Old 16-02-2015, 08:57 PM   #31
mcfly94
mcfly94's Avatar
Default Re: 2001 AUII XR8 exhaust discussion
Originally Posted by Peuty View Post
Erm, I assume you are talking to me. Everyone that has heard my car comments on how great it sounds. With no balance pipe. So thanks for saying my car only makes noise pollution, that's big of you.
I'll try to rustle up a sound byte.
i have the same, twin 2.5 and no balance, no x, no resonator, just two straight through mufflers not glass packs, theres a certain rev range atm where it barks something cronik, not the nicest sounding, but i think thats because its a huge exhaust on stock headers cats and motor.
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2015, 09:15 PM   #32
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
Originally Posted by STINKY NINJA
A single 3 inch would probably flow better than the stock exhaust with its super restrictive mufflers anyhow,not that im saying to get it because ground clearance may be an issue.
Ideally get a custom 2.25 twin with an x pipe 2 mufflers(centre) and 2 hotdogs(rear) i used to have a custom twin 2.5 with an x pipe and only 1 magnaflow muffler per side and it was a bit sluggy down low and sounded pooey and droned,was on a stock 220kw,was just too big for a stock windsor imo.
Ill say this though,it was the nicest symmetrical looking,shiny exhaust ive ever had on any of my cars,glad i never paid for it lol.
Originally Posted by STINKY NINJA View Post
Soundwise it evens up the note between the 2 separate pipes and sounds alot better than a twin sytem with no balance pipe or x pipe,performance wise im not sure,i also had another 220kw xr8 with a twin system with no balance or x pipe and it was the worst sounding exhaust ive ever heard,almost like an old 253 thong slapper,very bad sound...
This dude is on the money.
2.25" is the ducks guts for the 5L, and they absolutely need a balance pipe.
2.5" would work well from the headers and in the mid section, but the tailpiece must be 2.25".
Making the pipe smaller as the gas travels encourages flow.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2015, 09:23 PM   #33
mcfly94
mcfly94's Avatar
keep in mind you guys are talking about stock 5l's being the 185 to the 220kw yes? even a 220kw with a mild cam would be best with the 2.25
but alloy head and aftermarket intake, cam, surely begins 2.5 territory
Old 16-02-2015, 09:31 PM   #34
BLU-220
FG XR50 TURBO
BLU-220's Avatar
listen very well in what Sox says or he will give you a lecture on about exhaust systems on how they work and what's the best system for different applications
i was waiting for you sox to reply in this thread
BLU-220 is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2015, 09:42 PM   #35
Sox
RIP...
Sox's Avatar
Yeh, fair enough on a 185.
It's painful watching so many people fit an exhaust which is too big, using the mentality that because a race car has it, so should my road car...
Oval Everywhere...
Old 16-02-2015, 09:53 PM   #36
STINKY NINJA
Well you assumed wrong matey,if i quote you then im aiming it at you,if not then its a general statement.
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2015, 10:14 PM   #37
T MAN
T MAN's Avatar
while we are on the subject, what exhaust did the 220kw come with std??
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2015, 10:21 PM   #38
Sox
RIP...
Sox's Avatar
Dual 2.25" to the center mufflers, then dual 2" tail piece.
Oval Everywhere...
Old 16-02-2015, 10:27 PM   #39
STINKY NINJA
If ford would have used decent straight through mufflers it would have flowed quite good.
Old 16-02-2015, 10:29 PM   #40
Sox
RIP...
Sox's Avatar
I did this to mine just recently as a cheap interim until I make a complete new system.
It made quite a decent improvement overall.
Oval Everywhere...
Old 16-02-2015, 10:31 PM   #41
T MAN
T MAN's Avatar
thanks sox..
im currently running hurricane headers, 2.5" 100 cel cats, 2.5" merge into a single 3" with xforce muffler and a generic hot dog at the rear, its a 220kw with std bottom end and trickflow 170 heads..
I have been considering going to a duel system, its just the matter of 2.25 or 2.5 and wether or not to run a H pipe or x pipe cross over...
Old 16-02-2015, 10:53 PM   #42
Sox
RIP...
Sox's Avatar
thanks sox..
As already mentioned a dual 2.25" is ideal for a road going 5L.
My 5.6L Windsor has dual 2.5" to the middle and dual 2.25" tail piece.
The method of balance pipe isn't really important, so long as it has one.
Oval Everywhere...
Old 16-02-2015, 10:54 PM   #43
NCII40
XR6T BA 2002
NCII40's Avatar
http://www.fordforums.com.au/attachm...7&d=1423959668
What about 2.5 crush bend rear section
as you can see its reduced the diameter of the pipe /??
would this be ok?? with an added xpipe
XR6T 2002 BA
Old 16-02-2015, 10:58 PM   #44
Sox
RIP...
Sox's Avatar
The bigger pipe will still have lower velocity, so not really.
It's all about keeping exhaust velocity high in the most used RPM range.
Oval Everywhere...
