With da Warlords
Ok, so as far as I've worked out, the Au 2 & 3 uses obd2 port with a j1850 (pwn ) protocol???? Right?
If this is correct, could someone please confirm. And if this is correct, what kind of tools have people used in the past. Any specific ones to stay away from etc. I've located a few on ebay, but they seem to be a little on the "cheap" /(maybe nasty) side, vs sites like autoenguenity & odb2shop.com.au which sell for $$$.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
Sly like a G6
If I told you it was "PWM", would I pwn you?
You can get a diagnostic cable and PC software from BPT, $800. If you want to confirm J1850 protocol, give them a call, speak to Barry or Terry.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
Spin 'em Habib !
the Scantool Original is about $2595 , R&E Autos where i work sell the LAUNCH ones for $1295
Daniel
AU2PWR |
FTF Club Moderator
At work we have the Snap On scanner. Really really good. Tells you everything and then some.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
I am currently looking for one as well I have found a company that might be promising.
http://www.glmsoftware.com |
#6 | |||
Sly like a G6
Probably won't work on an AU as it supports international standards ISO 15031-5 and SAE International J1979, not J1850 as above.
While the site states that Quote:
So, this should work on BA or later.
![]() Join Date: Oct 2006
This may be a solution too https://www.ebay.com.au/itm/36125957...Bk9SR86u4NaQYg NEW 5-FT Extension Cable 4 Snap-On DA-4 MT2500-46 & DL-16 OBD-II OBD2 Adapter essentially Snap-On's adapter cable for the AU.
regards Blue |
