ASL
Closed Thread
Old 16-12-2008, 07:47 AM   #1
SA-AUII-MAX
true blue
Default Is there life after Castrol TQ95?
Just finished the rebuild on my tranny, only to find out that there is no Castrol TQ95 immediate available in South Africa!!. When one is servicing the tranny with the filter kit from Ford (part no. ED 7B000 KTF), it says in the instructions that other oils are available as-well. For Shell this should be ATF XTR, for BP Autran LE and a few more were I can choose from. (If I wish to do that). I did a Google search regarding Castrol TQ95 and more than once I had to read that Castrol TQ95 is specially developed for the BTR gearboxes used on Falcons, and that one should only use Castrol TQ95. So say some others manufacturers about their ATF oil. What I like to hear from you is, are some of you using other brands safely so it can replace Castrol TQ95?. What makes this oil so special, while we got higher rated oils available today (Dexron level III). Somebody using Castrol TQ Dexron III? It's available over here.
SA-AUII-MAX is offline
Old 16-12-2008, 10:03 AM   #2
bodes-sh
dex3 will kill the trans. so unless you want to pull it out again (which i doubt) don't even consider it...
you can use any brand equivalent of TQ95. Valvoline make one, as do quite a few companies. it doesn't have to be castrol. a couple of members on here are taxi operators. they use whatever oil is cheapest at the time and still get around 350000km with regular servicing of the autos.
whatever you do MAKE SURE YOU DON'T USE DEX3.
bodes-sh is offline
Old 16-12-2008, 10:07 AM   #3
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
No you cant use dexron III, and you cant use normal ATF, only the XTR version. The oil for the BTR transmissions is specifically designed for them, it has a lot of anti foaming agents that dexron III etc doesn't, all i can suggest is to get some air freighted over to yourself.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline
Old 16-12-2008, 02:40 PM   #4
just me
AU2 XR8
valvoline 95LE is the same as castrol tq95, just valvolines version. i work at a transmission place in vic and thats all we use its good stuff hope that helps
just me is offline
Old 16-12-2008, 02:41 PM   #5
gregaust
From my investigations on the differences in TQ-95 it has extra anti wear additives over normal dexron fluid to help the planetary gears from wearing.
gregaust is offline
Old 16-12-2008, 08:38 PM   #6
waggaclint
waggaclint's Avatar
valvoline also make an oil called MAXLIFE that is ok to use in ford boxes...
waggaclint is offline
Old 16-12-2008, 08:56 PM   #7
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
What rating is Transmax Z and is it ok with the BTR or should only be used in the T5?
Daniel
vztrt is offline
Old 16-12-2008, 09:06 PM   #8
gregaust
Funny you mention that ..Transmax Z is actually a synthetic version to Dexron 3 specs.. I'm sure i'd seen somewhere guys using that but haven't been able to find out for sure .
gregaust is offline
Old 17-12-2008, 02:05 AM   #9
5.0 ED
5.0 ED's Avatar
i'd be staying clear of any tranny fluid that you haven't pers0nally seen appr0ved to suit, anyway as i stated BTR trans fluids of all different brands have extra anti foaming agents in them, cause the BTR trans easily foam's up the transmission fluid, causing airated fluid giving insufficient lubrication and pressure. I have seen dexron 3 put into btr's before and they don't last long, like a couple hundred km's.
Im sure gregaust is also correct in saying that it has extra anti wear additives.
Dexron 2 is actually less foaming than dexron 3.
5.0 ED is offline
Old 17-12-2008, 03:38 AM   #10
SA-AUII-MAX
true blue
Thanks for all the advise. Today is reconciliation-day here in South Africa, so I'm trying to figure out what oil to use. Options are few, looks like the Focus is going to be the summers holiday transport. Will keep you posted.
Big thanks and a Merry Christmas and a Happy New Year to all.
This website is absolutely fabulous.
Max
Old 21-08-2012, 06:21 PM   #11
woza
Default Re: Is there life after Castrol TQ95?
What about using BTR Conversion Formula mixed with Dextron?
Thanks
woza is offline
Old 23-08-2012, 10:41 AM   #12
shayne93
66 Mustang
shayne93's Avatar
Sanggyong autos also use TQ95 so if sanggyong vehicles are available over there, look at what is recommended there for them.
shayne93 is offline
Old 23-08-2012, 10:55 AM   #13
Kryton
Kryton's Avatar
Id has a guess that after 4 years, he may have already found some oil.
Kryton is offline
Closed Thread