Old 16-02-2015, 11:00 PM   #45
b2tf
not here much anymore
b2tf's Avatar
Not an AU but a 5l nonetheless, my EL runs a twin 2.25" with no merge pipe, metal cats, a straight through muffler then 2 resonators at the back. Happy with it.
2024 F150 XLT
Old 16-02-2015, 11:24 PM   #46
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Problem with 2.25 is that it then becomes custom? What off the shelf system is there in that size?
  • 2023 Mitsubishi Triton
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2015, 11:43 PM   #47
STINKY NINJA
Thats the only issue with it,can become pricy to get a custom mandrel bent twin system done,i think thats the only reason most go with twin 2.5 off the shelf.
I only just got a new exhaust for my eb,only off the shelf options were 2.5 or 3 inch single or twin 2.5 with no x pipe,i would have loved a twin 2.25,i know its not a 220 xr8 but my motor pretty much has 220 heads,cam,manifold(not t/b)sounds almost identical.
Old 17-02-2015, 07:26 AM   #48
NCII40
XR6T BA 2002
NCII40's Avatar
you would be looking at over a 1000$$ to have a custom 2.25 twin with 2 x mufflers and xpipe
2.5 twin with 2 x mufflers easily accessible at a wrecker 2nd hand for 200$$ and probably about 120$$ to 200$$ to install
XR6T 2002 BA
Old 17-02-2015, 08:18 AM   #49
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
But without going to pick a part what is the cost of a 2.25 cat back?
I saw Manta had a 2.5 dual for about $950. Ill have to measure mine.
Old 17-02-2015, 09:06 AM   #50
pete05
pete05's Avatar
Polyal I was just quoted $1200 for a 2.25 mandrel exhaust by one of the best in western sydney.
AU11 xr8 manual
pete05 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2015, 09:13 AM   #51
ebv8
ebv8's Avatar
i had a couple of AU XR8's,
3in single 2 mufflers, sounded crap
duel 2.25 with chambered mufflers no balance pipe, great note but quiet
put on 2 hotdogs, loud and flappy
put on a balance pipe, loud and less flappy but too loud really
put on 2 redback straight throught mufflers, nice note but think these without a balance pipe would be great
and last one was a 220kw with 3in single and sounded flat and boring
so all in all if i did it again i'd use a duel 2.5, 1in balance pipe, and a single oval resinator each side placed at the back if they fit
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2015, 12:27 PM   #52
FTW-302
Just buy the Manta twin 2.5' system, you won't be dissapointed.
FG MK2 XR6 Turbo ute. Swift Green. 307rwkw.
AU T3 TE50 Congo Green.
FTW-302 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2015, 12:30 PM   #53
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Does anyone have any clips of the Manta setup?
Mines pretty loud and droney at the moment, no idea what brand it is though. I was after something a bit more refined.
Old 17-02-2015, 01:04 PM   #54
BOTTLEDUP
My understanding is it isn't very quiet, but the only guy I know running it is FTW-302. I think he might have some clips, perhaps drop him a PM?
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2015, 10:33 PM   #55
Bossxr8
Peter Car
Bossxr8's Avatar
Mine was $600 for a dual 2.25, 2 resi's and 2 chrome tips, but I supplied the 2 Hooker aerochambers (which are too quiet). All up it would have cost pretty much bang on $1000 I think.
Picked up 9rwkw with it though so it made excellent gains for nothing but a catback over the previous single 2.5.
Old 17-02-2015, 11:55 PM   #56
Sox
RIP...
Sox's Avatar
Comparing a brand new system to a second hand system is really an apples/oranges thing.
You might find a new system to be a bit less than that too, perhaps as low as $800.
And, I wouldn't have thought a good 2.5" dual exhaust system is common from a wrecker.
Oval Everywhere...
Old 18-02-2015, 01:58 AM   #57
LyleXR8
manta use combinations of mufflers, resonators, hotdogs and straight pipes in the middle section and tail pipes, so many different combinations can be made
LyleXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2015, 07:58 PM   #58
b2tf
b2tf's Avatar
Nothing as far as I know. I guess its one of those things, you can either have one made exactly how you want it for a price, or grab an off the shelf job and take the pros and cons as they come.
FWIW I had a Difillippo system on my last XR8 and it was good, but it was a single 3" also.
2024 F150 XLT
Old 20-02-2015, 07:12 PM   #59
NCII40
XR6T BA 2002
NCII40's Avatar
Ok i stuffed up
I bought the falcon Dual Exhaust and it don't fit my fairlane
we cut the pipes ready to extend the front section and weld in an XPIPE but the rear section didn't fit and it was sitting heaps low
It was build for a sedan and this would of cost around the $1000 mark
anyone else want it?? it practically brand new
i left it at the exhaust shop
owes me $220
Purchase me
XR6T 2002 BA
Old 20-02-2015, 07:26 PM   #60
T MAN
T MAN's Avatar
I would if you were in nsw...
