I have a question regarding the bolt pattern/pcd of the wheels on the Fiesta WS (German) and the newer Fiesta WT (Thailand).
I'm sure the bolt pattern/pcd of the WT is the same as the WS because the european 7-spoke alloy wheels are offered as an optional accessory on the Thai-made Fiesta in some markets, but some still claim they are different. I just want to confirm with WS owners and WT owners. Do the wheels of the Fiesta WS and WT use the same bolt pattern/pcd? If they do, is it 4 x 100 or 4 x 108? |
Finally rollin on 20's
They are all 4x108
Fiesta ST..... Colorado Red...... SOLD Territory Turbo Ghia ..... Winter White SOLD - Good bye my little buddy!!!! K&N, F6 Snorkel, Debung, 20" Enix Turbine in Gunmetal, 7 seat rear springs. |
#3 | |||
I know there was Fiesta WT owner here and he put aftermarket wheels. I can't seem to find that old thread that had photos of his car (it was a black Fiesta hatchback, looked like a lower end model, probably a CL). |
#4 | |||
CURRENT: 2017 Escape Titanium 2.0L EcoBoost with Technology Pack in White Platinum PREVIOUS 2015 Fiesta ST / 2012 Focus Titanium / 2009 Fiesta Zetec / 2004 Fiesta Zetec |
Most say that the bolt patter/PCD is 4x108, but this guy claims that the Thai Fiesta has a bolt pattern/PCD thats 4x100.
![]() PCD of 100 is about 10cm, PCD of 108 is 10.8cm, so its should be almost 11cm if the PCD is 108. @dannyhilton, as an owner of a German Fiesta WS, what do you think? Same PCD or different? Last edited by AG3; 10-01-2011 at 12:39 AM. |
The PCD is measured from the outside of the bolt I thought? They are definately 108, who is claiming such tom foolery?
yep stems back to the old imperial measurement of 4x 4 1/4 inches... the focus and mondeo are 5x108. very hard to source a decent variety of wheels locally. there's plenty if you want to buy from overseas like i did.
Ex-ride: 2010 MB Mondeo - Panther Black - Just a little bit modified ![]() New ride: 2010 LV Focus XR5 - Moondust Silver - More mods than you can poke a stick at ![]() |
This a bit of a silly question but has anyone put in 225/40 18 inch tyres into a ws fiesta (I have a set of these) ? The us version has a 195/60 15 which is 615mm in height compared 637mm for 225/40 18. I believe the us version has slight different ratios in their gearbox. I do mostly freeway running so am not overly concerned about acceleration. The standard aussie 15 inch however has quite small tyres 576mm in height I think for. Is 60mm taller wheel and tyres a bit too much notwithstanding those in the us where it is only 22mm difference?
try this website for calculations... http://www.miata.net/garage/tirecalc.html
those sizes you mention make your speedo out by 3.6% (slow) meaning you are going to be going faster than your indicated speed. also something to consider, not sure what width tyre you are looking at, but the XR4 had 17" wheels 7.5" wide and had to have spacers put into the steering rack to stop the wheels scrubbing out inside the guards on full lock. made the turning circle like a cruise liner!!
Thanks mondo broady now I can throw away the casio. I was thinking 225 wide and 40% aspect on 18 inch. They're good brand name tyres and it would be a waste not to use such nioce tyres.
Turning circle is not too much of an issue as I live in a rural area. I think the latest fiesta has the rack limiter if you opt for the 17 inch rims. I am just wondering whether anyone has put such large wheels and tyres and what issues they have experienced. Last edited by Gh1; 10-01-2011 at 11:16 AM. |
haha can't believe i asked that after using the 225 in the wheel calculator!! doh!! like i said, you might find you have issues with the steering at full lock scrubbing the inside of the tyre?? i'd be checking that one with Ford if i were you?? for what it's worth, i think 18" on a Fez is overkill. The 17" on the XR4 look the ducks guts... not sure what the latest Zetec comes with, 16" or 17" and i reckon they look good....
you might find someone with a XR5 focus will take those tyres off you hands as that is what fits their cars...
#12 | ||
Yeah I think I'll give it a miss. Thanks mondo_broady!
