RBS
Old 18-08-2008, 06:43 PM   #1
BlacklistedXR
Default Top Shock Mounts
As most of us know, this is a common problem with the AU Falcon and i am experiencing problems with mine at the moment. Axle tramp is not fun.
Is there an aftermarket option to the Ford ones? If a part number and a rough price can be given on a non genuine or even a genuine unit then that would be very helpful. Thanks.
Current:
Built R32 GTR
520Hp ATW
AU3 Fairmont I6
Whiteline swaybars, FPV Typhoon Rims, Superlows, Custom Intake Piping, Modified BA XR8 Airbox, Big Stereo
Past:
2001 AU2 XR8 220 Manual
1/4 Mile: 13.8 @ 100MPH (161km/h)
Ford Falcon AU2 V8 Auto
1/4 Mile: 13.0 @ 107MPH (172km/h)
BlacklistedXR is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2008, 10:01 PM   #2
richo77
richo77's Avatar
At the moment as far as i know, genuine is the only option. They are around $90 a side and relatively easy to do on your own. Dont pay anymore than $300 total if your getting someone to do it for you.
Good luck with it, you'll be glad when its fixed!
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2008, 03:30 PM   #3
xr8 007
xr8 007's Avatar
i preety sure nolathen make them as well. I changed mine to the genuine ones and never had a problem again.
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2008, 09:22 PM   #4
IH8HSV
XR6T 400kw(well one day!)
IH8HSV's Avatar
What are the symptoms of bad shock mounts? I think i have the same problem.
I changed my shocks but they still knock over every bump.
Is there any way to check them visually? Or is this the only thing it could be.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory
IH8HSV is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2008, 09:49 PM   #5
blackers10
blackers10's Avatar
if its IRS(being XR8 im sure it is) .. ford is the ONLY option (unless nolathane made some in the last 6 months)
one of the T series owners knows sombody who is testing some new ones that use a giant rose joint?(ball joint type thing)... but its still under development and has had a few issues so far due to the stresses and angles applied to it
Old 20-08-2008, 10:01 PM   #6
IH8HSV
IH8HSV's Avatar
I didnt explain myself properly. I meant the front shock bushes.
Cheers.
Old 20-08-2008, 10:05 PM   #7
blackers10
blackers10's Avatar
blacklisted is talking about rears (RE: axle tramp)
front id say its bushes or ball joints (just get somthing to lever the parts with(big screwdriver or crowbar) and the movment should be minimal (it wont hurt it as greater stress applied by 2k kg of car under hard braking and steering ;))
Old 20-08-2008, 10:22 PM   #8
IH8HSV
IH8HSV's Avatar
Ahh o.k.
I have tried that and even the guy from tyre power said everything was tight and looking good. Pedders report said upper control arm bushes needed replacing and a sway bar D bush. Also has a control arm pivot joint.
But i dont see how these bushes would cause a vibration to go away when slightly turning. Wheel bearings have no movement either.
I appreciate your help blackers10.
My next option is to replace everything and pay $2000 which i really dont want to do.
Cheers.
Old 20-08-2008, 10:37 PM   #9
blackers10
blackers10's Avatar
i wouldnt get any work done at pedders
they cant even seem to get a wheel alignment correct (camber even)on a AU Fairlane front end on superlows
and are a rip off
all those bushes are easy to replace
unsure what a control arm pivot joint is?? unless thats pedders for ball joint? lol
Old 20-08-2008, 10:48 PM   #10
IH8HSV
IH8HSV's Avatar
Do the upper control arm bushes need to be pressed out or back in with a hydraulic press???
Old 20-08-2008, 10:56 PM   #11
blackers10
blackers10's Avatar
if its the inner ones
my brother got the grinder out and ground the end off the bushes which made them peel apart easy as
then you just squeeze some grease (supplied with nolathane items) all over the new bushes and put them in and do it all up and its all done
Old 20-08-2008, 10:58 PM   #12
IH8HSV
IH8HSV's Avatar
Thanks mate. Ill do that myself to eliminate at least one problem.
Cheers.
Old 21-08-2008, 12:30 AM   #13
honer
Back to N/A land
I just put nolathane bushes in my uppers and did all of them in the lowers.
Lowers inner and outter require pressing to get out and in (or freezing them may get them in nicely) -- shock mount ones can be lopped off and punched out.
Uppers are a single peice from factory, lop the end off with a hacksaw and knock the other end out.
The Nolathane ones are 2 peice, just push/drive in -- grease up the metal sleeve and drive it in you don't put grease on the the rubber bit that sits in the control arm..... That I can remember anyway.. Instructions clearly state it anyway
honer is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2008, 12:36 AM   #14
FTe_XR8
formerly "3x-puursui7"
hey mate, just changed my rear mounts with the suspension. u can only get genuine ones and yup around the 90-100 mark each side. easy as to do urself prob only take an hour max at home, 4 nuts up top and one down the bottom. i still have my old ones but pretty sure there's nothing wrong with them(no visual damage) i'm guessing they crack causing the axle tramp. goodluck
all hail the mighty V8's
http://www.aufalcon.com.au/3x-puursui7
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2008, 12:47 AM   #15
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
Originally Posted by IH8HSV
Ahh o.k.
Cheers.
Three letters, WSC
Give Peter at Wilkinsons Suspension Centre a call, they are located in Bayswater, and are a family business.
Explain your issues and he will sort it.
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2008, 12:49 AM   #16
CAT600
CAT600's Avatar
As blackers was saying, there are some prototypes being looked at.
Shaynet is the member you need to speak to, although it was bought up last month, and there has been no further progress.
Daniel
Old 21-08-2008, 07:14 AM   #17
V8 EF Fairmont
In terms of the rear shock mounts (and excuse my lack of knowledge), are you talking about the item referred to as a 'top hat'? I just had these both replaced on my car and am interested to know whether you are talking about the same thing.
V8 EF Fairmont is offline   Reply With Quote Multi-Quote with this Post
