Old 11-06-2010, 09:33 PM   #1
RPM351
Default Raging Rhino XYGT @ WSID!
Just ran a mates XYGT on wednesday night drags and ran a best of 11.5 @ 122 mph! car is powered by a 393ci clevo, 4spd Toploader and 3.25:1 gears using MT 235/60 radials, looking forward to going out again real soon with a better clutch and new shifter.Car weighs 1595kgs with driver.
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
RPM351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2010, 09:50 PM   #2
sgn_351
Congrats steve and ante! Good work boys
sgn_351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2010, 11:00 PM   #3
HP-0351
1409hp 1190lb.ft 18psi...
Sounds good Steve. Any pics?
Also how much power is that 393 putting out at the engine and or flywheel?
Cheers,
Roy
The Daily 2003 BA GT Falcon http://fordforums.com.au/showthread.php?t=11367185
The Weekender: 1971 Twin Turbo XY Falcon
http://fordforums.com.au/showthread....=twin+turbo+xy
HP-0351 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2010, 09:19 PM   #4
RPM351
Default Power
Roy,
The car has 404rwhp or approx 500hp odd engine! very nice package and very much a good all round street car.Sorry no pics but will be plenty of chances in the near future as we will keep racing it for a while yet.
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 14-06-2010, 01:44 PM   #5
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Nice work would love to see more cars like this at our drag nationals, the XY is every Ford fans favorite.
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 04:12 PM   #6
Dodge
i like to be stroked
Dodge's Avatar
what revs were u doing at finish line? i wonder what it would run with a 3.9 or 4.11 diff
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying "Damn...that was fun!"
Dodge is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 07:49 PM   #7
RPM351
Default RPM's ??
Engine turns 5100rpm accross the line
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 14-06-2010, 07:52 PM   #8
RPM351
Default Sounds good!
Would love to come down there for a drive and race it,have spoken with the owner and he is keen as well,would also like to race it at Calder.
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 14-06-2010, 08:05 PM   #9
SpoolMan
SpoolMan's Avatar
Need help with anything send me PM ..
Accommodation plenty in the town of Bendigo 15 min from the track.
www.wotif.com
register your interest here once you are 100% sure your coming..
http://www.fordforums.com.au/showthr...41#post3185641
[SIGPIC][/SIGPIC]
Old 18-06-2010, 01:24 PM   #10
jg33ht
Impressive time, what was the 60 foot and half track? What manifold are you running to fit under the shaker?
Top effort!!!
jg33ht is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2010, 11:23 PM   #11
RPM351
Running 1.8 odd 60 ft's
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 20-06-2010, 09:04 AM   #12
XT302
WOW AWESOME effort considering Stefans made 355rwhp on your dyno to run 12.92 @ 111 MPH on 5 slotters, 2.078 60' with similar car and combo (XYGT,393, toppie, 3.25s) which I thought was equally as good a effort.
I bet he will be keen to know what the secret/difference is for his silver bullet...
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2010, 04:53 PM   #13
RPM351
Default Similar but not the same!
Yes similar in they both share the same cubes,trans and diff gears and yes they are both XYGT sedans but it ends there....
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 21-06-2010, 09:01 PM   #14
XT302
OK...
I take it you want to share because you started the post (if started for bragging rights only thats cool too, definitely something to brag about), but a number of questions have been asked and left unanswered....eg manifold being run (Stefans runs modded cast iron, which would have it limitations)
It is very impressive on the limited info available.
I presume it is on pump fuel? and naturally aspirated (because if it is on the bottle less impressive in my opinion)
It is has made 44 rwhp than Stefan, so I dare say not only does it make more power but it makes it differently because going a "bigger" cam would be useless cosidering your stated 5100rpm over the line. (see Stefan graph below, impressive power curve at peak RPM)
I don't recall Stefan weight, but going by your quoted weight with driver wouldn't be "that" significant a difference comparing to other cars/XY's I have seen on the scales.
So I have to presume "again" the differences being in suspension set up? because we have both mentioned the different tyres being used.
cheers.
Old 21-06-2010, 10:00 PM   #15
Stefan
Stefan's Avatar
It's all about compromises Garrett, the intake, the cam, the heads, the fuel system the pipes I run I'm sure are a limiting factor, in power and torque
The 12.9 I ran was my very first run with the combo, as you say, on my 5 slotters. I fried my clutch the very next run when I fitted radials and ran another 12.9.
I'm sure I can probably manage a mid 12 or better on my street tyres at the very least when I take out the Quicksilver car, the only change from the previous driveline will be the clutch.
