ASL
Old 11-06-2007, 11:05 PM   #1
Stav
Smile
Stav's Avatar
Default One strange spark plug colour?
if anyone has ideas on what this may be please comment.All of my spark plugs are like the dark one on top of the photo but cylinder number one is much lighter.What can be causing this? I have already changed the plug and it came up the same. Is it a coolant leak?Is it a leanout in that cylinder?
Site Sponsor See Sponsor Stingray Car Security ๐Ÿ˜๐Ÿ‘ŒโœŒ
Old 11-06-2007, 11:34 PM   #2
Fairlane
V8 Powaah
Fairlane's Avatar
Checked the backpage of my Haynes manual and its pretty tricky to diagnose, looks like High Speed Glazing which makes no sense at all, they are all the same plus and at the same temp.
Has it done this to the no1 cylinder before?
If not im thinking it may just have been a faulty plus (ive had brand new plus not work at all for me) or at a guess maybe incorrect gapping. I probably being a smart ****, but the gap on the faulty one does seem quite a bit less than the good plus.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 11:50 PM   #3
Stav
Smile
Stav's Avatar
It is the second plug in that cylinder today to go that colour? It is almost like there is some residue being pushed in from the fuel inlet and getting stuck in that injector..its wierd?
Old 12-06-2007, 09:13 AM   #4
bodes-sh
from those pictures the one at the bottom, the lighter one, looks like it is working normally, ie normal heat range, but the other one looks like it has carbon or oil buildup on it...
Old 12-06-2007, 04:59 PM   #5
FS5
i'd agree with that ,all my plugs look like the one in the bottom of the pic .
its strange how its only doing it on the one cylinder though .
going by the pic it looks like the one on tops been running a bit rich.
stav ,you sure you ment the bottom plug in the pic is the one thats a different colour to the rest .
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 09:16 PM   #6
Stav
Smile
Stav's Avatar
All my plugs looked like the top one.The odd one out was the bottom one.At this stage after running 12 volts a carbie cleaner through it so far it is running like the rest.I might pull all of them out and run cleaner through them again as this intermittent misfire is very confusing!! I will install a fuel gauge in it tommorow night to maybe sort the issue.
Old 12-06-2007, 09:29 PM   #7
fritzz
fritzz's Avatar
if they are all like the top 1 then theres a problem, the bottom 1 looks good.
its either to much fuel, not enough spark(stuffed plugs) or even oil. u would be able to tell if its oil coz it will have a bit of a shine.
how old are the spark plugs?
# 1997 EL Falcon GLI - Custom built AU 4L bottom end, Billet Turbos B76-GTS, Nizpro plenum, 6boost manifold, Autronic SM4, Custom billet surecam camshaft, 3x 044 pumps and custom undercar surge tank, Custom 4" exhaust, ID2000 Injectors, 60mm Turbosmart gate, Turbosmart race port bov, , Tremec TKO 600, Cebco 330mm Brakes, 3.7:1 9" diff with billet axles and trutrack center 608rwkw, 9.6sec 1/4mile
# 2008 FPV FG GTE - Xa Coilovers, 20x8.5/ 20x10 fairladys
fritzz is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 09:32 PM   #8
Stav
Smile
Stav's Avatar
I on puposely ranthe car irch via my adjustable regulator for fear of blowing the engine up.If it is a lean misfire the last thing I want is for it to detonate.Hence the darker colour .Today I ran it a bit leaner and the plugs look clean.
Old 12-06-2007, 11:31 PM   #9
GSN
bottom one looks good. Stoichiometric ratio burns a light browney reddish tingy colour. that how we used to check a/f ratio in the carby days
GSN is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2007, 11:58 PM   #10
Crash Lander
I was also going to say that the bottom one looks the way they all should look.
Does the car blow any smoke at all?
Some people think I suffer from A.D.D., but they... Oh LOOK! A Chicken!
Crash Lander is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2007, 12:00 AM   #11
Stav
Smile
Stav's Avatar
No smoke at all.
Old 13-06-2007, 03:42 PM   #12
FS5
maybe the injector on that plugs faulty or dirty or something and its running lean compared to the rest.
Old 13-06-2007, 03:58 PM   #13
mr_xr8
Capri GT/TS50/GTR
mr_xr8's Avatar
get the injectors flow tested and take note of which cyclinder they came out off.
R32 GTR Rebuild
TS50 Build
mr_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2007, 08:34 PM   #14
Stav
Smile
Stav's Avatar
I think I fixed the spluttering issue.I totally disconnected the ego sensor and the car did not splutter or do anything of the sort all day..I think I found the issue.number 1 spark plug again was slightly whiter than the rest though.It may be my porting isnt exact or air leak..or..crap injector..
ยซ Previous Thread | Next Thread ยป
Powered by vBulletinยฎ Version 3.8.5
Copyright ยฉ2000 - 2025, Jelsoft Enterprises Ltd.
