Old 15-12-2011, 01:13 PM   #1
prasac
prasac's Avatar
Default E85 vs THE REST!
i thought i would do a little write up about what we have found about this pump wonder fuel. for the last 18+ months ourselves and alot of friends have changed to this fuel. street to race cars included NA, Blown, Turbo, NOS cars. some changing from full on race fuel others from premium unleaded, the results were unanimous E85 bettered all of them. all the people i have spoke to have had no issues with fuel lines, filters etc. we have heard people saying it's difficult to run a car on NOS with it. the 2 NOS cars i know using it also don't report any issues.
the first car we changed was the brother's 3L 2JZ 80mm turbo powered, Powerglide gearbox Toyota Corolla, the little nugget was pumping out 770rwhp@32psi on C16, ran a 8.4@159mph best. the fuel we were using was just plain bowser pump E85 straight from United Petroleum @ Rozelle. after a few baseline runs on E85 the first power run showed 820rwhp@32psi, torque was also up 70ft/lbs. we weren't expecting such a big power difference considering C16 was a 116-octane. who would have thought a $1/L fuel could outperform a race ruel costing 10 times more. we had to put the timing down a little but the power was still there after putting boost up to 36psi we ended up with 890rwhp. a pick up of 120rwhp with E85 and 4psi we feel it would have made more power than it did but the turbo was out of puff, the turbo was rated 1100-1200hp 2 the motor. we found the car sounded crisper, better throttle response, car boosted quicker and much better smelling fumes. first pass out the car ran a 8.0@174mph. 4/10th and 15mph quicker.
next car we did was the other brother's 4L Twin 62mm Turbo V8 Capri, Powerglide box. we have played around with a variety of different fuels in this car ran 9.0@151 on BP 98 Premium the car made 675rwhp/680ft-lbs torque on 22psi.
for this first time on E85 we went a race mix drum E85 from Platinum Racing Products. once again the E85 lived up to expectation. 4 degrees more timing on the same boost 730rwhp with just the E85 change. on 27psi it made 800rwhp, however, we could tell by the graph that the turbo's were choking as the power was rolling over very early. after an exhaust housing change and adding a CDI for better spark (a very good ignition is needed for cold fuels) we ended up with 910rwhp@30psi full exhaust, with twin cats. picked up over 100ft/lbs of torque. has to date ran a best of 8.20@166. picked up the same benefits as we did with the Corolla. engine note was just that much better.
we had an E85 tune to race on and a BP98 tune for the street. we then decided to completely change the Capri to E85. we weren't going to use race E85 on the street as it was double the price, even though we averaged quite good fuel consumption been averaging around 12-15L/100km.
first pump E85 we chose was the Caltex E-lex as it was more accessible, power showed around 800rwhp, we didn't get to race it on 30psi with the E-flex because the E85 changed consistency. i bought the first drum of E-flex tested it and it was around 85%, then the next time we filled up when going to race we bought was 72%. because it was Winter blend, (they add more gasoline to the mix to make the cars start easier in Winter) the car was running fat as a pig with the E72 in there.
we did however race it on low boost E-Flex VS BP98. on BP98 22psi we ran 9.0@151 on the E-Flex because of the extra torque thru the whole rev range, we could run 9.0@152mph on only 18psi.
had we first tuned the car on the E72 and put E85 in there was a possibly of hurting the engine (will get to that later). for under $30 it's worth buying a tester, here is a link to the one we use http://www.quickfueltechnology.com/s...test-tube.html also get a couple of 20-50ml syringes, makes things easier when you need to add the fuel and water to the test tube. the syringes are only a $1 or $2 from a chemist. also a good purchase would be an air fuel meter, for around $300 you can buy a really good one, they are very simple to setup in your car. we have one installed in the car, its an NTK AFX it has a 5-wire sensor, cost around $320 delivered from the US. here is the meter in work in the car. as u can see they are very responsive and a good idea to have http://www.youtube.com/watch?v=0Mp433TOz5k
so after the E-flex fiasco we decided to go with the United Pretroleum E85 from Rozelle here in sydney. same fuel that we ran in the Corolla. so far that has been brilliant. on 30psi the car makes around the same as it did on the E-Flex just slightly more torque. out at the track the car has run a best of 8.37@164mph. it is extremely consistent in cold and hotter weather. also on the street it drives much cooler about 10-20oC.
