tune.
I'm going to have Blue Power lean on the tune a bunch more early on. Trying to get the car to 60ft better... I am going to need to try to also get my skirt off and really lean on the car off the line too
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 01-11-2012, 09:46 PM   #15
dirty
I run 1.75 in the 60' and my old shagger only does 12.4 et. I run 255R50 - 16 MT dot drag radials on bog stock BA steel rims. I do have a final ratio of 3.7 now but car did the 1.7's before I did that. Only makes 12# boost, and its 1.96t whatever that is in pounds? I recon the extra tyre there with a smaller rim gives more on the launch, only recon but, no proof. Fitting a 16" over brakes is an issue for some but.
dirty is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2012, 10:48 PM   #16
xr6t_ute
xr6t_ute's Avatar
Yeh not sure if they will fit on a Fg, on my Ba they fit no problem.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 04-11-2012, 09:38 AM   #17
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
I use 255/15s and can 1.5 60ft at Heathcote off the footbrake. Leaing the line with about 15psi and has a 3.27 diff.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2012, 07:48 PM   #18
G6ET8U
G6ET8U's Avatar
Update to this, I have now run 11.11 @ 124.69 at Calder Park with Nitto NT05R at 25psi cold. Very sticky track. My tune isn't set up with much boost early so 60ft was a fairly quiet 1.71. Other FG's were getting 1.5's on the night.
I tried out the 255 x 16" ET's at Heathcote and couldn't get under 2.0x in the 60ft. Plenty of cars were struggling for grip though.
This was on the footbrake, handbrake combo. Just the footbrake alone would have the car spinning the slicks on the start line. Any more than that would have the car spinning through 1st and most of the way through 2nd on MT's and NT05R's.
I am interested in trying the MT 16's at Calder on a properly prepped track that is sticky and will hold the car and the boost
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 05-11-2012, 11:14 AM   #19
dieseltrain79
There's your 10 waiting ;)
Old 07-11-2012, 10:53 PM   #20
xr6t_ute
xr6t_ute's Avatar
So the 16s fit no probs hey????
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 08-11-2012, 06:04 AM   #21
G6ET8U
G6ET8U's Avatar
No problems at all mate.
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 08-11-2012, 07:16 PM   #22
snapper82
Have upgraded ur rear brakes? i tried a 16 rim (nissan) on didnt fit over my f6 rear brakes
might try a steel rim
snapper82 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2012, 07:50 PM   #23
G6ET8U
G6ET8U's Avatar
Mine has stock Ford brakes mate, not FPV brakes. I believe they don't fit over FPV brakes.
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 10-11-2012, 12:29 AM   #24
xr6t_ute
xr6t_ute's Avatar
I had my 16 inch wheels widened an extra 1.5 inches, the mt's sit alot better on them compared to a stockie rim.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 10-11-2012, 04:40 PM   #25
G6ET8U
G6ET8U's Avatar
Thanks for the XR.
What was the damage for them to be widened? Are they ok structurally after being taken apart?
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 11-11-2012, 12:45 AM   #26
xr6t_ute
xr6t_ute's Avatar
Yeh it was done professionally, the only draw back is the extra weight, your better off with a 17 alloy rim.
Cost me back then $110 per wheel.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 11-11-2012, 12:49 AM   #27
xr6t_ute
xr6t_ute's Avatar
Ive since gone to a 15 inch rim with full slicks as i cant get off the line with my power level on the radials... The joys of having a ute.
You sedan boys are so lucky.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 11-11-2012, 09:33 AM   #28
G6ET8U
G6ET8U's Avatar
No doubt you'd be struggling off the line mate! Big power from your ute!
I have 17" alloys already but have my NT05R's fitted to them. I think I will just race on those until they are finished up and then get myself some MT's after that.
Jack
DARTH 2008 FG G6ET
465.6rwkw
2.6L Kenne Bell
Brembos all round
Old 11-11-2012, 12:56 PM   #29
dieseltrain79
Radials can hang on .. Plenty of 6/7/8/9/10 second cars on radials in the world .
Old 11-11-2012, 04:51 PM   #30
prasac
prasac's Avatar
if you can set the *** end up in a ute, you can leave with big power.
prasac is offline   Reply With Quote Multi-Quote with this Post
