Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
03-07-2022, 05:29 PM | #901 | |||
03-07-2022, 05:52 PM | #902 | ||
GT, does the Ford system show the equivalent US part number? Is it 5L1Z-6750-AA?
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
03-07-2022, 05:56 PM | #903 | ||
03-07-2022, 06:15 PM | #904 | ||
Same engine. Thanks! Gives me something to work on.
05-07-2022, 07:49 PM | #905 | ||||
Regular...with metamusal
so i take it the numbers are no help?. |
05-07-2022, 08:02 PM | #906 | ||
05-07-2022, 08:20 PM | #907 | ||
06-07-2022, 05:13 PM | #908 | ||
Big thanks to GT for finding me a NOS AU header tank. Almost impossible to find now days.
Proud owner of the ugliest Ford ever made |
7 users like this post: |
06-07-2022, 06:13 PM | #909 | ||
3 users like this post: |
08-07-2022, 10:51 PM | #910 | ||
Mr GT,
Seeking your knowledge to help understand something. F3LY3B477A is the old black pacnut for the front AU/BA/BF hubs. BA5N042A is the current black pacut to secure the hubs on sedans and Territorys. Ford specify the rear nuts are single use. And obviously a different part number means a different part. But I can't see any difference between the 2 parts, apart from the rear was about $20 more than the front. Same measurements, look the same. The rear one holds a slightly higher torque. Do you know what is the difference between front and rear? And what makes the rear nut single use but not the front? Cheers. |
09-07-2022, 12:07 AM | #911 | |||
https://www.ebay.com.au/itm/25222247...frcectupt=true Territory front retainer nut is W710084S439, AU - BF use the same where as FG Falcon on uses bolts to hold the hub in and is off different design. I would have to physically look at both to see what the difference is, most probably none except made by a different supplier. What specifically are you trying to work out? |
09-07-2022, 11:29 AM | #912 | |||
In an earlier post you said F3LY3B477A (the original front black caged type pac nut for AU/BA/BF/Territory RWD) was replaced by W710084S439 (new grey nut) because you thought the supplier went bust and Ford sourced a new part. I've always understood/believed the rear nut for all IRS vehicles from BA/SX onwards is BA5N042A. The ebay descriptions also lists it for the front of SX/SY AWD Territorys. From what I can see F3LY3B477A and BA5N042A are identical. Same colour, design, thread size and pitch, measurements of the washer, cage, etc etc. So what I'm trying to work out is why BA5N042A costs $20 more (or it did when I first looked at these around 12 months ago) than its superseded front counterpart and why is it listed as single use in the Workshop Manual and in the ebay descriptions. I was hoping in your fountain of knowledge you might know why 2 seemingly physically identical parts are apparently different. P.S. 11:07pm reply. I didnt realise you offered a 24/7 service. |
09-07-2022, 01:33 PM | #913 | |||
All i know is the BA5N042A is made by DANA, not sure who made the previous one, but I at a guess by the part number it may have been overseas? Engineers like to say one use only as they believe that once a fastener is torqued once it then looses its properties. I think they are just protecting themselves in a legal world we live in. |
4 users like this post: |
09-07-2022, 07:04 PM | #914 | |||
I suppose sometimes it really is that simple then. Thanks for your time and efforts once again. By the sounds of it you need a holiday too. |
09-07-2022, 07:24 PM | #915 | ||
The reason why hub nuts are "One use only" :https://www.brakeandfrontend.com/vid...reuse-new-hub/
Also https://gmb.net/blog/common-wheel-hub-mistakes/ and https://www.svtperformance.com/threa...le-nuts.61531/ and https://www.familyhandyman.com/artic...ive-fasteners/
regards Blue Last edited by aussiblue; 09-07-2022 at 07:53 PM. |
13-07-2022, 02:03 PM | #916 | ||
Any chance of finding ed sprint indicator lights.
Cheers. |
13-07-2022, 02:19 PM | #917 | ||
Former BTIKD
It may help GT, and save him some time, if you could be a little more specific like front, rear, side?
14-07-2022, 11:00 AM | #918 | ||
14-07-2022, 06:32 PM | #919 | ||
17-07-2022, 02:49 AM | #920 | ||
Hi any chance BA6584A has become available?
17-07-2022, 09:53 AM | #921 | ||
17-07-2022, 03:06 PM | #922 | ||
Yeah sorry fronts. thanks for info.
21-07-2022, 11:44 PM | #923 | ||
Hi GTLEGEND,
Mate, when time permits do you happen to know if the FG-X XR6 Turbo Red Badge and Front Grille is still available new? Part# i have for the badge is ER2Z 8B262 CA / Grille Part# is ER2Z 8200 CA Cheers, BB
2015 FGX XR6T Ute - Aero Blue - Leather Trim - 6 Speed Manual 1966 Mustang Convertible - Wimbledon White - 289ci Windsor - C4 Auto - Power Hydraulic Roof / Factory AC Previous Fords: - 2012 FGII XR6 Manual Ute - Kinetic - 1984 XF Fairmont Ghia - Olympic Gold - 1987 XF S Pak - White- 1994 ED Falcon Classic V8 - Polynesian Green - 1999 AU1 Falcon S - Hot Chilli Red - 2009 LV Focus Zetec 5sp Manual - Black Sapphire |
22-07-2022, 07:59 AM | #924 | |||
Based on the numbers provided, Badge is obsolete, grille can still get for $295 plus postage. GT |
26-07-2022, 09:14 PM | #925 | ||
Thanks for the info GT, much appreciated.
Shame the badge is gone already, hopefully i can get the badge off my existing one without damaging it.
01-08-2022, 08:56 PM | #926 | ||
Hi GT are there any black headlining pieces left for fgx Ute?
Also does ford still stock lower fg xr8 air box and snorkel? |
01-08-2022, 11:49 PM | #927 | |||
There are only a couple of Shadow Grey FGX Ute roof lining trim left. 5.4 FG XR8 I assume you are talking about, not 5.0? If so yes you can still get snorkels (only a handful left though) and air box for XR8 which is different to GT yes also, but again not too many left. If you need help sourcing let me know. GT |
07-08-2022, 04:17 PM | #928 | ||
I am trying to source a replacement set of bushes for the upper rear shock bush on my 2011 SZ diesel Territory.
I was sent a set of nolathane bushes that allegedly fit but found them too small. The SZ territory shocks seem to be a different size to the Falcons etc. So I am trying to locate the correct replacement bush and should one not be available, a set of replacement rear shocks. Regards Matt |
07-08-2022, 07:58 PM | #929 | |||
New genuine shock would be $180 each plus postage if required. GT |
08-08-2022, 08:13 AM | #930 | ||
Mr GT,
Are you able to get throttle body gaskets for the BF I6. I understand they may now be obsolete, but thought you might have a line on some. |
