21-12-2023, 07:16 PM | #361 | ||
Al
The footage from this video was what sucked me in.....
https://www.bing.com/videos/rivervie...2&&FORM=VRDGAR |
22-12-2023, 05:53 PM | #362 | ||
Al
The steering servo could do with upgrading, down the track. Don't consider it as strong enough.
When i figure out the characteristics better, am looking forward to shock & diff maintenance & tuning. Having 3 adjustable LSD's makes it interesting. (rear one on the EXB as well) |
23-12-2023, 05:04 PM | #363 | ||
Barra Turbo > V8
Fitted a new shell to me Baja Rey.
Who in their right mind at Losi thought 22 tiny easily rounded out screws to attach a 4 part shell which is only replaceable as a whole not in parts was a good idea. I think with this one i might trim a little behind the front wheels as these tyres are a little wider than the standard ones and chewed the old shell.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
24-12-2023, 06:37 PM | #364 | ||
Al
Glad i got curious about the "droop" settings.... rear was set to allow full shock extension, so have shortened by about 5mm.
Seems to have put the drive shafts into the diff end cup slightly too.... can understand why some peeps have them pop out. |
24-12-2023, 06:44 PM | #365 | ||
Barra Turbo > V8
Took my Mojave out today, behind the local rc track is a motorbike track kinda, but theres some roads leading into it.
Was able to stretch its legs (only 75% throttle) was a hoot. I got a rock stuck between suspension and wheel, its scored the inside of the wheel, not badly though. Really need the net thing to stop junk getting into the chassis and important parts!
24-12-2023, 06:55 PM | #366 | ||
Al
Good stuff! yeah almost every drive, i've ended up with a stone either stopping the ESC fan or right down in it.
Also need some bitumen tyres, have been back in that carpark & its taking its toll on tread levels.... have already front to backed them. |
24-12-2023, 10:26 PM | #367 | ||
Al
Curiosity & lack of faith, will see me pulling all 3 diffs shortly. Want to check oil levels & as they supply diff shims, will see about that too.
Will leave the "friction plates" in the rear LSD as is, but centre & front will be rearranged for less slip. Will use stock weight oils for now. Front & rear run 10,000 & centre 100,000. This is proving to be a good distraction! |
25-12-2023, 12:07 AM | #368 | ||
G'day... Looks like a great thread...Been off AFF for a fair while unfortunately due to other stuff and health matters ..
First up and it's not R/C but I love my HO Scale 1:87 model railway mostly in DCC now but I have also been doing radio control with construction /earthmoving models . Been doing it about 18 months I guess now , It's not actually hobby grade although my most recent purchase is pretty good . Sticking with Huina as it's an affordable entry into this type of radio control hobbying . I have three excavators all 1:14 scale . They are the 1592, 1593 and the notably more expensive 1594 with full metal undercarriage ..Two dump trucks also Huina also 14th scale and I dabbled with a dozer 1:16th but it isn't. It's more like 1:20th at best , Heavily modified it though and is okay .. In Europe especially this style of R/C is humungous ..It' s really expensive as well with the serious enthusiasts spending big bikkies .. Somer of the ScaleArt suff is exquisite and many use real hydraulic systems to function .. Its lots of fun but way out of my league .. I don't regret probably spending $30,000 over the past 15-16 years on my rail nor do I regret spending maybe $1500 getting into base level construction radio control .. I know I;d really regret not doing it because you only live once .. Just a taste of the real stuff in Europe...think this is Germany or Austria .. https://www.youtube.com/watch?v=ff4o3BpaYtU&t=1303s Last edited by roddy1960; 25-12-2023 at 12:13 AM. |
25-12-2023, 08:26 AM | #369 | ||
Al
Have watched some of those vids & yes theres some amazing machines.
Have seen & played around with some rail set-ups, some yrs back. All beautiful German products ! Also becoming interested in scale rock climbers. |
25-12-2023, 09:02 AM | #370 | |||
Al
https://es.aliexpress.com/item/40011...d=VvBc6W9pty2o |
25-12-2023, 02:04 PM | #371 | ||
Al
Front droop was the same....fixed. Good way to break them!