both cars use Speedflow 100-series braided rubber fuel lines, Bosch 044 pumps and Speedflow fittings. absolutely no problems or leaks since using it. the fuel even sat in the Corolla for over 3 months before going out with it again. it didn't corrode or eat anything. car went out and ran an 8.1 but we hurt the engine. initially we thought an injector failed, but after further investigation it was a NOS problem that torched the head, so we can't contribute that to the E85.
i know many cars in the US that have ran E85 for years using factory lines and haven't had a problem. after changing to E85 for the first time you should change the fuel filter after 2000-5000km's, as the E85 tends to ''clean'' your fuel line to a certain degree. after the first fuel filter change it will be fine.
the good thing about E85 is it is a very strong fuel and u really have to mess up bad to hurt an engine. we have run the AFR's as fat as low 10's and as lean as 14.0 and the power difference was minimal. we were quite shocked on the 14.0 AFR the car didn't pop, ping, nose over or anything it just ran like normal only 1/10th and 2mph slower than it's perfect tune.
here is a show of the log pretty much the whole run the car ran around 14.0 AFR, we still don't know why it leaned out so much. FR1 is the AFR line.
we have found AFR's around mid 11's to be the best on our cars, same like a little leaner some a little fatter. usually around a 7-8% difference in ethanol content you won't see much of a change. we have run E82 and E90 so if ur worried about consistency don't be too much. as said before ethanol has a very good detonation resistance and with AFR's. driving on the street you won't notice too much of a difference. at WOT an 11.7 AFR may go to 12.5 with the ethanol content difference.
alot of people have wondered can E85 also be used without an intercooler etc, how much boost can be run. yes, it can be done. i am considering tuning my own car on E85 without using an intercooler. cars in the US have been doing it with great success for a couple years. no the cooling effect of ethanol isn't anywhere near as good as methanol but it can still be done. run the car fat enough usually mid 10's AFR and it will cool the intake air temps down enough to run high boost and still make alot of power.
feel free to add your own results, i'm surprised there hasn't been a thread for E85 results done yet.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 02:01 PM   #2
graham_h
graham_h's Avatar
Default Re: E85 vs THE REST!
Great info.....so generally which servos sell it ?
graham_h is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 02:06 PM   #3
prasac
prasac's Avatar
this list was done at the start of the year. should be more stations and shops supplying it now.
PUMP Fuel
QLD
E-Flex Caltex Cnr Finucane Rd & Cambridge Dr,Alexandra Hills QLD,,(07) 3824 0311
E-Flex Caltex 1015 Mt Gravatt-Capalaba Road,Mansfield QLD,,(07) 3849 1133
E-Flex Caltex 126 Warwick Rd, Churchill, QLD, 4305,,07 32021377
E-Flex Caltex 7001 Augusta Parkway,Augustine Heights QLD,,(07) 3814 6486
E-Flex Caltex 10 Third Ave Cnr Browns Plains Rd, Marsden, QLD, 4132,,07 38034600
E-Flex Caltex 152 Smith St Cnr Kumbari Ave,Southport QLD,,(07) 5591 7120
E-Flex Caltex 1 Mudgeeraba Rd, Worongary QLD,,(07) 5569 2359
NSW
E-Flex Caltex 59-63 Tudor St Cnr Gordon Ave,Hamilton NSW,,(02) 4961 2753
