Old 11-02-2010, 01:15 AM   #1
bivo7
EF Falcon
bivo7's Avatar
Default barra in mk2 escort
hello any one seen a ba falcon motor go in to a escort, im thinking bout doing it. do you recon it will be able to be registered?
bivo7 is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 02:04 AM   #2
atec77
It used to be common fitting a capri v6 into an escort , enginnered it could be registered , I would expect a nissan 3 litre or ford 4 litre might be but you need to ask you local engineer
Old 11-02-2010, 01:57 PM   #3
JamesR
i dont like your chances of A) fitting a barra in, and B) getting it registered.
a lot of firewall will have to be cut out to fit it in length wise, and then you'll have issues fitting it in width wise.
the engine bays tight enough with a 2ltr in there.
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 08:07 PM   #4
Fev
Fev's Avatar
Want new motor and big power go fora zetec, duratec(more power and lighter) or a jap motoR like an sr20, 4age or a ca18det
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2010, 11:57 PM   #5
bivo7
EF Falcon
bivo7's Avatar
i want something with alot of torque the 4 cylinders have alot of up and go but no torque? any other ideas
Old 12-02-2010, 12:16 AM   #6
Jimmyd
3.6 supercharged Mustang V6
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2010, 01:01 AM   #7
braddyxe51
cortyboy
braddyxe51's Avatar
Ya a charged 6 would be my way too.
A friend runs 11.9 in full weight vn calias. with only 210rwkw. Not sure on torque but it would be heaps.
braddyxe51 is offline   Reply With Quote Multi-Quote with this Post
