Old 05-08-2007, 12:03 AM   #1
GTWHOA
Just cruisin
GTWHOA's Avatar
Default flashing light
hey all,
OK heres my problem, im getting the flashing radiator/fan pic coming up. The hand book says its a low coolant level warning but the coolant is topped up. the fans are working fine and the car is running at normal opperating temps.
any ideas appreciated.
___________________
BA LTD 5.4
GTWHOA is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2007, 12:48 AM   #2
fairmont1998
fairmont1998's Avatar
Sounds like the float on the sensor in the header tank has packed it in.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2007, 12:03 PM   #3
Burley
CRE.87V
hey mate...unplug the sensor spray a bit of wd40 and blow both ends out...may not be ur prob but this worked with mine. saves u buying a new sensor if thats all it was
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2007, 12:38 PM   #4
FGII-XR6
FGII-XR6's Avatar
it's the sensor
Old 05-08-2007, 06:18 PM   #5
GTWHOA
Just cruisin
GTWHOA's Avatar
thanks for the replies. where abouts is this sensor located?
___________________
BA LTD 5.4
Old 05-08-2007, 07:22 PM   #6
peterban
AULTD
peterban's Avatar
Its in the side of the coolant tank.
On the side of the plastic tank will be a round protrusion with two wires coming out of it, this is the coolant sensor.
It screws out but I think you need a special tool to undo it as they can be very tight.
If your coolant tank is dirty it may be easier to freshen it up with a new tank and sender.
They are on e-bay for $90.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2014, 07:42 PM   #7
4DEB
Default Re: flashing light
Hey there, I have same problem Radiator Fan light intermittently coming on,
There is no switch on the coolant bottle, Eb V8 with the problem and ED 6 cyl without any switch in coolant Bottle, So Where is Switch everyone says bottle although its not!!! Where? Where?
4DEB is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2014, 11:44 AM   #8
rmack
rmack's Avatar
Its not the low water for the washer bottle is it? Au series 2 and greater did not have a sensor on the header tank
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2014, 04:11 PM   #9
4DEB
Its the Radiator with fan inside warning light, I'm pretty sure it is the low water, although has plenty of water, and EB V8 has no switch in header tank, so where is the switch? I have an ED 6 too with no switch in header tank, must be a switch somewhere, need to know soon, any help??
Old 14-06-2014, 06:04 PM   #10
rmack
rmack's Avatar
Sorry was about to respond to the wrong post
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