E-Flex Caltex 69-71 Pacific Highway, Gosford West (East Bound) NSW,,(02) 4325 7456
E-Flex Caltex 98 March St Cnr East Market St, Richmond, NSW, 2753,,02 45885827
E-Flex Caltex 86 Pittwater Rd,Manly NSW,,(02) 9977 2863
E-Flex Caltex 309 Victoria Rd,Rydalmere NSW,,(02) 9638 1932
E-Flex Caltex 191-195 Lyons Rd,Drummoyne NSW,,(02) 9713 7265
E-Flex Caltex 775 Princes Hwy,Tempe NSW,,(02) 9573 1069
E-Flex Caltex 216 Newbridge Rd, Moorebank, NSW, 2170,,02 96028263
E-Flex Caltex 646 Hume Hwy,Casula NSW,,(02) 9602 8482
E-Flex Caltex 1403 Princes Hwy, Heathcote, NSW, 2233,,02 95205697
E85 Shoalhaven 663 Warringah Rd,Forestville NSW
E85 Shoalhaven 251 Princess Hwy,Albion Park NSW
E85 Shoalhaven 215 Kinghorne St,Nowra NSW
E85 United 127 Victoria Road,Rozelle NSW
E85 United 2 Rawson Rd, Guildford NSW,,
ACT
E-Flex Caltex Curran Dr,Cnr O'Hanlon Pl,Nicholls ACT,,(02) 6242 0742
E-Flex Caltex 150 O'Halloran Circuit,Kambah ACT,,(02) 6231 7177
VIC
E-Flex Caltex 66 Bell Street,Yarra Glen VIC,,(03) 9730 1466
E-Flex Caltex Cnr Barrys Rd & Hume Hwy,Campbellfield VIC,,03 93579470
E-Flex Caltex Cnr Melton Hwy & Gisborne-Melton Rd,Kurunjang VIC,,(03) 9747 6688
E-Flex Caltex 575 Melton Hwy, Hillside, VIC, 3037,,(03) 8390 9458
E-Flex Caltex Sharps Rd & Assembly Dr, Tullamarine VIC
E-Flex Caltex 349 Plenty Rd,Northland Centre VIC,,(03) 9471 7026
E-Flex Caltex 346 Main Street,Lilydale VIC,,(03) 9735 1915
E-Flex Caltex 82 Gordon Street,Footscray VIC,,(03) 9318 6514
E-Flex Caltex Canterbury Rd Cnr Gatwick Rd, Kilsyth, VIC, 3137,,03 9761 4700
E-Flex Caltex 622-626 Blackburn Road,Mt Waverly VIC,,(03) 9562 5407
E-Flex Caltex 409 Clayton Rd Cnr Centre Rd,Clayton VIC,,(03) 9543 9496
E-Flex Caltex 154-172 Springvale Road,Springvale VIC
E-Flex Caltex 841 Nepean Highway,Cheltenham VIC,,03 5975 8444
E85 United 160 Old Geelong Road,Hoppers Crossing VIC,,(03) 9748 3601
SA
E-Flex Caltex 1916 Main North Road,Brahma Lodge SA,,(08) 8258 1280
E-Flex Caltex 1129-1131 South Road,St Marys SA,,(08) 8277 1170
E-Flex Caltex Cnr Panalatinga & Bains Rds,Woodcroft SA,,(08) 8325 1925
E85 United 169 -171 Tapleys Hill Rd,Albert Park SA
E85 Unknown Salisbury Highway,Green Fields SA
E85 Unknown 646 Marion Rd,Park Holme SA
BULK Fuel
QLD
E85 Elf Racing Fuel Motorsport Fuels QLD,45 Southerden St,Sandgate QLD 4017,,(07) 3269 6823
E85 PowerPlus Racing Fuel DCR Fabrications,71/193 South Pine Road,Brendale Qld 4500,,0414 308 447
E85 PowerPlus Racing Fuel Marinelli's Mechanical and Performance,25-27 Belar St, Yamanto QLD,,07 3812 7725
E85 Sucrogen Racing Fuel Brinks Performance,19 Yarrowee Street Currajong Qld 4812,,07 4779 8288
E85 Sucrogen Racing Fuel Mercury Motorsport,2 / 278 Newmarket Road, Wilston QLD 4051,,1300 558 650
NSW
E85 Cheetah Racing Fuel Sutto's Motor Cycles,141 Blaikie Rd,Jamisontown NSW 2750,,02 4737 9566
E85 Elf Racing Fuel Black Hill Transport,98 Browns Rd,Black Hill NSW 2322,,(02) 4930 3132
E85 Elf Racing Fuel MRT Performance,1 Averill St,Rhodes NSW 2138,,(02) 9767 4545
E85 Platinum Racing Fuel Envy Imports,20 Roger Street Brookvale, NSW,,02 9907 4144
VIC
E85 Cheetah Racing Fuel Violet Town Garage and Engineering,2 Cowslip St,Violet Town VIC 3669,,03 5798 1452
E85 Cheetah Racing Fuel Bendigo Tyre Centre,4A Wood St,Long Gully VIC 3550,,03 5444 1545
E85 Cheetah Racing Fuel Chip Control,6/57-59 Horne St,Sunbury Vic 3429,,(03) 9740 3363
E85 Cheetah Racing Fuel Yarra Valley 4WD,35 Maroondah Hwy,Healesville VIC 3777,,03 596 23 124