26-12-2023, 09:09 AM | #372 | |||
Barra Turbo > V8
I did get a cpl vouchers for hobbies direct so i might do some shopping this week!
26-12-2023, 09:32 AM | #373 | ||
Al
Derr! yep..... they do a CF body for $500+ too...lol
26-12-2023, 09:42 AM | #374 | ||
Al
Man these are cheap now.... hows the amount of easy tuning with my Hobbywing ESC!
https://www.ebay.com.au/itm/29608249...Bk9SR7CP166UYw |
28-12-2023, 02:26 PM | #375 | ||
Al
Picked up a PowerHD 30kg servo & some cheap hex drivers... have been fiddling with those tiny supplied keys.
Speaking with the Hobby shop guy & he recommends upping the diff oils rather than changing friction plates around. |
28-12-2023, 02:31 PM | #376 | |||
https://www.ebay.com.au/itm/40446871...mis&media=COPY My kid has the old school one, i have the newer one. You can plug it into a pc and be fancy, plus its also a balance checker for your batteries. |
28-12-2023, 02:38 PM | #377 | ||
Al
Agree, thanks. Watched a couple of vids on them last night.
28-12-2023, 07:00 PM | #378 | ||
Al
The debris net thingy arrived & some beautiful cnc alloy suspension arms ..... measured up perfect & ran a pin through them & alignment, fit is all good.
Reckon for all 6 arms, about 40gms heavier. |
28-12-2023, 07:35 PM | #379 | ||
Barra Turbo > V8
Keen to see some pics of the net
28-12-2023, 07:57 PM | #380 | ||
Al
Got it here from "lovesister" lol, but payed $28.... quick delivery!
https://www.ebay.com.au/itm/354992941116 Also picked up shock & diff oil (expensive) Jap stuff. Rear will stay 10,000... Centre 300,000 up from 100,000 & Front 50,000 up from 10,000. Should give it a lot more zip & tighten up , on power out of turns. Last edited by HIPO; 28-12-2023 at 08:05 PM. |
28-12-2023, 08:58 PM | #381 | ||
Centre and rear diffs? If its selleys it works. Front diffs i perfer them a bit looser because turning.
Yes, by selleys i do mean roofers silicone. Its way cheaper. |
28-12-2023, 09:18 PM | #382 | ||
Al
28-12-2023, 09:33 PM | #383 | ||
29-12-2023, 06:48 AM | #384 | ||
Al
Atm want known weights, so i know which way to go to dial in for my style.... part of the fun. Tons of initial turn in now, will be interesting just how much changes.
29-12-2023, 07:43 AM | #385 | ||
Barra Turbo > V8
Bloody hell you blokes get into it, i cant be bothered although id like to but i dont know enough about it.
Also will order a net today, wish hobby shops had em only cause i got a cpl vouchers
29-12-2023, 08:14 AM | #386 | ||
Al
So much has changed since i used to do this.
Tons of info & vids on Youtube covering the different aspects.... i've been serving my apprenticeship on there to try & get up to speed. Have just realised this new servo is programable too.... cant see myself delving into that though. |
29-12-2023, 02:09 PM | #387 | ||
Barra Turbo > V8
Ordered one of those nets from the same seller, says breathable i hope it is. Wonder how it does banging on a hot motor also.
Test and confirm HIPO, if yours catches fire i wont use mine
29-12-2023, 03:21 PM | #388 | ||
Al
Haha! definitely breathable. Yep will update, trust me! ...............wish the fan set-up would arrive, really want that on before netting it.
30-12-2023, 12:31 PM | #389 | ||
Al
Alternate , dedicated Mojave shell..... haven't searched prices elsewhere.
https://www.prolineracing.com/produc...PRO361818.html |
30-12-2023, 02:39 PM | #390 | |||
Barra Turbo > V8
Im awaiting this one to come into stock https://hobbiesdirect.com.au/Pro-lin...lear-PRO361817 I wont be faffing painting different colours, it'll get painted just one colour.
