Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
01-06-2022, 12:11 PM | #841 | |||
I am going to assume its a 6 cyl 4.0 as the part numbers you refer to are for that engine. You are correct the original water pump with pulley kit had a part number of AU28501KTPP but it is no longer available and long obsolete. The water pump itself had a part number of AU28501KT but is the same in being obsolete and no longer available from Ford. The pulley alone AR2Z8A528AA is still available. Early BA's used the same AU pump until 10/2003 then in 11/2003 they changed to the BA8501KTPP and BA8501KT respectively. The pulley remained the same. All of these are still available. I am sure they are not backward compatible. I think it may have something to do with the way the heater pipe goes into the back of it and changed from just a press fit to one with a clamp and bolt and the boss of the water pump where the pipe goes in is different and the actual pipe is different to between AU and BA. Unsure of who the the OEM supplier is of the pump, but I think the body may have been cast by Ford themselves and then ACL bearing and a few other local suppliers made the pump internals and Dayco the pulley. |
01-06-2022, 12:30 PM | #842 | |||
FordTarius
---------------------- Forte | AU3 (2002) ---------------------- |
01-06-2022, 10:55 PM | #843 | |||
Thanks, Ben
It's easier to get forgiveness than permission. |
02-06-2022, 05:48 PM | #844 | ||
Water pump kit for FGX XR8 available?
http://www.fordforums.com.au/showthread.php?t=11405157 BR3Z-8501H-HK1T AC3Z-8527-A 7T4Z-8590-A I saw you had priced these about 12 -18 months ago assume part numbers are correct. |
02-06-2022, 06:13 PM | #845 | |||
02-06-2022, 06:34 PM | #846 | |||
Thankyou - can confirm have a 3 bolt pulley flange. |
02-06-2022, 11:15 PM | #847 | ||
In that case you would need pump with part number BR3Z8501S not the H level like in that link, the S has three flange, the H 4 and that is what is in that kit, so you would not be able to use that kit and have to buy the parts seperately.
I can get that pump alone for for $220 plus postage if required. |
03-06-2022, 10:29 PM | #848 | ||
Just wanted to write tonight a huge appreciation to GTLEGEND for being able to source parts (that he was able to get) for me to make a start on the Rooflining conversion on my Falcon. Much appreciated Legend!!
04-06-2022, 09:37 AM | #849 | ||
Happy I could help.. let me know if you need help finding other bits. Let me know what you still need to get and we can keep an eye out.
05-06-2022, 04:26 PM | #850 | ||
Hoon On The Rise
Hi,
Long shot and sometimes long shots are worth it. What are the odds of 5R29-1130-AA being in stock? Also same as 8R29-1130-AB Will take 4 if they're available. Thank You
Stomp 'n' Steer FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
05-06-2022, 07:26 PM | #851 | |||
The 5R291130A is a hub cap for BF. I may be able to get 2 NOS but they are obsolete. I have no idea on price, but they were last around $120 each plus freight. As for the 8R29 number is not coming up for some reason, but this is either a hub or center cap. What model is it off or a VIN will help narrow down? Are you sure it is not ending with BA as that's a FG base Ute hub cap? If so I can get 4 of them for $100 each. GT |
07-06-2022, 11:51 AM | #852 | ||
gday GT parts recieved thankyou. im still trying to work out whats supposed to be underneath that top radiator cowling underneath the left and right side holes. cheers.
07-06-2022, 05:15 PM | #853 | ||
13-06-2022, 09:00 AM | #854 | ||
Morning GT, I'm getting a charge fail warning and battery low warning on my EcoLPi ute. The battery is now down to under 12v and is not getting any charge. Good chance I'm going to be up for a new alternator, by the looks of it.
A little bit of basic research tells me that the EcoLPi vehicles run a different alternator (higher capacity) than the petrol versions. Here's the vin: 6FPAAAJGCMDM28719 Are these still available? If so, have you got a price, please? I'm thinking with the weight of an alt, freight cost will probs negate any potential savings, but if you're happy to chase up the details, it'll give me a starting point. Thanks for your assistance.
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
13-06-2022, 10:47 AM | #855 | |||
Yes you are correct the Lpi alternators are different than the petrol ones. Still available and can get for $370 plus freight. I cant see freight being more than $20, but until I know the box dimensions and weight, I would not know exactly. Happy to get one for you if need be. GT |
13-06-2022, 12:03 PM | #856 | ||
Peter Car
Hey GTLEGEND.
Chasing up a G6E Turbo boot badge for an FG. They still available? |
13-06-2022, 12:39 PM | #857 | |||
Thanks for getting back to me so quickly.
13-06-2022, 05:10 PM | #858 | ||
Chasing ba/bf xr headlights? What are they worth if they are gettable
2005 BA MkII XR6 Silhouette - SOLD 2007 BF GT Cobra 6 spd manual #43- SOLD 2016 Mustang GT - Current 2010 XR6 Turbo 50th Anniversary - Sold 2006 BF MKII XR6 Turbo Seduce - Sold 2006 BF MKI F6 Typhoon Toxic - Current |
13-06-2022, 08:23 PM | #859 | ||
13-06-2022, 08:34 PM | #860 | ||
14-06-2022, 11:27 AM | #861 | ||
Peter Car
14-06-2022, 12:14 PM | #862 | ||
14-06-2022, 06:59 PM | #863 | ||
14-06-2022, 07:06 PM | #864 | ||
15-06-2022, 12:01 AM | #865 | ||
GTLEGEND
I am having leakage of power steering fluid at the junction of my hard lines into the steering rack on my 2009 G6E Turbo. On inspection it appears that the (duckbill) seals are damaged. Are the seals available as a pair and if they are what would the cost be posted to Newcastle? Thank you for any assistance you can provide. Barrie (WhiteKnight) Last edited by WhiteKnight; 15-06-2022 at 12:02 AM. Reason: wrong name |
15-06-2022, 08:00 AM | #866 | |||
Are you referring to the seals in the image below with ID 3K664? If so yes they are available and cost $65 for the pair. Postage to Newcastle would be $9.30 tracked via Aust Post. FG Steering Rack Seal.PNG GT |
15-06-2022, 03:42 PM | #867 | ||
Thanks for your help but my son who has contacts at dealer locally got a pair at a lower price and no delivery cost
Thanks again. |
15-06-2022, 05:07 PM | #868 | ||
Thanks to GT for all my parts. All arrived safe and sound. One of the bigger items had a big postage cost and GT went out of his way to try and get a cheaper price and was able to! Legend! Will definitely hit him up next time I need parts!
Thanks! |
15-06-2022, 05:51 PM | #869 | |||
All good, glad you found one cheaper and local. Funny how there is such discrepancy in prices on some parts. Seems my contact can be cheaper on some items, but a little dearer than others and adding freight does not help. Anyhow all we can do is try and as per the first post in this thread, I advise to shop around as sometimes some dealers sell less than most can even buy for. Reach out if you ever need anything in the future that I can help with. GT |
15-06-2022, 05:52 PM | #870 | ||
Anytime bud, glad to help...
