RBS
Old 15-04-2006, 09:53 PM   #1
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Exclamation Urgent Help Required
Gday
My Car wont Start at all , all the Electrics work but when you turn the key , the car makes 3 clicks and then nothing , could this be the Starter Motor , or Flat Battery ( Electrics Work though ?)
Please Help , If Anyone can fix it , ill Pay $$$ upfront !!! : : :
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 09:57 PM   #2
DOC
DOC's Avatar
3 clicks, start with a flat battery or dirty terminals
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 09:57 PM   #3
JC
Miami Pilot
JC's Avatar
Flat battery. Even though other electrics may work, the starter has the biggest current drain of the entire electrical system. Turn everything else in the car off and try again - you may get lucky! If that doesn't work then jump start is required.
You will need another car to get it started - connect black from donor car -ve battery terminal to a good ground on your car (do NOT use -ve battery terminal), and then the red cable from donor car +ve to your battery +ve. Throttle the donor car up to about 2000/2500/3000 rpm, then try starting yours. It should start.
Oh, check the glovebox and make sure it closes properly. If it's very full, the little light in there will stay on and it will drain the battery overnight.
Mods: Tune, ShockWorks, GTE 19” - 8” & 9” with 245 & 275/35/19 Michelin Pilot sport 5s
Daily: SZ Territory RWD 6R80, 20 x 8.5” rims 19” with 245s and Gabriel shocks & SSL King springs
Ford Performance Club ACT
Old 15-04-2006, 09:58 PM   #4
Bucknaked
Bucknaked's Avatar
I agree with Doc. My car has done this. Just get it jumped and yo should be fine.
FG2 XR6T
KIA Cerato
2022 Kawasaki Z900
Bucknaked is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 10:00 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
You should always connect the positive first, donor to flat , then flt neg to a ground on the donor car.....
and then the red cable from sonor car +ve to your battery _ve. Throttle the donor car up to
And buzzzzt flash melt...
nope i know you meant -ve to -ve, +pos to +pos...
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 10:13 PM   #6
GK
Walking with God
GK's Avatar
All good advice.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 15-04-2006, 10:15 PM   #7
JC
Miami Pilot
JC's Avatar
Fixed - edited my post. I always connect -ve first, but +ve first would work too.
Old 15-04-2006, 10:16 PM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
cheers guys ill have a stab tommorow
happy easter
AU2PWR
Old 15-04-2006, 10:22 PM   #9
The Monty
Just slidin'
The Monty's Avatar
Sounds just like my battery problem. Except mine just kept ticking.
Whats the go with this? I havent done this before, just - to - + to +. Am I destroyning my car or something? :
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2006, 10:39 PM   #10
DOC
DOC's Avatar
Connect it as svo347 has said
positve donar to positive dead then negative donar to earth dead car, there is no real need to up the revs in the donar car but do let it sit for a while on idle.
The reason i believe you dont connect the negative terminal on the dead car car is to avoid an explosion if there are any gases around and the spark arcs, but could be wrong on this.
Old 15-04-2006, 10:41 PM   #11
svo347
AFF's 1st DM.......
svo347's Avatar
The theory is, if you dont connect the neg to the battery as the LAST connection, your less likely of a spark and therefore ignighting the hydrogen gas thats present in the battery.
Ie connect it to a chassis ground as the last connection
13.21 @107.7mph
Old 15-04-2006, 10:43 PM   #12
svo347
AFF's 1st DM.......
svo347's Avatar
Your on the right track Doc.... :
13.21 @107.7mph
Old 16-04-2006, 09:20 AM   #13
HLC
Audi S3
where is a good earth on the car to connect the negative terminal off the donor car too? just anything metal that isnt the motor?
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 11:40 AM   #14
INJECTED_250
Custom user title
INJECTED_250's Avatar
Another old theory is to turn youre head lights on... THis can help to take any weird surges caused by old crappy jumper leads that dont make a good connection and have a high resistance . Ive always done it on efi cars never had any trouble.. Defently sounds like a dead battey with the whole 3 click things
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 12:59 PM   #15
antilooped
antilooped's Avatar
HLC - ive always seen the pro's use the alternator body mounts there is a nice part where you can make a good connection on top of it.
AUII Xr6 Manual + Silhouette + Tickford Bodykit + Alloys + Momo Kit = Dreamy!
antilooped is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 01:28 PM   #16
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
All Fixed
Whoosha came over and $116.10 and a Century Ultra Hihg Power Battery Later
Now all i need is the code for my stereo
Cheers Everyone with ideas and Special Thanks to Whoosha for his Guided Wisdom !!
Daniel
AU2PWR
Old 16-04-2006, 01:37 PM   #17
svo347
AFF's 1st DM.......
svo347's Avatar
Yer your welcome :P:P:P:P
13.21 @107.7mph
Old 16-04-2006, 01:52 PM   #18
Whoosha
AU DIE HARD
Whoosha's Avatar
Originally Posted by SR_AU
All Fixed
Daniel
Not to mention free stubbie holder ,,chamios +2easter eggs + car wash...
autobarn cranny easter give aways.... yum free beeess
whoosha
Originally Posted by Riksta
Old 16-04-2006, 01:56 PM   #19
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Invest in a ammeter and voltmeter.... gauge or multimeter kept in your glove box....
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2006, 03:48 PM   #20
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
okie doke AU3 Chaser
yeah the easter eggs and car wash was a nice touch
AU2PWR
