Old 27-05-2012, 01:01 PM   #1
xr6t_ute
xr6t_ute's Avatar
Default Hoosier 28x10.5x15 slick
I am trying to get my 60ft down on my Ba turbo ute.. best to date was a 1.62 (radial) and have gone backwards since upping the power level (1.78)
Ive got my hands on some 28 x 10.5 Hoosier slicks and wanted to know if it will be ok to run on a 8" rim. Any feedback would be much appreciated.
Daily driven workute....10.33 @ 136mph
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
xr6t_ute is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 01:33 PM   #2
CYC06T
Default Re: Hoosier 28x10.5x15 slick
I think you can, but it won't be the best fit. A 10inch rim would be much better. I was running that combo on my car for quite a while
8.4 @ 174mph
CYC06T is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 02:19 PM   #3
dalts
dalts's Avatar
You will have to jack the ute up a lot to get a 28x10.5 under it,I barely get a 28x9 under mine!
blueprint ba turbo ute,powerglide,
Old set up -9.9@140 1.57 60ft 720rwhp
New set up 1003.4rwhp yet to be run!
Tuned by
Forced performance and tuning.
dalts is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 02:29 PM   #4
xr6t_ute
xr6t_ute's Avatar
Using standard rear..Do you think it will need to go higher than that?
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 27-05-2012, 10:37 PM   #5
dieseltrain79
Your radials are probably too far worn to handle the power and launches now !
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 12:35 AM   #6
4VCLEVO
XA GT
4VCLEVO's Avatar
I'm running a 28x10.5 M/T on a 8inch rim, fits fine.
XA GT, 6.848sec 1/8 mile @ 101.68mph
4VCLEVO is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 07:16 AM   #7
dalts
dalts's Avatar
It would be touch and go,a 28x9 would be fine thats what I used but at 460rwkw that size was at its limit with a standard suspension set up!
Tuned by
Old 28-05-2012, 11:55 PM   #8
xr6t_ute
xr6t_ute's Avatar
Ah ok.. well will find out tomorrow night when i get the wheels fitted to the tyres, and dummy it up...otherwise yeh, maybe go and shell out for 28x9 and sell the 28x10.5x15s
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 29-05-2012, 09:14 PM   #9
xr6t_ute
xr6t_ute's Avatar
Ok well finally got the rims on thanks to my Mate Tony,and Heath for giving me his custom made calipers :-)
28 x 10.5 hoosiers fitted nicely with more headroom than i thought.
Thanks everyone for there input... Just about ready for the Heathcote AFF drags.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 29-05-2012, 09:18 PM   #10
xr6t_ute
xr6t_ute's Avatar
http://www.fordforums.com.au/attachm...1&d=1338286727
The pic on the left is the std xr6 18 inch wheel and tyre against the hoosier slick.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 04-06-2012, 08:30 AM   #11
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
The tyres are good for 7 sec passes, provided the car is sorted.
They are quite tall compared to std.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 09:48 AM   #12
xr6t_ute
xr6t_ute's Avatar
Yeh Standard rear end Paul, the only thing i can think of is that the leafsprings are probably wrapping up on takeoff.
Theres always slapper bars, 4 link etc, but it is a daily workute. I just wanted to try bigger rubber first.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 04-06-2012, 05:48 PM   #13
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Hey have you got a video you can post or any photos of launch or slow mos.
Just going by the photo of it sitting in the shed the larger tyre is sitting with a bit of camber with the top leaning in and bottom slightly out is this how it sits in real life and how does it look when the car is squatting in stage?
No sure if you can adjust the camber so they sit nice flat on the track when the car is squatting so you get maxium contact for launch.
I found using a shorter tyre made this possible with no adjustment required to my stock camber. Mostly reccomend to match the tyre width to the wheel width, but you can get away with slightly wider tyres then the rim as the other members have pointed out.
Just keep in mind if you go to wide and sticky expect to find your new weakest spot in the drive train.
Work out the best PSI for your setup and sometimes extra fuel can help keep the rear planted which may give you a better ET and 60 foot then a lighter load.
Also look at running a stock wheel and small tyre on the front even a set of worn stockies pump pumped up hard will help.
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 06:25 PM   #14
XT302
Have a look down two threads (at moment) raging rhino my last post links to photo. Car running these exact slicks on a 8" rim .