E85 Cheetah Racing Fuel Coxy Motorsport,31B Clements Avenue, Bundoora VIC 3083,,(03) 9467 8900
E85 Cheetah Racing Fuel Just Fuel Petroleum,2 Western Av,Sunshine VIC,,03 9312 4788
E85 Cheetah Racing Fuel Alfa Petroleum,962 Burwood Hwy,Ferntree Gully VIC 3156,,(03) 9758 8956
E85 Cheetah Racing Fuel Sofair Petroleum,100 McKinnon Rd,McKinnon VIC 3204,,(03) 9576 9159
E85 Cheetah Racing Fuel Ausfield Lubricants,1/36 Mickle St,Dandenong South VIC 3175,,03 9768 3532
E85 Cheetah Racing Fuel Octane Alley,135 Victoria St,North Geelong VIC 3215,,(03) 5278 9000
E85 Cheetah Racing Fuel LV Dyno Centre,19 McMahon St,Traralgon VIC 3844,,03 5176 2257
E85 Cheetah Racing Fuel Independant Motorsport,3/32 Vestan Dr,Morwell VIC 3840,,03 5134 8822
E85 Elf Racing Fuel Race Fuels Pty Ltd,18-24 Moray St,South Melbourne VIC,,(03) 9686 8645
E85 PowerPlus Racing Fuel Cnr Nepean Highway and Bay Road VIC
E85 PowerPlus Racing Fuel Moe Engines Pty Ltd,121 Moore Street Moe,Vic 3825,,(03) 5126 1222
E85 PowerPlus Racing Fuel ACB group,118 Swann Drive,Derrimut Vic 3030,,(03) 9369 0220
E85 PowerPlus Racing Fuel VPW Australia,122-128 Cooper St,Epping 3076,,1300 659 904
E85 Sucrogen Racing Fuel John Duff & Co,52 Sybella Ave, Koo Wee Rup VIC,,03 5597 1277
E85 Sucrogen Racing Fuel HP Heaven,525 Somerville Road Sunshine VIC 3020,,(03) 9312 4555
E85 Sucrogen Racing Fuel Herrod Motorsport,103 Northgate Drive Thomastown VIC 3074,,03 9464 5100
SA
E85 Elf Racing Fuel Watsons Express Transport,84-86 Wingfield Rd,Wingfield,SA 5013,,(08) 8244 5455
E85 Elf Racing Fuel Performance Fuels,3 Ledger Rd, Beverly SA 5009,,1300 726 084
E85 PowerPlus Racing Fuel Scotcher Race Fuels & Oils,3 Senna Rd, Wingfield SA,,(08) 8262 2200
WA
E85 Cheetah Racing Fuel K TEC Automotive,72 Howe St,Osborne Park WA 6017,,(08) 9227 8911
E85 Elf Racing Fuel Race Torque Engineering,16 Action Pl, Wangara Perth WA 6065,,(08) 9302 6388
E85 Elf Racing Fuel Watsons Express Transport ,140 Welshpool Rd, Welshpool WA 6106,,(08) 9258 4855
E85 PowerPlus Racing Fuel Jas Performance,5 Weema Court,Swan View WA 6056,,0412 074 003
E85 Sucrogen Racing Fuel Racing Performance Works,50 Gordon Road (East) Osborne Park Perth WA 6017,, 0618 9443 1719
E85 WA Race Fuels A1 High Performance,4/49 McCoy Street Myaree WA 6155,,08 9330 1418
E85 WA Race Fuels Chris Mills Performance,25 Ballantyne Road Kewdale WA 6105,,089353 1155
E85 WA Race Fuels Lost Racing,2/1 Port Kembla Drive Bibra Lake WA 6163,,08 9494 2210
E85 WA Race Fuels Kostecki Engine Centre,93 Mulgul Road Malaga WA 6062,,08 9209 1222
E85 WA Race Fuels Australian Industrial Equipment,Lot 61 Halifax Drive Bunbury WA 6230,,08 9725 6788
TAS
E85 Cheetah Racing Fuel Independent Oils,8 -10 Trevor St,Ulverstone TAS,,(02) 4930 3132
E85 Elf Racing Fuel Devonport Performance Tyres & Fuels,168 Tarelton St, East Devonport TAS 7310,,(03) 6427 0700
E85 PowerPlus Racing Fuel Boost Automotive,123 Invermay Rd, Invermay TAS,,(03) 63 344 011
Old 15-12-2011, 02:09 PM   #4
graham_h
graham_h's Avatar
Any benefit running it in a stock 6 ? Probably better economy ?
Old 15-12-2011, 02:20 PM   #5
prasac
prasac's Avatar
E85 tends to use 30% more fuel during WOT, so you will need to upgrade fuel pumps and injectors. everyday normal driving it's around 10-20%. at only $1.10/L here in Sydney vs $1.50/L for BP98 it works out a little cheaper.
will run cooler, make 5% or so more power, definitely worth considering.
