Old 02-10-2007, 01:33 PM   #1
ebxr8240
Performance moderator
ebxr8240's Avatar
Default TCI Powerglide ??? Price is right, are they o/k ??
Finally found a Powerglide...
Are these o/k ???
http://store.summitracing.com/partde...5&autoview=sku
Landed here is going to cost me $1700..
Daily driver GTE FG..
Old 02-10-2007, 02:28 PM   #2
crochunter
440cube Dart
crochunter's Avatar
Should be cheap now the aussie dollar is 90cents.
crochunter is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2007, 05:16 PM   #3
brenx
brenx's Avatar
I notice the trans in your link ain't recommended for beyond 450hp. Which probably means its not much better than a stock build with a shift kit? If your doing a conversion (ie Ford)? Make sure the bellhousing bolts on/off.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2007, 11:50 PM   #4
ebxr8240
ebxr8240's Avatar
Na its for a Lexus 1UZ,V8 turbo motor in Mustang Celica...
Yes any stronger the aftermarket case is required...
Spoke to TCI that power level is for a big block Chev ..
Comes with bassic steel upgrades.
The Celica will be less than 1/2 the weight of a b/b Chevy sedan...
I'll try and bring it in with Ford bellhousing though.. Like I need a Chevy housing!!!!!
Old 02-10-2007, 11:56 PM   #5
Rooster
Gimme Shelter
Rooster's Avatar
Cool
have been running a TCI Powerglide (top end of the range) behind a blown LS7 for about 2 years now. only drama we had was after a solid few trashings, not doing enuff band adjustments when dropping the oil. since being a bit more diligent, haven't had a drama. trans cooler in the mix obviously.
Rooster is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2007, 04:31 PM   #6
brenx
brenx's Avatar
You shouldn't need an aftermarket case. I'm running the best part of 600hp through a 6cyl stock case. I used a 6cyl case as 6cyl ones had a bolt on/off bell. The bloke before me ran over 1000hp though it.