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 06:37 PM   #15
xr6t_ute
xr6t_ute's Avatar
Yeh i dont have any video footage that i can look at, hopefully someone can take a close up shot at heathcote so it can be looked at and go from there.
As for the tyre leaning, i think thats just how the body is and also the offset of the tyre, and being a leaf spring rear end theres not much squat, if it was a sedan it would be alot easier to launch, and run 1.5 tenths quicker from being 70kg lighter than a ute.
http://www.fordforums.com.au/attachm...1&d=1338795523
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 05-06-2012, 03:15 PM   #16
Giant
Giant's Avatar
Paulie Parsac might be able to give you some tips relating to leaf springs and drag racing. Him and his brothers are getting the carpi down the strip in 8 odd seconds consistantly. using standard rear leaf springs.
Old 05-06-2012, 03:49 PM   #17
prasac
prasac's Avatar
video of our tyres, 275 radial 1.33 60' http://www.youtube.com/watch?v=78VGsmQry7Q this one might be better can see more of the body and video from side http://www.youtube.com/watch?v=I-ODlOTc7-U
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2012, 04:36 PM   #18
prasac
prasac's Avatar
we ran similar Hoosier's are these the DOT Radial (2 lines down centre) or full slick? we had the DOT Radial pretty much a slick, we ran on a 10'' wheel you can use an 8''. i think the best we ever 60'd with them was like a mid 1.3 they were difficult to find the right pressure with when we thought we had it, then it would change it's mind when these wear out try M/T's most people including ourselves tend to have more success, we found half a tenth in the 60' straight away. found an old video with those slicks http://www.youtube.com/watch?v=1Z6sYt-V-0E
Old 05-06-2012, 05:13 PM   #19
xr6t_ute
xr6t_ute's Avatar
The hoosiers i bought are a full slick, will give that a go this weekend and see how the 60ft is, and i guess go from there.
I wish my ute holds tight on the the 60ft like yours does..lol
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 05-06-2012, 05:28 PM   #20
prasac
prasac's Avatar
we run the caltracs that is about it. ur pushing about 900lbs more than us also, though in saying that i have seen 4000lb cars 60' 1.2-1.3's. alot of people criticise leaf spring rear ends but they aren't that bad, if you can get them to work they are good. i know we tried a couple different sets of leaf springs to see which worked best.
Old 05-06-2012, 05:32 PM   #21
xr6t_ute
xr6t_ute's Avatar
I just want to get in the 1.5's and consistantly, managed 1.62's previously so il have to see if the wider and taller rubber works in my favour.
Nothing more frustration than having a tyre hook up one time then not then the next run. Its like russian roulette.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 05-06-2012, 05:33 PM   #22
xr6t_ute
xr6t_ute's Avatar
Race weight is 1890kg according to the weighbridge.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 05-06-2012, 05:44 PM   #23
prasac
prasac's Avatar
it takes time, we have been chasing it 18 months now it's not easy especially if you're pushing it, we can 60' 1.28 on a slick and 1.33 on a radial consistently, but, the thing is we aren't pushing it, we don't want to waste a run you need to find a happy medium, trying to find too much on the 60' can cost you, i'm not sure what or how u set up the boost controller if it gradually feeds in or all comes in at once, what you lose in the 60' you may gain somewhere else.
Old 05-06-2012, 06:20 PM   #24
xr6t_ute
xr6t_ute's Avatar
Yeh maybe il see how it goes this week and try and make the boost come in softer down low in the tune itself, as everythings just off the std pcm.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 05-06-2012, 08:31 PM   #25
dalts
dalts's Avatar
Good luck at the drags!
Those tyres fit nicely looks like I'll have to take mine back up to stock height to get some decent rubber under the back!!
Tuned by
Old 05-06-2012, 09:44 PM   #26
xr6t_ute
xr6t_ute's Avatar
Yeh cheers, i would say a 29 x 10.5 would even fit at the stock height.
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 09-06-2012, 01:04 AM   #27
allmtr
Good luck this weekend, mate!!!
allmtr is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2012, 01:09 AM   #28
xr6t_ute
xr6t_ute's Avatar
Thanks new pb 10.68 .. Trans slipping, it doesn't like these slicks
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
Old 09-06-2012, 09:38 AM   #29
XT302
AWESOME on new PB.
Why do you say doesn't like these slicks?
Old 09-06-2012, 11:29 AM   #30
prasac
prasac's Avatar
congrats on the PB. did you remember to take all the tools etc out the back