Old 15-12-2011, 02:30 PM   #6
63futura
63futura's Avatar
One day we will hopefully see it at the bowser over here in the west
As soon as we do im switching straight away
Did you have to go any bigger in fuel lines / injectors or pumps ?
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 02:39 PM   #7
prasac
prasac's Avatar
it's just a great fuel.
fuel lines stayed the same. -6 or -8 is plenty big. injectors you will need bigger by at least 30%. both cars have 3 x Bosch 044 pumps. the Bosch pumps are good for 700hp gasoline each. 3 x Bosch 044 would be good for 1400hp @ motor.
when the Corolla had 2 x Bosch 044 it was running out of pump around 800rwhp.
Old 15-12-2011, 03:01 PM   #8
blueoval
Critical Thinker
blueoval's Avatar
prasac - great post mate. I too have had good results with no notable detrimental effect on parts, or the way it runs. I've been running my car on it for 18months now. I think it could be longer iirc. But the bottom line is, it has worked awesomely for me and I save about $10-15 a tank when I fill up.
I use Caltex E-flex at my local in Woodcroft in SA. Some of you already know I run a s/c with low boost (7lbs) on a stock 6 engine, I run a Walbro 255lt/hr fuel pump and 36lb injectors and run a blend of about 40% Eflex and 60% 98 from the same place. The 98 at Caltex has 10% Ethanol added to their fuel so it makes no difference to me. Found I felt the car gain more torque from the E-flex compared to the straight E85 from United. This is a seat of the pants feeling so I have no figures backing it up. But I also went Eflex due to it being so close to home rather than trekking 20km out of my way to fill up.
Again, no issues to date. I have recently swapped my fuel filter over 'just in case' and found in the old filter, it looked dead clean. No sign of muck, gunk or grit to be found from the old filter. I was surprised.
I understand some are apprehensive about running E85 but I have found pretty good benefits not just in power but it works out a bit cheaper for me at the pump too.
I must stress though, anyone who is considering it, a tune is a MUST. DO NOT attempt to put E85 in your tank without first consulting your tuner and getting the right hardware fitted to your car as well as a custom tune to run the car.
otherwise I recommend it for all boosted and moderately modified cars as either an occasional option or as an everyday option like I am.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 03:44 PM   #9
graham_h
graham_h's Avatar
Why can't you put e85 straight in ?
Old 15-12-2011, 03:47 PM   #10
prasac
prasac's Avatar
yeah, i should have stressed the fact also.
what it is made of also comes into play, the sugar cane ethanol is a little better than the wheat one etc. but, the difference is nothing major.
Old 15-12-2011, 03:51 PM   #11
prasac
prasac's Avatar
30% more E85 is needed to run the car, so, you can't run E85 without a tune. you may also need a bigger fuel pump, injectors etc.
the energy 1L of E85 releases is 30% less than that of 1L of gasoline.
Old 15-12-2011, 03:55 PM   #12
blueoval
Critical Thinker
blueoval's Avatar
Backing up what Prasac said:
First of all, E85 is thicker in consistency than regular fuel. Second your standard fuel pump wont be able to handle the thickness and in turn due to its thickness you need to pump a lot more into the engine to get the amount of 'bang' required to get the engine moving. Due to the thickness also, your injectors won't be able to cope as well either. The ecu will need to be retuned to accept the new fuel as well. Fuel line thickness will need to be upgraded to feed the engine. The fuel consumption is more than regular fuel due to the thickness and consistency of it.
I run a 40% blend due to my fuel lines and current size of the injectors aren't able to cope with the demand required. My after market fuel pump is fine though. I was told a minimum of 60lb injectors are required along with bigger fuel lines are what is needed to fun straight E85.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 15-12-2011, 04:39 PM   #13
trbo 6
When you say it is thicker are you saying that it has a higher viscosity? Or it is more dense? Because E85 has a lower specific density than unleaded.
Oh and the Caltex Great Western Highway Greystanes NSW has E-Flex
trbo 6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 04:45 PM   #14
prasac
prasac's Avatar
who told you that? what size are the fuel lines? there is 2 x -6 on the 6-cylinder making about 1150hp @ motor on E85. that is about 1500hp gasoline. fuel pressure sits on about 50-60psi.
get 20L of gasoline and then get 20L of E85 put them in a drum and measure.
