Old 28-11-2011, 03:38 PM   #1
baz
Default Air Conditioner
Does anyone know an easy way of checking the air con to see if it needs gas. mine is cool but I think it could be colder, My Celica used to have a sight glass to look for bubbles but my 2001 cat dosn't seem to have one.
Baz
baz is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 05:15 PM   #2
thearrow
Default Re: Air Conditioner
Baz....just had mine regassed last week. If it isn't "cold" then it needs re-gassing or alternatively it has a leak in the system somewhere.
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 10:20 PM   #3
REDDYZ
REDDYZ's Avatar
Being the owner of your car, you are the best person to judge it. If you think its not getting cold enough as it use to.. then it needs re-gas. There is no other easy way to check. Take it to a/c specialist and they can hook up gauges and check if it is low on gas. If they are genuine, they will tell you the truth otherwise they will book you for air-con service. Irrespective of season, you have to use a/c in the car atleast once a week. Otherwise, the system will lose pressure and gas along with it, just like the tyres losing pressure if you don't drive for a while.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 10:36 PM   #4
XARATE
XARATE's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Quality contribution which has gone somewhat un-noticed so far.
An aircon service isnt a sign of dishonesty.
A proper service includes:
- a change of gas. It does break down similar to the way engine oil does and it can become contaminated with metalic particles from the compressor and rubber from hoses
- a new reciever drier. Vital in keeping moisture out and assists in filtering the gas
- cleaning of the condenser and the space behind it. It is very very common to have a large amout of contaminates between the radiator and condenser which causes low airflow and reduces aircon efficiency
- Cleaning or replacing of the cabin filter/pollen filter
- cleaning, disinfecting and deoderising the air ducts using equipment that reaches places you will never see. Removes possible health hazards too
- inspection of all hoses for possible signs of premature wear, rubbing, abrasions, cutting, kinking, crushing or delamination.
An ac system service is always a great idea to have your system working at its full potential
270rwkw BA XR8
http://www.fordforums.com.au/showthread.php?t=11339147
XARATE is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 10:52 PM   #5
REDDYZ
REDDYZ's Avatar
I didn't mean that way. if it sounded that way and offend anyone. I was referring only in terms of checkup only, not service exactly. You gave a good summary of service. I think its mandatory to replace the receiver drier. However, not many does all the above. Next time I take mine for service I should demand for last two points you made. cheers mate.
Old 28-11-2011, 10:54 PM   #6
scout
Just to clarify the reason you run an AC unit often, is to keep the shaft seal lubricated. A dry seal may leak and may wear out early. Modern AC systems are better designed than the old clunkers.
scout is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 10:57 PM   #7
XARATE
XARATE's Avatar
Dont stress nate no offence taken. I just thought i'd add the info to help give an idea of what should be done in a service rather than the usual repair and regas
270rwkw BA XR8
Old 29-11-2011, 06:23 PM   #8
baz
Thanks Guy's, I didn't want to start any arguments, I just wanted to know if there was a sight glass for checking air bubbles in system. It is cool but I think it was colder last year
Old 29-11-2011, 09:49 PM   #9
philfree
hi
i work for ac place when we do a ac service we replace the reciver drier (whitch should be replaced everytime the system is opened) clean condensor and check the operation wether it's ok a generly a good look around for any obvous look at me faults. on another note if a ac system is low on gas it has a leak and legaly ac places are required to make a concerted effort to find the leak if their is none found a service is done dye is added for those real hard to fund leaks if the leak is found then must be repaired before they can gas it up. if you do get a regas rember that the leak will keep looseing it so it will need gas again at some stage and it will probly leak more as time goes on.
2000 AU II Fairmont Ghia with tint, stero, Tickford body kit, 17in mags
2000 Nissan Patrol ute 4.2 td with 155rwhp
1982 Mitsubishi l200 express 4x4 converted to home built buggy 2.6 efi with megasquirt ecu
philfree is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2011, 10:49 AM   #10
baz
Originally Posted by philfree
hi
So what would a service of this kind cost?
Old 02-12-2011, 10:27 AM   #11
baz
Hi guy's, just wondering what a service or regas od the A/C should cost, I was quoted $160 just for a regas.
Old 02-12-2011, 02:57 PM   #12
thearrow
That sounds about right. When I had mine done of course they found something else wrong with the switch that turns it on and off (apparently it was overheating) so that was extra.
