Old 25-04-2011, 07:02 PM   #1
blueoval
Critical Thinker
blueoval's Avatar
Default headlight globe removal and replacement
Hey guys I'm in the middle of replacing one of my head light globes on my car. I've tried to do search of past threads on removal and replacements of them. Can someone direct me to it please, or provide me with some advice.
The hardest part is getting my head around the circlip and how it works as well as replacement of the parker globe. I hear its integrated to the head light. Is this true? Is there an easy way to remove this?
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2011, 07:11 PM   #2
philfree
Default Re: headlight globe removal and replacement
the Parker bulb is removed separately from the main h4 bulb it just pushes in and if u pull on the wires it come out the only hard part is getting it back into its spot when ur putting it back together. the main h4 bulb their is a trick to removing the plug if you push at the to flat parts opposite each other it will release and come off the clip if you push it in and on a angle it will come off and push it in but opposit angle it will lock in again with the new bulb in .
2000 AU II Fairmont Ghia with tint, stero, Tickford body kit, 17in mags
2000 Nissan Patrol ute 4.2 td with 155rwhp
1982 Mitsubishi l200 express 4x4 converted to home built buggy 2.6 efi with megasquirt ecu
philfree is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2011, 07:43 PM   #3
blueoval
Critical Thinker
blueoval's Avatar
Cheers mate. I worked out how to get easy side done ok. The hard part is on the battery side.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 25-04-2011, 08:16 PM   #4
GK
Walking with God
GK's Avatar
Indeed. Not much room to move there.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 25-04-2011, 10:05 PM   #5
blueoval
Critical Thinker
blueoval's Avatar
Too dark to do anything now. I'm gonna get me some bent nose pliers to help remove the parker globe. I'm gonna do it with the battery still in. If its too hard only then will I remove the battery.
I dont understand why Ford went away from the traditional twist style fittings. They were so much easier to deal with.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 25-04-2011, 10:34 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Whilst this is true - the AU has a bucket of room even on the battery side compared to an EF/EL!
I'm pretty sure when i looked after the cabs, I really did get a dollar for every time i changed a headlight bulb...
Oh and the AU's use H4's, the EL's use H1's from memory.
Old 26-04-2011, 10:25 AM   #7
blueoval
Critical Thinker
blueoval's Avatar
Thanks guys. Jobs done. No need for bent nose pliers or battery removal. Was able to coerce the globe out ok as well as the parker globe. Had the job finished within 15 minutes after all the other ancillary items were refitted I.e. s/c pod and catch can.
I now have some PHILIPS crystal vision bright white globes fitted.
I appreciate the advice and help.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 03-11-2019, 10:35 AM   #8
dovo
Made a quick video on how to remove the connector clip, just because I had so much trouble in the past (including breaking the globe mount away from the Headlight :(. Its easy to do right once you see where the clips actually are. https://youtu.be/xoQKNUFAz4Y
dovo is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2019, 11:40 AM   #9
Mechan1k
Mechan1k's Avatar
8 and a half year mine ... that's a good effort.