Old 15-12-2011, 04:58 PM   #15
graham_h
graham_h's Avatar
Interesting reading....so $20 of e85 mixed with e10 to the brim ? Good idea ?
Old 15-12-2011, 05:01 PM   #16
FreddyDUZ747
FreddyDUZ747's Avatar
Smile Re: E85 vs THE REST!
Thats as good a idea as the Ford pos KA,not cool man
Try $19.50 of E85 instead of $20
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 05:02 PM   #17
prasac
prasac's Avatar
too much, i put 5L of pure ethanol E100 in my Aurion with 50L of Caltex Vortex 98. i wouldn't go much over that.
Old 15-12-2011, 05:05 PM   #18
graham_h
graham_h's Avatar
Ok I'll give it a go this weekend....600k trip...see how it goes
Old 15-12-2011, 05:08 PM   #19
CFOUR
The Destroyer
CFOUR's Avatar
Great write up, there's enough text there to fill a book.
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 05:09 PM   #20
prasac
prasac's Avatar
you will use more than normal.
Old 15-12-2011, 05:19 PM   #21
blueoval
Critical Thinker
blueoval's Avatar
My tuner Bruce told me this. We didn't discuss the line sizes or pressure rates. Be interesting to find out what these 1150hp engines are running in the way of line sizes mate.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 15-12-2011, 05:21 PM   #22
blueoval
Critical Thinker
blueoval's Avatar
Use it with caution and at your own risk. I personally wouldn't try it without first speaking to a tuner who knows the fuels. Be warned also, the servo attendant will ask you if you have your car tuned for it too when you rock up and pay for it.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 15-12-2011, 05:26 PM   #23
prasac
prasac's Avatar
2 x -6 on the Corolla and 2 x -8 on the Capri both run around the same pressure. i will be running 2 x -8 fuel lines on my drag car which will be making around 1500hp on methanol, which equates to enough flow for 3000hp on gasoline.
i'm not sure what your tuner is telling u about it being thicker. as i said get 20L of E85 and 20L of BP98 etc and measure how high they sit. if e85 was alot thicker the drums wouldn't be the same size.
1 gallon of gasoline produces 114,000 BTU's
1 gallon of E85 produces 76,000 BTU's
that is why 30% bigger injectors and fuel pumps are needed.
Old 15-12-2011, 05:48 PM   #24
blueoval
Critical Thinker
blueoval's Avatar
The calcs sound right mate. Just going off what I was told. I have a feeling I would max out my current injectors long before the line was going to be a problem anyway. I don't know what size lines I have as it is now. But I was lead to believe the lines needed up sizing due to the consistency of the liquid being thicker. I may be confused with something else if what you say is true. But If I am wrong, I am wrong, and happy to admit that and move on.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 15-12-2011, 07:47 PM   #25
FreddyDUZ747
Shav,my lines on the BA are the same as the AU by memory and mine are good for 450rwkw+ on E85.You know where she is tuned
Old 15-12-2011, 10:57 PM   #26
graham_h
graham_h's Avatar
Interesting video Here... audio sounds like a pig drowning but you get the idea.
Bit of reading I've done...seems the standard injectors and pump are ok provided they're in good order.
Obviously for added performance injectors and pump would be the go.
Be real interesting to hear from some tuners as to their viewpoint
I'd like to see a 5.0ltr supercharged tuned for it
Old 15-12-2011, 11:44 PM   #27
ebxr8240
Performance moderator
ebxr8240's Avatar
SEEMS N20 doesn't have the same effect ???
Mate used it on his last run with std engine..
Sounded better but did same times..
I guess there's already plenty of oxygen in the fuel !!!
Daily driver GTE FG..
Old 15-12-2011, 11:50 PM   #28
prasac
prasac's Avatar
purchase new injectors there is no point doing the change if you don't. if you have injector for 500hp and your car now makes 400hp on BP98 for example you won't have enough injector for a switch to E85 and make that power.
Old 15-12-2011, 11:56 PM   #29
madwag
madwag's Avatar
so how long would it take to break even after having all the work done on the car to have it run on E85?
WTB. Black BF front door trims, BF wagon books, terry ducting.
The Daily's Build.
http://www.fordforums.com.au/showthread.php?t=11349360
Weekender: '69 VW Notchback
http://www.fordforums.com.au/showthr...24#post4531824
madwag is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 11:56 PM   #30
prasac
prasac's Avatar
did he re-jet the NOS setup for E85 or just use the same as he had before?
doesn't seem right that he didn't pickup.