As for Ante's XY, I'm not 100% sure of exact comb but I think it is an airgap and 2Vs. Steve's combos are always improving he certainly does not keep churning out the same engine for every customer.
Congratulations Steve and Ante sounds like a great combo. I'll need to pop in and catch-up on the latest.
Stefan is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2010, 10:17 PM   #16
RPM351
Default No bottle policy!
OK...
cheers.
Garret,
This is a 98 octane, pump gas daily driver with no tricks,it has all the standard OEM equipment with the exception of a 36gal tank,a 31 spline upgrade output shaft,detroit locker and 31 spline axles,I have a always had a policy of "NO NITROUS" and this is no exception.On Stefan's power graph there is one small but important mistake which I will endevour to correct,the dyno I use needs to calibrate your road speed to your tacho and wasnt on that run but it has no effect on the net output,Stefans car made that peak number at or below 6000rpm.There is no trick suspension,no tramp rods or Cal tracks,no 90/10 shocks or anything else related to drag set ups! By the way its 49rwhp better not 44rwhp.
As for what intake it has its a dual plane aftermarket job with a little TLC.
I will make an effort to post the dyno graphs overlaid on top of each other of both these cars at actual road speed to help clears things up.
Cheers!
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 21-06-2010, 10:24 PM   #17
XT302
Yeah my bad on 49rwhp :(
Stefan no doubt about improvement in yours and limiting factors, you had clutch issues and this had shifting issues, so time will show if these are overcome.
Even sweeter effort for a 2V then.
Look forward to photos and the dyno overlay...ah shame that dyno hiccup wasn't mentioned earlier would have saved some "discussion" on another forum.
Old 21-06-2010, 11:04 PM   #18
Stefan
Stefan's Avatar
Garrett, I'm fairly sure I said the dyno graph rpm was calibrated to my tacho in the car, which was out a country mile. We were more concerned at what rpm I need to shift when looking at my tacho rather than the actual engine rpm.
Alot of this probably got lost in the name calling and thread hi-jacking of previous discussions.
Old 22-06-2010, 06:35 PM   #19
jg33ht
Any chance of posting the slip?
Old 22-06-2010, 10:04 PM   #20
miletica7
Hi Guys,
Great site you have here, look forward to visiting and posting. I'm the owner of the Rhino XYGT. Attached is the timesheet which shows our best run so far. Not easy leaving the line with a manual, I need more practice as the 60ft and reaction times show. Lots of room for improvement. Look forward to the next street meet. Also would like to thank my good mate Steve from RPM Motorsport on building me an awesome package. Will post some pics of the car shortly.
miletica7 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2010, 10:07 PM   #21
HP-0351
Looking FORD to seeing some pics of this XY
Old 22-06-2010, 10:14 PM   #22
XT302
agreed
Thanks for the slip.
Stefan recall the thread and post.
Old 23-06-2010, 01:12 AM   #23
HP-0351
would it be this car?
http://badgerphoto5.badgerphotograph...For%20Real.htm
Old 23-06-2010, 09:13 AM   #24
RPM351
Default Yes thats the one!
Thats it roy...
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 23-06-2010, 11:16 PM   #25
XT302
2 different numbers on both days still T numbers is that prior to the 11sec pass?
Gotta love torque look at the air under the guard
Old 24-06-2010, 01:08 AM   #26
miletica7
Hi There,
T99 was the number on the car when we first ran on 9th and steve posted on the 11th no photo of that run, next meeting which was the 16th car ran 11.56@120.95 MPH T13 which is the photo on the link, got my andra licence and racing number, thanks for your positive comments guys, hope to better the time next week if it does not rain, will keep you posted on our progress.
Ante.
Old 26-06-2010, 11:35 PM   #27
HP-0351
posting this for RPM351
Old 27-06-2010, 08:53 AM   #28
XT302
Miletica, hope it doesn't rain and wish you all the best, look forward to some more photos and updates.
What is the dyno of? Must be a different run (Stefans) cause the graphs are competely different to the one I posted.
Old 27-06-2010, 09:08 AM   #29
RPM351
Default Dyno runs overlaid
Garrett,
These are the two cars both in 3rd gear with same overal diameter tyres,I have used road speed not RPM to overlay them as the RPM's wont allow them to match up correctly.
RPM Motorsport
1/6 Rennie st
Wetherill Park
NSW 2164
ph/fax.029756 6644
Old 27-06-2010, 06:48 PM   #30
XT302
Cheers Steve,
So Ford cast 2Vs or aftermarket jobs?
