Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Technical Area
Old 07-02-2016, 11:37 PM   #1
penske61
Default Power steering fluid loss
Had a large puddle of steering fluid under my power steering box last weekend. It wasn't overfliied. I refilled it and have driven 3 times this week, but it hasn't come out again?
Any ideas?
penske61 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2016, 11:49 PM   #2
olfella
Cranky old bastard
Default Re: Power steering fluid loss
Apparently there is an O ring on the high pressure hose on the pump that can fail. It may have taken up again. I would be worried that any fluid got into the alternator as alternators and steering fluid do not like each other. Could be an idea to have a look and clean it out if possible.
"But really...what can possibly go wrong"
olfella is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2016, 08:55 AM   #3
foxtrot3
foxtrot3's Avatar
Any ideas?
Hi. WHAT MODEL CAR ARE YOU TALKING ABOUT??????????????????????????
Cheers MD
HI
I'M MICHAEL
Old 08-02-2016, 10:21 AM   #4
penske61
Sorry, it is an XB 351 auto
Old 11-02-2016, 07:34 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. Its a sign that the steering box is well worn. The bush for the sector shaft wears on the sides and becomes oval in shape. In most cases the seal can allow for a bit of sideways movement on the output (sector) shaft but if you park the car and put a bit of load on the steering box by engaging the steering lock or park the car with the steering on full lock the output shaft can be pushed hard to one side and the seal cannot do its job. Wait until it starts dripping all the time as it will need a new bush to fix it. Cheers MD
HI
I'M MICHAEL