#13 | |||
With a little research, the PCD is is measured from the center of the bolts. ![]() ![]() What do you guys think? |
#14 | ||
Have just purchased WT with aftermarket CSA's and they offer the following for the Fiesta as recommended by Ford, 4 stud PCD is 4/108 with 45 offset in sizes 15x6, 16 x 6.5 and 17x7.......... Zetec will be coming with 16's...........
Capri Car Club of NSW,
Keeping the Legend Alive since 1985 |
#15 | |||
![]() If only someone with a German WS could also post a photo with a ruler too, so we can see what a PDC of 108 looks like. PS: This guy from Malaysia installed 17 inch wheels with a PCD of 100 on his new Thai-made Fiesta. ![]() Last edited by AG3; 10-01-2011 at 09:17 PM. |
#16 | |||
#17 | ||
I know the dodgy ruler has some strange markings, but it is very accurate and shows pretty much spot on 108mm. This in on a 2009 WS Fiesta Zetec with 17" Ford Alloys.
And the wheels are so dirty as it's been flooding in Toowoomba today. Haha. ![]()
#18 | ||
Thailand Fiesta: bolt pattern/PCD 4x100(?)
![]() German Fiesta: bolt pattern/PCD 4x108 ![]() Looks like they're different. :( |
#19 | ||
Check this out, the bolts on the Thai-made Fiesta really look closer to the center (PCD 100?), while the German Fiesta has its bolts spread out a bit more (PCD 108).
![]() Whats odd, is based on this photo, the Thai-made Australian market Fiesta (WT) Zetec uses the wheels of the German Fiesta Zetec S (blue car above) ![]() Last edited by AG3; 11-01-2011 at 02:50 AM. |
#20 | ||
The Thread Killa
Doesn't make sense for Ford to manufacture different-sized wheel hubs and rims for the same car.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle |
#21 | |||
Any WT Fiesta LX owners here? The WT Fiesta LX appears to be using the same 15 inch wheels as the ASEAN Fiesta Trend. ![]() Can any of the WT Fiesta LX or CL owners check if your wheel's PCD is 100. Last edited by AG3; 11-01-2011 at 06:49 PM. |
#22 | ||
maybe someone who works ford ford can jump in and answer the question
#23 | ||
might i suggest it's possible those pics above of the red & blue cars are an optical illusion?? the one that looks to be smaller PCD is taken at the same level as the wheel and directly in front. the other two are taken from above and to the side of the wheels and perhaps giving the illusion of more "meat" between the centre cap and the bolt holes??
#24 | |||
![]() 10cm = 100mm = PCD 100. I guess the ruler doesn't lie. The Australian spec Thai-made Fiesta WT appears to be using the european model's PCD of 108. |
#25 | ||
@mondo_broady, this one is not exactly the same angle, but you can clearly see the difference of the PCD 100 wheels of the Thai-made ASEAN spec Fiesta and the PCD 108 wheels of the German Fiesta.
#26 | ||
only ford...
#27 | ||
My god, I wonder why they thought that was a bright idea? You'd think the whole 'One Ford' thing would be cutting down on such stupidity, surely it'd be more expensive to produce both the 100 and 108 spec PCD rather than just make 108 the standard?
Definitely a trap for people buying rims overseas.
#28 | |||
Looks like Thailand is producing 2 kinds of models, the ASEAN one with PCD 100 wheels and the Australian market WT with PCD 108 wheels. The ASEAN model is probably using Mazda 2 hubs (PCD 100?) I'm guessing the Australian model uses PCD 108 wheels because the German WS model sold earlier has PCD 108 wheels too... maybe so they can share the same wheel options or aftermarket wheels? I'm curious now about the 7-spoke wheels sold as an accessory in the ASEAN markets (see linke below), it looks identical to the wheels of the German-made Fiesta WS Zetec. http://www.ford.co.th/servlet/Conten...age&site=FTHEN Did Ford make a PCD 100 version of these wheels. Before I forget, thank you guys for replying. @dannyhilton, thank you for taking that photo with the ruler showing the PCD 108 wheels of the German Fiesta. Last edited by AG3; 15-01-2011 at 03:11 PM. |
#29 | |||
#30 | |||
By the way, I took a photo of the 15 inch ASEAN spec Fiesta alloy wheels, just in case you want to compare it (visually) to the 15 inch wheels of the Fiesta WT LX sold there. ![]() |
